Hi Milhouse,
There is something wrong when we use available version with service libreelec settings addon, popup is displayed and Kodi freeze.
(2018-05-12, 17:16)Guilouz Wrote: [ -> ]Hi Milhouse,
Seems, that there has already been taken notice of it --->
https://forum.kodi.tv/showthread.php?tid...pid2734081
(2018-05-12, 14:32)lanzorg Wrote: [ -> ]I just installed your latest build, I updated from stable LibreELEC Generic.
I can finally use VAAPI hardware decoding.
But unfortunately I don't have working WiFi anymore.
It's a broadcom based chipset, it worked flawlessly with stable branch.
Is there a way to install/reinstall the WiFi driver?
To diagnose hardware issues we need a zip file from your Logfiles directory.
I can only guess what the problem is - take a look at this post:
https://forum.kodi.tv/showthread.php?tid...pid2677935
hi
i recognize that le / kodi does not recognize the usb dongle from any usb port anymore ( usb stick for bluetooth keyboard )...setup is asrock beebox / J3160 nuc...
i jumped from build 301 where it worked to current 0511...ideas?
greetings
(2018-05-12, 21:26)appendizitis Wrote: [ -> ]hi
greetings
Only that there's a build between #0301 and #0511 that is the first to not recognise your dongle. Knowing which build that is might help to narrow down what is responsible for the changed behaviour.
Does the dongle still work with #0301? Can you upload a zip from the Logfiles Samba share after booting #0511 with the dongle connected.
hi
got some more problems...grafic disorder in libreelec menue...cannot choose ....box started to freeze if i want to choose anything, restart does not solve the problem.
i will upload a log coming week...sy for that
(2018-05-10, 09:31)jznine Wrote: [ -> ]Any idea what the default will be for the adjust display refresh rate once it is removed from the GUI?
My guess is the default behaviour of display refresh rate switching will be "off" until you enable one or more resolutions in the Whitelist, at which point it will be "on" (presumably equivalent to the current "Always").
Hi i have a massive problem with your releases.
I can play one Video. After that i can use kodi normaly but i can not start any video. Autoplay for videos does not work too.
Any ideas what to do?
(2018-05-13, 15:06)Maximus1 Wrote: [ -> ]Hi i have a massive problem with your releases.
I have a massive problem with your debug log-free bug report.
(2018-05-13, 15:51)Ipaddle Wrote: [ -> ]Hi
I am using build #0403
KODI crashes when playing any music file.
This is the log file (hopefully): https://paste.kodi.tv/uyivajurez
Link doesn't show me anything - LibreELEC has a built-in crash log upload facility.
(2018-05-13, 16:30)Ipaddle Wrote: [ -> ]Yes, I know but that did not work (I think the file is too large 5.3 MB).
Here link to the file on my Google drive: https://drive.google.com/file/d/1iTSXPjB...sp=sharing
But the way it is build #0404
Disable ProjectM, as the crash is occurring in that add-on.
(2018-05-13, 16:36)Milhouse Wrote: [ -> ] (2018-05-13, 16:30)Ipaddle Wrote: [ -> ]Yes, I know but that did not work (I think the file is too large 5.3 MB).
That worked (actually I had to delete the add on and its settings. Thank you very much. I am happy now.
New LibreELEC.tv Leia build #0513:
Generic
(Supercedes previous build)
SHA256 Checksum:
cbe14d6b2de115aaaeeccca3a7e8fc3e93ada06e4cecd4b8d195b5be8c0de2f0
(Generic)
text:
# uname -a
Linux NUC 4.14.39 #1 SMP Mon May 14 03:37:31 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180514033358-#0513-ga418694 [Build #0513]
# Kodi version
(18.0-ALPHA2 Git:ce5cecc). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a418694,
changelog) and tip of
XBMC master (9815b13,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (0da87a8), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (ac94e59), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (00d57de), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (dbdc96e), pvr.vbox (3cf15ad), pvr.vdr.vnsi (ed1c124), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (a410f2b), vfs.libarchive (1b00b57)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2679 (perma): eventlircd: don't grab power buttons
- Include [env] PR:2680 (perma): kodi: mid-May 2018
- Include [env] PR:2682 (perma): linux: update to linux-4.14.39
- Include [env] PR:2689 (perma): init: add sky42 enhancements/bug fixes
- Include [env] PR:2692 (perma): RPi, Generic: fix erratic IR timeout behaviour on Topseed mceusb receiver 1784:0011
- Include [env] PR:2694 (perma): Generic: allow lower IR timeouts on ITE CIR devices
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13721 (perma): Std thread
- Include [pkg] PR:13871 (perma): [Music]Artist art in file view and on playback from fileview
Build Highlights:
- Std threading fixes - LE Settings add-on now rendering correctly
- VideoPlayer: add setting for using VAAPI HEVC
- [PVR] multithreading/access fixes
- connman: update to connman-1.36
Build Details:
- LibreELEC.tv:
- Revert "make: Fix glob handling (#2681)" (PR:2697, 1 commit, 2 files changed)
- connman: update to connman-1.36 (PR:2698, 1 commit, 3 files changed)
- vdr-addon: update to 2.4.0 (PR:2675, 3 commits, 22 files changed)
- mpd: update to 0.20.19 (PR:2668, 1 commit, 10 files changed)
- oscam: update to 11420 (PR:2665, 1 commit, 10 files changed)
- XBMC:
- VideoPlayer: add setting for using VAAPI HEVC (PR:13856, 3 commits, 3 files changed)
- Use GetDynPath for getPlayingFile (PR:13874, 1 commit, 1 file changed)
- BusyDialog: ignore gui messages while active (PR:13861, 1 commit, 11 files changed)
- [PVR] CGUIWindowPVRBase multithreading fixes (PR:13879, 5 commits, 2 files changed)
- Prefer stereo streams if user has configured 2.0 in AE (PR:13877, 1 commit, 4 files changed)
- dialogs/GUIDialogBusy: stop the CThread properly (PR:13880, 1 commit, 1 file changed)
- Revert "BusyDialog: ignore gui messages while active" (PR:13881, 1 commit, 11 files changed)
- paplayer: only fire a single OnPlaybackStarted for a file (PR:13882, 1 commit, 3 files changed)
- PVRClient: protect access to m_timertypes (PR:13883, 1 commit, 1 file changed)
- inputstream.adaptive:
- [WV JNI] Hold Classloader open for OnEventListener to avoid GC cleanup (0da87a8)
- pvr.dvbviewer:
- Add support for guest privileges: (1d87501)
- Bump version to 3.4.6 (98d7170)
- Add custom timeout setting for livetv connections and timeshift (f9298c3)
- Bump version to 3.4.7 (ac94e59)
- pvr.vdr.vnsi:
- client: delete cVNSI{Demux,Recording} on open error (PR:14, 1 commit, 1 file changed)
- pvr.zattoo:
- Persist zattoo session to prevent multiple logins (46f76a5)
- Shorten session cookies in log (9cf0646)
- Improve storing session cookie (bfeefe1)
- Store uuid after generating (a410f2b)
