dirkie I'd suspect it's something in the BIOS settings. Some time ago, I found a guide & posted it
here ,
It was Openelec, & it was a celeron nuc, it might not help, but you have nothing to lose.
On the Devices and Peripherals > Video menu, 1GB Minimum Memory is set to 512 MB. ?
Can you see the boot usb in the bios boot menu F10?
New LibreELEC.tv Leia build #0812:
Generic
(Supercedes previous build)
SHA256 Checksum:
7af8488015f160c6efc46cc9a88cdae9b12e009a4f37f1d1f38371aa4e6d0f1b
(Generic)
text:
# uname -a
Linux NUC 4.17.14 #1 SMP Sun Aug 12 21:05:08 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180812210354-#0812-gb98d2ae [Build #0812]
# Kodi version
(18.0-BETA1 Git:269a24c). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (b98d2ae,
changelog) and tip of
XBMC master (881a9e6,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (6bf7802, +2), inputstream.rtmp (bf5351e), peripheral.joystick (08e4a1a), peripheral.xarcade (07be227), pvr.argustv (1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313, +2), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (89cac8b), pvr.mythtv (e61f47c, +4), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0460536), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441, +2)
- Exclude [env] kodi-999.99-filesytem-reduce-smb-chunksize-to-64K.patch: Kodi SMB chunk - use upstream commit
- Include [env] compare (perma): flatbuffers: add initial package
- Include [env] patch: RPi: POE support
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2837 (perma): linux (RPi): update to linux-4.14.61
- Include [env] PR:2838 (perma): linux (Generic): update to linux-4.17.14
- Include [env] PR:2862 (perma): glibc: update to glibc-2.28
- Include [env] PR:2867 (perma): enable dynamic configuration of netconsole at runtime
- Include [env] PR:2872 (perma): update dvb addons
- Include [env] PR:2873 (perma): wpa_supplicant: Fix EAPOL vulnerability
- Include [env] PR:2876 (perma): open-vm-tools: bump to stable-10.3.0
- Include [env] PR:2877 (perma): kodi: use HTTPS and SHA256 for LibreELEC repo addons
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
Build Highlights:
- kodi: use HTTPS and SHA256 for LibreELEC repo addons
- Fix GUI sounds not updating when changed
- Retroplayer: black screen fix for ARGB1555 and some other small changes
- [bluray] Change log messages after the fs callbacks refactoring.
- open-vm-tools: bump to stable-10.3.0
Build Details:
- XBMC:
- Fix GUI sounds not updating when changed (PR:14285, 1 commit, 3 files changed)
- Retroplayer: black screen fix for ARGB1555 and some other small changes (PR:14281, 4 commits, 5 files changed)
- [docs] Add missing Player infolabels/boolean conditions (PR:14261, 2 commits, 1 file changed)
- [Docs] Unescaped comma in Player.PlaySpeed (PR:14289, 1 commit, 1 file changed)
- [bluray] Change log messages after the fs callbacks refactoring. (PR:14288, 3 commits, 5 files changed)
- [gui] Cosmetic improvements and fixes (PR:14290, 3 commits, 3 files changed)
- OpenGL: fix gui fonts for GL version 2.1 (PR:14293, 1 commit, 1 file changed)
- Revert "Retroplayer: RenderBufferPoolOpenGLES: use internal format GL (PR:14292, 1 commit, 1 file changed)
- pvr.hts:
- Demuxer fixes (PR:371, 2 commits, 4 files changed)
- Added: [env] PR:2876 (perma): open-vm-tools: bump to stable-10.3.0
- Added: [env] PR:2877 (perma): kodi: use HTTPS and SHA256 for LibreELEC repo addons
Hi Milhouse
I've found a strange bug which I never had in LE 8.2.5 (there's a thread in the german kodi board)
Anyway, I tried the last nightly that's possible to download "#0801, 01-Aug-2017" and there is the bug, too
Now I want to try the builds #0713, 14-Jul-2017 -> #0731, 31-Jul-2017
I just want to check from when the bug appears. Do you have the old nightlys (earlier than #0801, 01-Aug-2017) and could you send it to me?
Milhouse thank you for your reply. I tried with 8.2.5 and KERNEL/System from that version you linked without success. It hangs right after bootloader timeout or trying to run "run". I chcecked with bios 37 and 42 :/
can i help with logs or something? Just tell me if I can do anything any help appreciated.
