A question about audio encoders..
I would like to use my system for some audio ripping but only 2 audio encoders are showing up, AAC and WMA. I know these are binary addons (or at least I believe they are) how would one get the other encoders installed? I have updated to version 0622.
Do I need to revert to the stable version?
Thanks...
(2017-06-26, 01:23)giftie Wrote: [ -> ]Do I need to revert to the stable version?
Yes. Other binary addons would be installed from the LibreELEC repository but there's no point trying to build those while the addon infrastructure changes continue to roll on. If you want to use binary addons (more than those included in these builds) then stick with a stable release, or a test version prior to these add-on changes (about #0530).
I have some issues with my NUC NUC6CAYH and my Logitech Harmony 300.
Sometimes, the Harmony isn't working. After some restarts, she works again.
Is there something new in the Testbuilds? There are no Problems with LE 8.0.2.
(2017-06-26, 21:21)dirtydesaster Wrote: [ -> ]I have some issues with my NUC NUC6CAYH and my Logitech Harmony 300.
Try disabling LIRC in LE Settings addon. The way LIRC is handled in these builds is totally different to LE 8.0.2. Please provide "journalctl -a | pastebinit" and your kodi debug log if you continue to experience problems. There is a fairly significant LIRC updated in tonight's build (#0626).
New LibreELEC.tv Leia build #0626:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.11.7 #1 SMP Mon Jun 26 21:08:05 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170626210643-#0626-g7710554 [Build #0626]
# Kodi version
(18.0-ALPHA1 Git:423072a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (77105540,
changelog) and tip of
XBMC master (eea53e61,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (12a27fd8, ahead +114)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (a1d37ac5), inputstream.rtmp (6db3697a), peripheral.joystick (f5538d25, +1), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (a5db9ddb), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (2651886f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (fbb7e561), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (9bbd7cf3), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (40dc17d0), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
- Include [env] compare: kodi18a1 latest updates
- Include [env] compare: linux: update to linux-4.11.7
- Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.4
- Include [env] PR:1690: Enable -fPIC for some packages
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
- Include [pkg] PR:352: Fix: set wrong variable (libcec)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12345: [fix][Take II] Nuke 'libpng warning: iCCP: known incorrect sRGB profile' warnings and optimize images
Build Highlights:
- New 4.11.7 kernel
- Bump to 3.3.2-Leia-Alpha-1 (in kodi18a1 latest updates)
- [peripheral] change addon interface to new C++ style
- Drop inputstream.rtmp until it is compatible with latest Kodi master
- PR:1726: [WIP] lirc: update to 0.10.0
- Updated Intel microcode to fix broken Hyperthreading on Skylake/Kaby Lake
Build Details:
- LibreELEC.tv:
- fuse: don't run /usr/sbin/update-rc.d on install (PR:1718, 1 commit, 1 file changed)
- openssl: update to openssl-1.0.2l (PR:1713, 1 commit, 1 file changed)
- spotify-connect-web: remove addon (PR:1721, 1 commit, 9 files changed)
- activate swap for all projects (PR:1717, 2 commits, 8 files changed)
- mpd: update to 0.20.9 (PR:1722, 1 commit, 2 files changed)
- tvheadend42: update to 4.2.2-75 (PR:1724, 1 commit, 2 files changed)
- librespot: initial addon (PR:1676, 5 commits, 15 files changed)
- intel-ucode: update to 20170511 (PR:1729, 1 commit, 1 file changed)
- XBMC:
- FIX: [amc] proper VP6 mime (fixes #17511) (PR:12349, 1 commit, 1 file changed)
- [cleanup] Remove HAS_VIDEO_PLAYBACK nonsense. (PR:12346, 1 commit, 8 files changed)
- [settings] add "masking" to "path" type (PR:12348, 1 commit, 1 file changed)
- [peripheral] change addon interface to new C++ style (PR:12333, 3 commits, 25 files changed)
- [depends] - fixes for tvos (PR:12355, 2 commits, 3 files changed)
- FFmpeg: Bump to 3.3.2-Leia-Alpha-1 (PR:12358, 1 commit, 1 file changed)
- [ios/ios64] - bump xcode and sdk to fix ios64 compilation (PR:12298, 3 commits, 1 file changed)
- Fix MakeShortenPath (PR:12359, 1 commit, 2 files changed)
- apple: code cosmetics, remove white spaces (PR:12364, 1 commit, 19 files changed)
- [addons/settings] fix loading scraper settings from the database (PR:12360, 2 commits, 3 files changed)
- start killing PlatformDefs (PR:12353, 4 commits, 29 files changed)
- Avoid incorrectly matching years in mini-series titles during TV enumeration matching (PR:12344, 1 commit, 1 file changed)
- [GUI] Optimize InfoBools / additions / fixes for gui:martredraw (PR12213) (0de583a5)
- Addonvideocodec Implementation (#12340) (66233da3)
- inputstream.adaptive:
- peripheral.joystick:
- Change to new C++ based addon interface style (PR:112, 1 commit, 61 files changed)
- Added: [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Added: [env] PR:1726: [WIP] lirc: update to 0.10.0
Since around build #530 i have problems with my remote and power management functions.
