(2017-09-14, 08:30)debutanker Wrote: [ -> ]Seems that PR: 12797 was the clue for my problems when switching tv channels ( https://forum.kodi.tv/showthread.php?tid...pid2639954 ) ?!
Thanks alot for this new, smooth experience!
Is there something more to do for the addon maintainers in the future to keep this experience alive?
Cause ive opened a issue report on github for my pvr addon ---> https://github.com/kodi-pvr/pvr.dvblink/issues/97 .
Yes, although we were able to get it going quite well with a patch on Kodi side l, the add-on maintainers are still in charge to fix this properly (and finally) on their end.
Many thanks for all your efforts, @ksooo!!
(2017-09-12, 00:03)Milhouse Wrote: [ -> ] (2017-09-11, 17:24)Boulder Wrote: [ -> ]Here's the logfile archive right after installing #910.
It looks like the Chromebook needs the ar3k firmware.
I'll include this in tomorrows #0912 build, please confirm if that resolves the issue tomorrow.
Boulder please confirm if the latest builds are now working, otherwise I'll close the PR and the firmware won't be included in future builds/releases.
(2017-09-14, 12:04)Milhouse Wrote: [ -> ] (2017-09-12, 00:03)Milhouse Wrote: [ -> ] (2017-09-11, 17:24)Boulder Wrote: [ -> ]Here's the logfile archive right after installing #910.
@Boulder please confirm if the latest builds are now working, otherwise I'll close the PR and the firmware won't be included in future builds/releases.
Just got around to testing, and the BT hardware now works fine. Thanks
New LibreELEC.tv Leia build #0914:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.13.2 #1 SMP Thu Sep 14 23:32:49 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170914233121-#0914-gdce110d [Build #0914]
# Kodi version
(18.0-ALPHA1 Git:ae8206a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (dce110d,
changelog) and tip of
XBMC master (ae8206a,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (008cb78, +7), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (a855663), pvr.njoy (99874de), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8a1e224, +13), pvr.vbox (b5da811), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (9bfd868), pvr.wmc (7e2cb4b, +1), pvr.zattoo (02a171e, +5)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1978: linux: update to linux-4.13.4
- Include [env] PR:1980: unpack/extract: avoid calling extract multiple times, sourcing config/options each time
- Include [env] PR:1982: RPi: add alsa card conf for IQAudIODigi to enable passthrough
- Include [env] PR:1986: kernel-firmware: add ar3k firmware for Asus Chromebook M004U
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12767: Partial revert of imdb crashfix due to a introduced bug
Build Highlights:
- New 4.13.2 kernel
- RTL8192EU: Update to new branch
- Add pvr.teleboy (Swiss TV channel)
Build Details:
- LibreELEC.tv:
- linux: enable internal regdb, disable crda for WeTek_Core/WeTek_Hub/imx6 (PR:1977, 1 commit, 3 files changed)
- checksums: fix packages after github change; fix download logic error (PR:1975, 2 commits, 126 files changed)
- amd updates (PR:1974, 2 commits, 2 files changed)
- Python: add patch to use /dev/urandom instead of /dev/random (PR:1965, 1 commit, 1 file changed)
- RTL8192EU: Update to new branch (PR:1973, 1 commit, 2 files changed)
- librespot: update to ddfc28f (PR:1971, 2 commits, 8 files changed)
- pvr.teleboy: new pvr addon (PR:1987, 1 commit, 1 file changed)
- XBMC:
- Allow the binary addon to set redirect limit (PR:12779, 1 commit, 2 files changed)
- Allow setting custom http request from binary addon (PR:12790, 2 commits, 3 files changed)
- Allow binary addon to get multiple values for same property name (PR:12780, 1 commit, 16 files changed)
- VideoPlayer: make OpenFile asynchron (PR:12797, 2 commits, 11 files changed)
- Split YUV2RGB shader into GL/GLES (PR:12794, 1 commit, 12 files changed)
- VideoPlayer: fix OnPlayBack callbacks (PR:12799, 2 commits, 3 files changed)
- Remove autotools files from gitignore (#12514) (6cb5c48)
- inputstream.adaptive:
- Rename GetProperty to GetPropertyValue (PR:67, 1 commit, 1 file changed)
- [HLS] local instead member stringstream for downloads (dadea14)
- pvr.zattoo:
- Rename GetFileProperty to GetFilePropertyValue (9f45464)
- Sync curl with pvr.teleboy (b6d4eee)
- Make UpdateThread multithreaded (ab0c3c7)
- Sync with pvr.teleboy (10bb9e2)
- Fix build error (02a171e)
- Updated: [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Updated: [env] patch: pvr addons: disable broken addons
- Added: [env] PR:1978: linux: update to linux-4.13.4
- Added: [env] PR:1980: unpack/extract: avoid calling extract multiple times, sourcing config/options each time
- Added: [env] PR:1982: RPi: add alsa card conf for IQAudIODigi to enable passthrough
- Added: [env] PR:1986: kernel-firmware: add ar3k firmware for Asus Chromebook M004U
With #0914 and further VideoPlayer adjustments, the experience with live tv is, and without exaggerating, the best i ever had within kodi.
