2017-03-15, 09:23
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355
2017-03-15, 23:59
New LibreELEC.tv Leia build #0315: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (1b38cb92, changelog) and tip of XBMC master (77f3bff1, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.2 #1 SMP Wed Mar 15 21:03:45 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170315210225-#0315-g1b38cb9 [Build #0315]
# Kodi version
(18.0-ALPHA1 Git:93e9d69). Platform: Linux x86 64-bit
- Includes latest kodi-platform master (36fb4937, ahead +1)
- Includes latest libcec master (8563411d, ahead +30)
- Includes latest libnfs master (d501dc8a, ahead +55)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (aa0d5113, +1), inputstream.rtmp (6c1af46a, +7), peripheral.joystick (0c47f0e1, +9), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (4b902cd1, +3), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (7bb31db9, +1)
- Include [env] 31a41616: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] 2447ac86: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: rapidjson: drop yajl, add rapidjson
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1431: scripts/mkimage: align partitions to 4MiB
- Include [env] PR:1433: v4l-utils: properly fix streamzap issues, allow user rc_maps.cfg override
- Include [env] PR:1438: v4l-utils: cleanup locally added keymaps, remove crime against rc6_mce
- Include [env] PR:1450: create_addon: add device support
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- libcec updates
- XBMC:
- [PVR] Fix trac17374: Settings deinitialized too early on app exit. (PR:11849, 1 commit, 3 files changed)
- libcec:
- added: log a warning when we detect that RPi's CEC service is used by something else, blocking libCEC. issue #191 (5469da23)
- changed: const IAdapterCommunication::GetLogicalAddresses(), making the mutex mutable for now without changing the platform lib. closes #259 (0cf3f0fe)
- fixed: cross compile includes (50f1179d)
- fixed: detect debian based distros properly when installing python. closes #314 (f4e2ed77)
- fixed: don't filter out broadcast in HandleDeviceVendorCommandWithId(). issue #309 (e1df683b)
- fixed: send an active source message when a routing change has been received with libCEC's address as new route and no active source message has been sent yet. issue #309 #205 #233 (67d444dd)
- fixed 67d444dd944192a31ab07637a4b57d27c890ede4 (d1a708b9)
- fixed: vs2015 c++ redistributables (8563411d)
- Added: [env] PR:1450: create_addon: add device support
2017-03-16, 15:01
I receive "TVheadendserver not reachable" ... since #0314 and #0315
nothing changed just updated from #0313
http://sprunge.us/cbYE
2017-03-16, 16:45
@peram1 did you update your tvheadend add-on (see link in #0314 changelog).
2017-03-16, 18:04
2017-03-17, 00:10
New LibreELEC.tv Leia build #0316: Generic
Based on tip of LibreELEC.tv master (1b38cb92, changelog) and tip of XBMC master (25de4115, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.2 #1 SMP Thu Mar 16 21:11:06 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170316210756-#0316-g1b38cb9 [Build #0316]
# Kodi version
- Python error (eg. plugin.video.youtube) caused by PR11814 - notified on github
- XBMC:
- [win] use 64-bit toolset if available (PR:11845, 1 commit, 5 files changed)
- RenderManager: Force frames to output when reconfiguring renderer (PR:11855, 1 commit, 1 file changed)
- [bluray] Improve Blu-ray playback (PR:11836, 10 commits, 8 files changed)
- Fix allocation of 0-length array (PR:11814, 3 commits, 2 files changed)
2017-03-17, 23:52
@Milhouse:
It may sound a little spoiled but I just wanted to let you know.
I found that starting with build #0117 the network speed from my realtek pcie gbe family controller drops from over 100MBs in build #116 to 60MBs max. in #117 and later.
This happens when I copy a large testfile from the Libreelec PC to a windows PC. When I do it the other way around (copy a file from the Windows PC to the Libreelec PC) the speed is oke (over 100MBs).
2017-03-18, 00:19
(2017-03-17, 23:52)rudrood Wrote: [ -> ]@Milhouse:
Interesting, thanks for the report. Do you see any difference between #0117 and #0124?