If i want to force power off within the powermenu in kodi or power off the system with remote (imon hid and harmony remote), i get a deadlock situation and my system stops responding.
So i have to force a reboot or power off with ssh.
Is there something more i could do to get any hints (
Debug Log or anything else)?
Many thanks
debutanker
(2017-06-27, 02:58)debutanker Wrote: [ -> ]Since around build #530 i have problems with my remote and power management functions.
Is there something more i could do to get any hints (Debug Log or anything else)?
Many thanks
debutanker
Does this start with #0606? Could be the dropped SIGTERM patch. Currently no time to investigate alternative or updated patch.
(2017-06-23, 10:31)Milhouse Wrote: [ -> ]@E92M3 you haven't answered:
(2017-06-21, 10:16)Milhouse Wrote: [ -> ]Are you trying to access shares on an LE samba server or some other server? Which server on your network is your master browser and does it support NT1? Is your default network workgroup "WORKGROUP" or something else? Have you tried forcing SMB1 in the Kodi Settings > Samba?
At the moment I can only imagine your Samba server doesn't "speak" SMB2+ reliably so you should force SMB1 (NT1) in the Kodi Samba settings.
I'm trying to access non-public shares on a Windows 7 X64 box which is part of "workgroup" I can manually add the shares and it connects OK, but it will not browse and only lists ".." to a higher directory, basically it doesn't see the workgroup.
8.0.2 lists properly and browses the shares without issue, I went back to the first test build here and it doesn't work, nor the latest.
(2017-06-27, 03:53)Milhouse Wrote: [ -> ]Does this start with #0606? Could be the dropped SIGTERM patch. Currently no time to investigate alternative or updated patch.
Many thanks for your reply!
Yes, problem started with #0606.
So i had to stay on #0605 till there will be an alternative.
There is a problem with test builds,
Where visualization window hides played video and stays on until it's cancelled manually,
when playing playlist with several videos and kodi automatically switches to the next video in TS container
For test I've used following samples from kodi samples page:
MPEG2_1080i_sample.mkv
Samsung_UHD_Dubai.ts
to reproduce:
1. put files in directory and select from context menu on directory "Play" action
2. wait till MPEG2_1080i_sample.mkv is played and Samsung_UHD_Dubai.ts is played automatically
result:
played video is hidden by MusicVisualisation window
expected result:
played video visible on screen (VideoFullScreen window)
debug log:
https://pastebin.com/xvGtxD2K
look for: MusicVisualisation.xml in the log
additional notes:
* TS file is played as expected if playlist overlay window is open during playback of the first file and then TS file played automatically
or TS file is picked in Files and played manually
* if ESC is pressed while MusicVisualisation window is visible, visualization is closed and videos in playlist are played as expected until another TS file is met
* files are on NFS server
* now running #0626 but bug also happened with earlier versions
New LibreELEC.tv Leia build #0627:
Generic
# uname -a
Linux NUC 4.11.7 #1 SMP Tue Jun 27 21:05:23 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170627210400-#0627-g1196fc5 [Build #0627]
# Kodi version
Based on tip of
LibreELEC.tv master (1196fc52,
XBMC master (e940fa16,
Build Highlights:
- [vfs] change addon interface to new C++ style
Build Details:
- LibreELEC.tv:
- system-tools: bump p7zip and unrar (PR:1731, 3 commits, 4 files changed)
- XBMC:
- [network] fix CID 1364572 - ensure we're not leaking the ipv6 test socket (PR:12337, 1 commit, 1 file changed)
- [cleanup] Remove HAS_FILESYSTEM (PR:12350, 1 commit, 4 files changed)
- Nuke u16string and u32string own implementation (PR:12293, 2 commits, 4 files changed)
- [fix][Take II] Nuke 'libpng warning: iCCP: known incorrect sRGB profile' warnings and optimize images (PR:12345, 37 commits, 1207 files changed)
- Rework OS screen saver handling (PR:12342, 10 commits, 20 files changed)
- [cleanup] Cleanup system.h unused defines (PR:12347, 1 commit, 1 file changed)
- [vfs] change addon interface to new C++ style (PR:12356, 1 commit, 18 files changed)
- [fix][pictures] CID 77607: prevent buffer overflow (PR:12369, 1 commit, 1 file changed)
- DBus refactoring (PR:12371, 13 commits, 16 files changed)
Here is a kodi debug log when I try and browse for SMB shares from LE to W7. I can manually type in the smb share and it connects, but browsing just lists ".." - nothing.
