New LibreELEC.tv Leia build #1229:
Generic
(Supercedes previous build)
SHA256 Checksum:
625fe3e58f68ff40969379ba314780e98838e087fa85d13effdc275fa93c79a7
(Generic)
text:
# uname -a
Linux NUC 4.19.13 #1 SMP Sat Dec 29 21:04:37 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181229210312-#1229-ga98586b [Build #1229]
# Kodi version
(18.0-RC5 Git:85486a2). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a98586b,
changelog) and tip of
XBMC master (85486a2,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (9e63589, ahead +15)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (d35dfcd), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (42a9a4b), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (1956113), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (ec29899), pvr.wmc (2697409), pvr.zattoo (d44651f), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3156 (perma): web: update to libmicrohttpd-0.9.61/curl-7.62.0
- Include [env] PR:3164 (perma): ffmpegx: disable nonfree
- Include [env] PR:3179 (perma): libshairplay: update to 096b61a
- Include [env] PR:3183 (perma): image: add PROJECT to /etc/os-release
- Include [env] PR:3191 (perma): kodi: service addon wrapper call fix
- Include [env] PR:3192 (perma): ncurses: improvements / sytem-tools 110: update mc and efibootmgr
- Include [env] PR:3193 (perma): v4l-utils: simplify 70-infrared.rules and fix kernel 4.20 issues
- Include [env] PR:3196 (perma): linux (RPi/Generic): update to linux-4.19.13
- Include [pkg] PR:111 (perma): stats improvements (service.libreelec.settings)
- Include [pkg] PR:112 (perma): reorganize about section (service.libreelec.settings)
- Include [pkg] PR:113 (perma): avoid truncating of version number (service.libreelec.settings)
- Include [pkg] PR:114 (perma): update translations from transifex (service.libreelec.settings)
- Include [pkg] PR:115 (perma): cleanup (service.libreelec.settings)
- Include [pkg] PR:14924 (perma): [games] Fix crash in PCSX ReARMed with BIOS
- Include [pkg] PR:15016 (perma): Resolution: Don't add half refreshrates by default
- Include [pkg] PR:15102 (perma): [airtunes/linux] - fix airtunes/shairplay not working on linux
- Include [pkg] PR:15156 (perma): [JSON]Add OnRefresh announcement to the schema
Build Highlights:
- New 4.19.13 kernel
- kodi-18.0rc5-Leia
- Kodi: [airtunes/linux] - fix airtunes/shairplay not working on linux
- Kodi: [JSON]Add OnRefresh announcement to the schema
- libnfs: add nfs_umount() which will unregister the client from the mount daemon
- Settings addon: update translations from transifex (service.libreelec.settings)
- Settings addon: cleanup (service.libreelec.settings)
Build Details:
- LibreELEC.tv:
- kodi (RPi/Generic/Rockchip): update to kodi-18.0rc4-Leia (PR:3195, 5 commits, 7 files changed)
- tigervnc: update to 1.9.0 (PR:3189, 2 commits, 3 files changed)
- dotnet-runtime: update to 2.2.0 (PR:3188, 1 commit, 2 files changed)
- libjpeg-turbo: bump version/switch to cmake; fix host cmake (PR:3187, 3 commits, 3 files changed)
- glib: remove function that could not possibly be used (PR:3186, 1 commit, 1 file changed)
- buildsystem: centralise package sourcing (PR:3171, 20 commits, 47 files changed)
- XBMC:
- [keymaps] Specify that gamepad.xml is for EventServer "gamepads" (PR:15138, 1 commit, 1 file changed)
- bump to v18.0 rc5 (PR:15152, 1 commit, 1 file changed)
- libnfs:
- add nfs_umount() which will unregister the client from the mount daemon (9e63589)
- Updated: [env] PR:3164 (perma): ffmpegx: disable nonfree
- Updated: [env] PR:3192 (perma): ncurses: improvements / sytem-tools 110: update mc and efibootmgr
- Added: [env] PR:3196 (perma): linux (RPi/Generic): update to linux-4.19.13
- Added: [pkg] PR:114 (perma): update translations from transifex (service.libreelec.settings)
- Added: [pkg] PR:115 (perma): cleanup (service.libreelec.settings)
- Added: [pkg] PR:15102 (perma): [airtunes/linux] - fix airtunes/shairplay not working on linux
- Added: [pkg] PR:15156 (perma): [JSON]Add OnRefresh announcement to the schema
If somebody experiences the same interpolation/scaling issue (with Lanczos3/Spline36) as explained
here on Apollo Lake hardware, this can be fixed by setting 'MESA_GL_VERSION_OVERRIDE=(<4.0)' before starting KODI.