2017-03-18, 00:38
Thanks for your reply.
No, tested almost every build later then #116 to find when it started, but all of them perform the same.
2017-03-18, 00:48
New LibreELEC.tv Leia build #0317: Generic
Based on tip of LibreELEC.tv master (c8e19e71, changelog) and tip of XBMC master (19f6b582, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.3 #1 SMP Fri Mar 17 22:05:36 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170317220322-#0317-gc8e19e7 [Build #0317]
# Kodi version
- Includes latest addons: inputstream.adaptive (aa0d5113, +1), inputstream.rtmp (6c1af46a, +7), peripheral.joystick (0c47f0e1, +9), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (bdc48989, +4), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (7bb31db9, +1)
- Include [env] compare: linux: update to linux-4.10.3
- Include [env] PR:1452: Package updates
- Include [pkg] PR:11860: Fix for YouTube Add-On Crash
- New 4.10.3 kernel
- Package updates
- Fix youtube and other Python add-on startup errors
- LibreELEC.tv:
- create_addon: add device support (PR:1450, 1 commit, 1 file changed)
- v4l-utils: properly fix streamzap issues, allow user rc_maps.cfg override (PR:1433, 2 commits, 4 files changed)
- v4l-utils: cleanup locally added keymaps, remove crime against rc6_mce (PR:1438, 2 commits, 9 files changed)
- port forward of #1446 (PR:1447, 2 commits, 3 files changed)
- XBMC:
- Use invoke-id instead addon-id for selecting the monitor for abortrequest (PR:11852, 1 commit, 7 files changed)
- [bluray] allow do build without bluray support (PR:11862, 1 commit, 1 file changed)
- [win] use users profile folder as home folder (PR:11857, 1 commit, 1 file changed)
- drop support for 'old' static listitem format (PR:11756, 1 commit, 1 file changed)
- [python] WindowXML - add param for mediawindow (PR:11766, 1 commit, 2 files changed)
- pvr.dvblink:
- pvr.dvblink (master) version 4.1.2 (PR:78, 1 commit, 3 files changed)
2017-03-19, 00:15
New LibreELEC.tv Leia build #0318: Generic
Based on tip of LibreELEC.tv master (c8e19e71, changelog) and tip of XBMC master (4912f8f8, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.4 #1 SMP Sat Mar 18 21:44:19 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170318212823-#0318-gc8e19e7 [Build #0318]
# Kodi version
- Include [env] PR:1455: linux: update to linux-4.10.4
- New 4.10.4 kernel
- Bluez: build deprecated tools (updated PR:1452)
2017-03-19, 23:26
Just to make sure I see no ghosts, the next thing is driving me crazy..
With the fresh installed Milhouse build I'm not able to open the LibreELEC Add-on repo (Team LibreELEC- 9.0.0) as it says "Could not connect to the repository).
Made a clean install on another spare laptop and now I'm able to enter the repo but when I try to install something from it nothing happens.
All other repo's work as expected, so it's not a network thing (even used different dns servers).
Is there something I could do/check to see where the problem is, or is this as expected?
2017-03-19, 23:27
(2017-03-19, 23:26)rudrood Wrote: [ -> ]Just to make sure I see no ghosts, the next thing is driving me crazy..
LibreELEC 9.0 repo hasn't been built yet
Hopefully soon.
2017-03-19, 23:49
New LibreELEC.tv Leia build #0319: Generic
Based on tip of LibreELEC.tv master (c8e19e71, changelog) and tip of XBMC master (26d4d140, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.4 #1 SMP Sun Mar 19 21:22:34 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170319212112-#0319-gc8e19e7 [Build #0319]
# Kodi version
- Include [pkg] PR:11873: [Fix]Default music artist separators remove colon and "|" (ticket 17401)
- [addons] Update Chorus
- [Fix]Default music artist separators remove colon and "|" (ticket 17401)
2017-03-20, 02:58
(2017-03-19, 23:27)lrusak Wrote: [ -> ](2017-03-19, 23:26)rudrood Wrote: [ -> ]Just to make sure I see no ghosts, the next thing is driving me crazy..
Hopefully soon.