Great job @Team-Kodi!!
Edit: noticed one little thing - if i open the osd channel menu, kodi doesnt show me the channel which is on air actually, but the channel which was played before.
(2017-09-15, 10:29)debutanker Wrote: [ -> ]With #0914 and further VideoPlayer adjustments, the experience with live tv is, and without exaggerating, the best i ever had within kodi.
+1
Though I never really had problems concerning PVR & Live-TV using Libreelec, those improvements really make a great experience!!
Thumbs up!!!
About channel osd - in my case it does not show the last aired channel but always the first one of the specific group. I'm using favourites with different groups (sports, news, etc...).
Hi Milhouse,
Possible to have new Waveform addon ? It was disable with last build. Thanks.
New LibreELEC.tv Leia build #0915:
Generic
# uname -a
Linux NUC 4.13.2 #1 SMP Fri Sep 15 22:46:18 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170915224451-#0915-g4218aca [Build #0915]
# Kodi version
(18.0-ALPHA1 Git:1a06e0d). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (4218aca,
XBMC master (1a06e0d,
- Includes latest addons: inputstream.adaptive (aa62764, +9), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (a855663), pvr.njoy (99874de), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8a1e224, +13), pvr.vbox (b5da811), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (9bfd868), pvr.wmc (7e2cb4b, +1), pvr.zattoo (943a9b6, +7)
- Include [pkg] PR:12802: [cmake] correctly escape install regex syntax introduced at #12538
Build Highlights:
- ffmpeg hevc updates from RPi newclock5 (no obvious issues with x86, mentioned only for future reference)
- player state fixes
Build Details:
- LibreELEC.tv:
- kernel-firmware: add ar3k firmware for Asus Chromebook M004U (PR:1986, 1 commit, 1 file changed)
- XBMC:
- [PVR] Cleanup: Remove obsolete and unused setting pvrplayback.scantime. (PR:12800, 1 commit, 4 files changed)
- [cmake] Exclude *.xml.include files from install/package generation (PR:12538, 1 commit, 1 file changed)
- player state fixes (PR:12801, 2 commits, 17 files changed)
- ADTSParser implementation (76ce861)
- ADTS padding changes / Lock tree while accessing psshset (HLS) (aa62764)
- pvr.zattoo:
- Try to fix loading of guide data (170a264)
- Limit update thread to 1 (943a9b6)
- Added: [pkg] PR:12802: [cmake] correctly escape install regex syntax introduced at #12538
Milhouse
Problem with the delayed sound is still existing, only for info
Does anyone have issue with playback ?
Randomly playback hangs on image, if I wait nothing happens. If I stop playback, Kodi freeze few seconds before go back to files list.
Something else, when I use backward/forward, Kodi always caching and take many seconds to resume playback.
This happens since 2/3 builds ago. No issue with Kodi on OSX with same files.
(2017-09-15, 19:07)Guilouz Wrote: [ -> ]Possible to have new Waveform addon ? It was disable with last build. Thanks.
visualization.waveform updated.
(2017-09-16, 05:03)Milhouse Wrote: [ -> ] (2017-09-15, 19:07)Guilouz Wrote: [ -> ]Possible to have new Waveform addon ? It was disable with last build. Thanks.
Hi Milhouse, any chance you could build projectm and asteroids as well?
Thanks in advance!