So, now I'm able to use 'Video scaling method: Auto' again, without a distorted picture on lower resolution videos.
(2018-12-30, 05:51)epias Wrote: [ -> ]If somebody experiences the same interpolation/scaling issue (with Lanczos3/Spline36) as explained here on Apollo Lake hardware, this can be fixed by setting 'MESA_GL_VERSION_OVERRIDE=(<4.0)' before starting KODI.
About 2 months ago (since #1028) you can now add that kind of setting to
/storage/.config/kodi.conf
and it should work.
I think this was fixed already, the shader was just not reinited after refreshrate switched. Do you have a sample for easy reproducing? Can you still reproduce it?
New LibreELEC.tv Leia build #1230:
Generic
SHA256 Checksum:
308a879fd6bbd5f012bf848d2678527affbe3e0afba27efbc14df946c9121e7e
(Generic)
text:
# uname -a
Linux NUC 4.19.13 #1 SMP Sun Dec 30 21:04:32 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181230210312-#1230-g41d2c65 [Build #1230]
# Kodi version
(18.0-RC5 Git:8dfb253). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (41d2c65,
XBMC master (8dfb253,
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (b6a5202, +2), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (322f47d, +2), pvr.nextpvr (42a9a4b), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (1956113), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (ec29899), pvr.wmc (2697409), pvr.zattoo (d44651f), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] PR:3197 (perma): cmake: update to cmake-3.13.2
- Include [env] PR:3199 (perma): pkgcheck: add new script
- Include [env] PR:3202 (perma): busybox: update to busybox-1.30.0
- Include [pkg] PR:117 (perma): improve wording of Thank You page (service.libreelec.settings)
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
Build Highlights:
- cmake-3.13.2, busybox-1.30.0
- TexturePacker: Fix memory / resource leak the ugly way
Build Details:
- LibreELEC.tv:
- image: add PROJECT to /etc/os-release (PR:3183, 1 commit, 1 file changed)
- mariadb: initial addon (PR:3190, 1 commit, 11 files changed)
- XBMC:
- [JSON]Add OnRefresh announcement to the schema (PR:15156, 1 commit, 2 files changed)
- Redact URL in CUtil::ExcludeFileOrFolder (PR:15162, 1 commit, 1 file changed)
- pvr.hts:
- Add support for recent tvheadend 4.3 image URL changes (HTSP v34) (PR:391, 2 commits, 5 files changed)
- pvr.mythtv:
- add the implicit marks for begin or end (b83fb4c)
- bump version 5.10.3 (322f47d)
- Added: [env] PR:3197 (perma): cmake: update to cmake-3.13.2
- Added: [env] PR:3199 (perma): pkgcheck: add new script
- Added: [env] PR:3202 (perma): busybox: update to busybox-1.30.0
- Updated: [pkg] PR:111 (perma): stats improvements (service.libreelec.settings)
- Added: [pkg] PR:117 (perma): improve wording of Thank You page (service.libreelec.settings)
- Added: [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
New LibreELEC.tv Leia build #1231:
Generic
SHA256 Checksum:
0d77ea9e8d68f6eef5cae07c9cf22da45427e14c0fa79dcfac2bfdeb93d6ffeb
(Generic)
text:
# uname -a
Linux NUC 4.19.13 #1 SMP Mon Dec 31 21:04:25 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181231210249-#1231-g05be03f [Build #1231]
# Kodi version
Based on tip of
LibreELEC.tv master (05be03f,
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (b6a5202), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (322f47d), pvr.nextpvr (42a9a4b), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (1956113), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (ec29899), pvr.wmc (2697409), pvr.zattoo (d44651f), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- kodi-binary-addons: update to latest versions (PR:3203, 1 commit, 63 files changed)
- crazycat_aml: change description (PR:3201, 1 commit, 1 file changed)
- web: update to libmicrohttpd-0.9.61/curl-7.62.0 (PR:3156, 3 commits, 3 files changed)
- cmake: update to cmake-3.13.2 (PR:3197, 1 commit, 1 file changed)
- LibreELEC-settings: update to 05bfa87 (PR:3204, 1 commit, 1 file changed)
- pkgcheck: add new script (PR:3199, 7 commits, 14 files changed)
- v4l-utils: simplify 70-infrared.rules and fix kernel 4.20 issues (PR:3193, 1 commit, 1 file changed)
- ncurses: improvements / system-tools 110: update mc and efibootmgr (PR:3192, 4 commits, 15 files changed)
- addons: bump sapphire driver to v7.1 (PR:3205, 1 commit, 1 file changed)
Happy new year everyone - thanks for all the support with testing, bug reports, feedback and fixes over the last 12 months.