That bios RAM changes did not change anything.
Hi, I had used Libreelec in the past (Asrock Beebox 7100U) but after the update from (internally Kodi 16 -> 17) the DTS HD-Master and True HD was not working anymore.
So I switched to Windows 10 LTSB and let it run with Kodi 18 Leia Alpha 1-3, I had 3840x2160 60Hz Resolution working and all Sound Formats where playing with no issue.
I was a little bit unhappy that my screen resolution breaks down if I turned off my Yamaha A1050 Receiver under Windows 10 and so I heard from Libreelec and Milhouse.
After download the latest Libreelec Leia Version and install them I have updated to the Milhouse #0812 Version.
My screen resolution is again 3840x2160 but only 30Hz and my DTS-HD Master and True HD sound not working anymore.
I tried many options but nothing helps me and so I will ask you here in the forum.
Someone a hint for me what I should use or check?
Thx a lot.
(2018-08-13, 13:38)ChristianundCo Wrote: [ -> ]Now I want to try the builds #0713, 14-Jul-2017 -> #0731, 31-Jul-2017
No, they're gone I'm afraid.
(2018-08-13, 17:29)dirkie Wrote: [ -> ]@Milhouse thank you for your reply. I tried with 8.2.5 and KERNEL/System from that version you linked without success. It hangs right after bootloader timeout or trying to run "run". I chcecked with bios 37 and 42 :/
I can't think of anything which would help - possibly removing
quiet
from the kernel command line might show a little more information, but this sounds like a vendor issue. We have other people with Gemini Lake systems installing and booting fine, but there's either a hardware fault with yours (run memtest86+ on the RAM?) or it's a BIOS bug which is preventing the Linux kernel from booting. Are you able to install something like Ubuntu from a flash drive?
Milhouse thank you gain for your reply. I just installed Ubuntu 18.04.1 LTS on tht NUC . "without" problems. Only problem: I hve to unplug and replug HDMI after initial boot.
fresh install:
~$ uname -a
Linux test-NUC7PJYH 4.15.0-29-generic #31-Ubuntu SMP Tue Jul 17 15:39:52 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
And i upgraded with dist-upgrade to:
$ uname -a
Linux test-NUC7PJYH 4.15.0-30-generic #32-Ubuntu SMP Thu Jul 26 17:42:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
edit:
tried kodi. 1080p running fine. uhd stuttering and hdmi audio out not working out of the box.
(2018-08-13, 19:39)dirkie Wrote: [ -> ]@Milhouse thank you gain for your reply. I just installed Ubuntu 18.04.1 LTS on tht NUC . "without" problems. Only problem: I hve to unplug and replug HDMI after initial boot.
fresh install:
When booting the LibreELEC installer, have you tried changing HDMI ports on the NUC (unplugging the cable from HDMI1 and plugging into HDMI2, or vice versa)? I seem to recall an issue with Intel NUCs a while ago where the output port would switch resulting in blank screens (either that, or I've mis-remembered what the problem was at the time).
Can you disable the "other" HDMI/Display Port/whatever output in the BIOS?
Edit: Also, do you have the option to boot using BIOS (Legacy) or only UEFI? In the boot manager you should see the USB boot drive listed twice, once for UEFI and again without UEFI - try both (if you haven't already). As you can tell, I'm running out of ideas.