Here is the debug log:
http://sprunge.us/HDHT
Hope this has some information that can be used to troubleshoot. This is a clean install of 8.0.2 and then upgrade to latest test build.
@E92M3:
On the LibreELEC client, run:
systemctl stop nmbd
nmbd -iFd3 >/tmp/log
Wait 30 seconds, then...
cat /tmp/log | pastebinit
systemctl stop nmbd
Then paste the link. What is the IP address of your Windows 7 PC?
Issue still exists,.
Quote:################ SYSTEM INFO ################
Date: Wed Jun 28 12:58:13 IST 2017
kodi Options: --standalone -fs --lircdev /run/lirc/lircd
Arch: x86_64
Kernel: Linux 4.11.7 #1 SMP Tue Jun 27 21:05:23 BST 2017
Release: LibreELEC devel-20170627210400-#0627-g1196fc5
############## END SYSTEM INFO ##############
Crashing on boot,
Crashlog ends with the following
Quote:12:58:10.048 T:140426958853888 DEBUG: CAddonSettings[weather.yahoo]: trying to load setting definitions from old format...
12:58:10.048 T:140426958853888 DEBUG: CAddonSettings[weather.yahoo]: loading setting values
12:58:10.048 T:140426958853888 DEBUG: weather.yahoo: weather location: 560743
12:58:10.404 T:140427730589440 DEBUG: Library Data Provider: script version 0.3.0 stopped
12:58:10.404 T:140427730589440 INFO: CPythonInvoker(8, /storage/.kodi/addons/service.library.data.provider/plugin.py): script successfully run
12:58:10.516 T:140427730589440 INFO: Python script stopped
12:58:10.516 T:140427730589440 DEBUG: Thread LanguageInvoker 140427730589440 terminating
12:58:10.516 T:140428152055552 DEBUG: Skin Helper Simplecache --> Initialized
12:58:10.838 T:140427361507072 DEBUG: Previous line repeats 1 times.
12:58:10.838 T:140427361507072 DEBUG: CAddonSettings[script.skinshortcuts]: loading setting definitions
12:58:10.838 T:140427361507072 DEBUG: CAddonSettings[script.skinshortcuts]: trying to load setting definitions from old format...
12:58:10.933 T:140427378292480 INFO: Python script stopped
12:58:10.934 T:140427378292480 DEBUG: Thread LanguageInvoker 140427378292480 terminating
12:58:10.936 T:140426833204992 DEBUG: CAddonSettings[service.vpn.manager]: loading setting definitions
12:58:10.936 T:140426833204992 DEBUG: CAddonSettings[service.vpn.manager]: trying to load setting definitions from old format...
############### END LOG FILE ################
############ END kodi CRASH LOG #############
Remote connect to device, delete service.vpn.manager from /addons and /userdata/addon_data
Device loads correctly, message saying version 20170627 successfully installed or somesuch.
Try again to download and install vpnmanager and kodi.bin crashes.
Do I have to contact the developer of this addon see if they'll be able to correct whatever it is that's causing the issue, or is this still something to be fixed this end?
