2018-11-07, 15:12
(2018-11-06, 22:44)jmerrilljr Wrote: [ -> ]Here is the dmesg | pasteinit: http://ix.io/1raX. #1016 plays fine. #1016x does not.
iperf -c 10.0.1.55 -u -P 1 -i 1 -p 5001 -f G -b 100.0M -t 10 -T 1
Can you test TCP with iperf rather than UDP?
This doesn't look good:
text:
[ 19.362489] pcieport 0000:00:1c.0: AER: Multiple Corrected error received: 0000:00:1c.0
[ 19.362505] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 19.362509] pcieport 0000:00:1c.0: device [8086:9c14] error status/mask=00001000/00002000
[ 19.362513] pcieport 0000:00:1c.0: [12] Timeout
[ 22.571954] pcieport 0000:00:1c.0: AER: Corrected error received: 0000:00:1c.0
[ 22.571976] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 22.571983] pcieport 0000:00:1c.0: device [8086:9c14] error status/mask=00001000/00002000
[ 22.571991] pcieport 0000:00:1c.0: [12] Timeout
[ 22.751504] pcieport 0000:00:1c.0: AER: Corrected error received: 0000:00:1c.0
No idea what is causing that at the moment. Unfortunately the log spam has resulted in the log buffer being truncated.
Can you add
log_buf_len=16M
to your kernel command line, then boot with #1022 (4.18.14, no problems) and run dmesg | pastebinit
, then upgrade to #1106 (4.19.1, kernel errors) and again run dmesg | pastebinit
, pasting both links here - hopefully this time we'll have complete kernel logs for both a working and non-working kernel. I'll then be able to do some digging. It looks like 4.19 introduced quite a number of r8169-related bugs.