New LibreELEC.tv Leia build #0813:
Generic
SHA256 Checksum:
71607786f8bc183b391487d56e7bc9dc4304d481638a5e081aebd900599e6520
(Generic)
text:
# uname -a
Linux NUC 4.17.14 #1 SMP Mon Aug 13 21:04:03 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180813210240-#0813-g84465ef [Build #0813]
# Kodi version
Based on tip of
LibreELEC.tv master (84465ef,
- Includes latest addons: inputstream.adaptive (6bf7802, +2), inputstream.rtmp (0cc2da1, +1), peripheral.joystick (08e4a1a), peripheral.xarcade (07be227), pvr.argustv (1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313, +2), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (89cac8b), pvr.mythtv (e61f47c, +4), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0460536), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441, +2)
- Include [env] PR:2879 (perma): mesa: update to mesa-18.1.6
Build Highlights:
- mesa: update to mesa-18.1.6
Build Details:
- LibreELEC.tv:
- linux (Generic): update to linux-4.17.14 (PR:2838, 12 commits, 8 files changed)
- wpa_supplicant: Fix EAPOL vulnerability (PR:2873, 1 commit, 1 file changed)
- proftpd, net-snmp, openvpn: updates to recent version (PR:2871, 3 commits, 5 files changed)
- glibc: update to glibc-2.28 (PR:2862, 9 commits, 14 files changed)
- Amlogic/Rockchip: Fix build with glibc-2.28 (PR:2878, 1 commit, 1 file changed)
- inputstream.rtmp:
- [depends] openssl: build static (PR:40, 1 commit, 1 file changed)
Weekly Linux 4.18.0 build #0813x:
Generic
Packages disabled/not included:
text:
DVB Driver Addons
Spinelplus support
just for a short ping back: I tried with the two latest files you posted and without kernel option quiet. System hangs after:" loading Kernel ... OK"
and it crashes. I updated ubuntu kernel to 4.18 to see if it boots and it does
So I think we have to call it off for the moment.
Thank you very much for your great ideas.
New LibreELEC.tv Leia build #0814:
Generic
SHA256 Checksum:
8c4f37f38d7c6feb1fdf4d7ea5e3cb3b4f219f915f45e19c52cbfa8340a22af2
(Generic)
text:
# uname -a
Linux NUC 4.17.14 #1 SMP Tue Aug 14 21:04:09 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180814210250-#0814-gcee9ce7 [Build #0814]
# Kodi version
Based on tip of
LibreELEC.tv master (cee9ce7,
XBMC master (c8fef7d,
- Includes latest addons: inputstream.adaptive (430c440, +4), inputstream.rtmp (0cc2da1, +1), peripheral.joystick (08e4a1a), peripheral.xarcade (07be227), pvr.argustv (1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313, +2), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (89cac8b), pvr.mythtv (e61f47c, +4), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0460536), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441, +2)
- Include [env] PR:2837 (perma): linux (RPi): update to linux-4.14.62
- Include [env] PR:2881 (perma): busybox: update to busybox-1.29.2
- Include [env] PR:2882 (perma): xorg-server: update to xorg-server-1.20.1
- Include [env] PR:2884 (perma): samba: update to samba-4.8.4
- Include [env] PR:2885 (perma): nano: update to 2.9.8; .tar.xz package
Build Highlights:
- busybox: update to busybox-1.29.2
- xorg-server: update to xorg-server-1.20.1
- samba: update to samba-4.8.4 (various security fixes)
- nano: update to 2.9.8
- VideoPlayer: LinuxRendererGL fixes
Build Details:
- LibreELEC.tv:
- enable dynamic configuration of netconsole at runtime (PR:2867, 0 commits, 0 files changed)
- open-vm-tools: bump to stable-10.3.0 (PR:2876, 1 commit, 2 files changed)
- proftpd: bump rev (PR:2883, 1 commit, 2 files changed)
- XBMC:
- Fix for (external)player from playercorefactory.xml gets the default (PR:14291, 1 commit, 1 file changed)
- addondb: avoid constraint violation (PR:14137, 1 commit, 1 file changed)
- OSX: fix multi-monitor setups (PR:14282, 2 commits, 1 file changed)
- VideoPlayer: LinuxRendererGL fixes (PR:14295, 3 commits, 5 files changed)
- inputstream.adaptive:
- [TS] collect codec extra data for hevc (036f014)
- [DASH] throttle segment wait / fix adaptationset search for updates without id / group (430c440)
- Updated: [env] PR:2837 (perma): linux (RPi): update to linux-4.14.62
- Added: [env] PR:2881 (perma): busybox: update to busybox-1.29.2
- Added: [env] PR:2882 (perma): xorg-server: update to xorg-server-1.20.1
- Added: [env] PR:2884 (perma): samba: update to samba-4.8.4
- Added: [env] PR:2885 (perma): nano: update to 2.9.8; .tar.xz package
Terribly sorry if this has been covered before in the thread:
I have a Pentium Gold G5600 (Intel HD 630). Currently using a DP -> HDMI 2.0a active converter and 4K HDR videos play in Windows 10. I tried this build and 4K 60 videos play amazingly, however HDR videos don't work (video plays, but color is all wrong and TV doesn't switch to HDR mode). Has Intel not released linux drivers with HDR support?