I hope 2019 is an excellent year for you all!
Happy New Year to you, and many thanks for all that you do for the Kodi community!
Thanks everyone, new year, new kodi!
Happy new year @
Milhouse and the rest of the team!🍾
A happy new year to everyone here.
I have a bug that I have to report.
Lately I got a new HTPC using NUC7PJYH Pentium J5005.
It works well with your Testbuilds but I have a problem waking up my fileserver.
If I enable Wake servers in the settings page of LE, the NUC crashes when starting it and I end up in Safe Mode.
I just checked with 1231 testbuild. The problem still persists.
So I have created the log files
here
TIA
Umtauscher
Using the WOL Plugin works btw.
But as I am using a centralized mysql database, waking the server by the plugin is too late because LE won't start if the server is not awake.
New LibreELEC.tv Leia build #0101:
Generic
SHA256 Checksum:
25033bc54d8fd533a0794b2a9ca6a51c951ad3f28c98ee64c23be08d41500717
(Generic)
text:
# uname -a
Linux NUC 4.19.13 #1 SMP Tue Jan 1 21:17:56 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190101211246-#0101-g05be03f [Build #0101]
# Kodi version
(18.0-RC5 Git:a0ce24a). Platform: Linux x86 64-bit
Based on tip of
XBMC master (a0ce24a,
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (3e1eae0, +1), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8a9d821, +1), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (322f47d), pvr.nextpvr (7c2eb5d, +1), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (1956113), pvr.vbox (ea20464, +1), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (185b311, +1), pvr.wmc (2697409), pvr.zattoo (d44651f), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] PR:3209 (perma): zstd: update to 1.3.8
Build Highlights:
- zstd: update to 1.3.8
- PVRClient: Do not overwrite arbitrary memory fixes #15157
- RendererVDPAU: Do not use memset on non-trivial type
Build Details:
- XBMC:
- PVRClient: Do not overwrite arbitrary memory fixes #15157 (PR:15168, 1 commit, 1 file changed)
- RendererVDPAU: Do not use memset on non-trivial type (PR:15161, 1 commit, 1 file changed)
- Revert "FIX: [droid] translate to ascii for sorting" (PR:15176, 1 commit, 3 files changed)
- [lang][skin.estuary] updated language files from Transifex (44c643f)
- pvr.dvbviewer:
- [lang] updated language files from Transifex (3e1eae0)
- pvr.hts:
- [lang] updated language files from Transifex (8a9d821)
- pvr.nextpvr:
- More incremental bugfixes for seeking, GetStreamTimes() changes (PR:78, 1 commit, 6 files changed)
- pvr.vbox:
- [lang] updated language files from Transifex (ea20464)
- pvr.vuplus:
- [lang] updated language files from Transifex (185b311)
- Added: [env] PR:3209 (perma): zstd: update to 1.3.8
New LibreELEC.tv Leia build #0102:
Generic
SHA256 Checksum:
57e7a24a8ea0d7e34f70f0ba814a264a995c5aac90c067779c1a7a911385aaed
(Generic)
text:
# uname -a
Linux NUC 4.19.13 #1 SMP Wed Jan 2 21:04:22 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190102210301-#0102-g05be03f [Build #0102]
# Kodi version
(18.0-RC5 Git:195fd1c). Platform: Linux x86 64-bit
Based on tip of
XBMC master (195fd1c,
Build Highlights:
- [skin] Bump GUI ABI to 5.14.0
Build Details:
- XBMC:
- Update FileItem state on external player closing (PR:15126, 1 commit, 1 file changed)
- [skin] Bump GUI ABI to 5.14.0 (PR:14933, 1 commit, 1 file changed)
- Fix *All Albums item removed by Coverity fix (PR:15155, 1 commit, 1 file changed)
- [guiinfo] Fix Player.Duration / Musicplayer.Duration time format para (PR:15184, 1 commit, 1 file changed)
