Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
New LibreELEC.tv Leia build #0430: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.13 #1 SMP Sun Apr 30 22:12:21 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170430221059-#0430-ge0d8fd7 [Build #0430]
# Kodi version
(18.0-ALPHA1 Git:91a9066). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (e0d8fd7b, changelog) and tip of XBMC master (27a989ee, changelog) with the following modifications:
  • Includes latest kodi-platform master (36fb4937)
  • Includes latest libcec master (3953f8dc, ahead +12)
  • Includes latest libnfs master (1052ba94, ahead +58)
  • Includes latest p8-platform master (2d90f986)
  • Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (28350d6e, +3), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (8549a31c), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
  • Exclude [env] ffmpeg-99.1010-tls-1.2.patch: upstream ffmpeg-3.3
  • Include [env] compare: tvheadend42: update (pngquant)
  • Include [env] compare: linux: update to linux-4.10.13
  • Include [env] patch: vfs addons: add vfs.rar, vfs.sacd and vfs.sftp kodi-binary-addons
  • Include [env] patch: imagedecoder.raw: update imagedecoder.raw
  • Include [env] patch: screensaver.shadertoy: bump screensaver.shadertoy to 434f5ce
  • Include [env] patch: visualization.projectm: bump visualization.projectm to 7489e4a
  • Include [env] patch: visualization.shadertoy: bump visualization.shadertoy to ae677ac
  • Include [env] patch: ffmpeg: update to ffmpeg-3.3
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
  • Include [env] PR:1469: samba: update to samba-4.6.2
  • Include [pkg] PR:2: Update b43 firmware (wlan-firmware)
  • Include [pkg] PR:7: Remove not used part (pvr.octonet)
  • Include [pkg] PR:8: libXBMC_codec.h removed and changed to libXBMC_pvr.h also fix compile fault after last request (pvr.octonet)
  • Include [pkg] PR:24: Remove not used part (inputstream.adaptive)
  • Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
  • Include [pkg] PR:65: update language from transifex (service.libreelec.settings)
  • Include [pkg] PR:72: Remove not used part (pvr.mythtv)
  • Include [pkg] PR:73: libXBMC_codec.h removed and changed to libXBMC_pvr.h (pvr.mythtv)
  • Include [pkg] PR:12034: KODI: Update NEON support
  • Include [pkg] PR:12037: [fix] guilib versions after pull/12011
Build Highlights:
  1. Restore pvr.mythtv add-on, switch to janbar repo
  2. Fix for guilib version - does this resolve "incompatible" addon issues?
Build Details:
  1. LibreELEC.tv:
    • kodi: bump kodi and binary add-ons to current (PR:1567, 4 commits, 16 files changed)
    • dtc: change url and use correct file type (PR:1575, 1 commit, 1 file changed)
    • kernel-firmware: change url and use correct file type (PR:1577, 1 commit, 1 file changed)
    • createlog: bring sanity to kodi log order (PR:1571, 1 commit, 1 file changed)
    • pvr.mythtv: change url, bump to 8db66ca (5.10.0) (PR:1580, 1 commit, 1 file changed)
    • packages/linux-drivers/gpu-aml: Use RFC date in version string (PR:1558, 1 commit, 1 file changed)
  2. XBMC:
    • [settings] change spinners to list for media/video (PR:12036, 1 commit, 1 file changed)
    • Application: Remove unused dirtyRegions variable (#12030) (3b4ccd89)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: screensaver.shadertoy: bump screensaver.shadertoy to 434f5ce
    • Added: [env] patch: visualization.projectm: bump visualization.projectm to 7489e4a
    • Added: [env] patch: visualization.shadertoy: bump visualization.shadertoy to ae677ac
    • Added: [pkg] PR:72: Remove not used part (pvr.mythtv)
    • Added: [pkg] PR:73: libXBMC_codec.h removed and changed to libXBMC_pvr.h (pvr.mythtv)
    • Added: [pkg] PR:12034: KODI: Update NEON support
    • Added: [pkg] PR:12037: [fix] guilib versions after pull/12011
Tomorrow I'll try to install.
(2017-04-30, 16:38)sboa Wrote: [ -> ]2. Update 4.11-rc8: http://forum.kodi.tv/showthread.php?tid=...pid2576062 - black screen, samba yes
3. install
4. Update 4.11-rc7: http://forum.kodi.tv/showthread.php?tid=...pid2573242 - black screen, samba yes
5. install
6. Update 4.11-rc6: http://forum.kodi.tv/showthread.php?tid=...pid2567575 - black screen, samba yes
The #0410x (4.11-rc6 kernel) build pre-dates the changes introduced in the #0418 (4.10.11 kernel) build which is when your system stopped working. It's possible changes in 4.11-rc6 have been backported to 4.10.11, and these changes have somehow broken your HDMI, but I'd expect this to be more widespread so that seems a little unlikely.
In addition, the 4.11-rc6 and 4.11-rc7 builds lack the media_build package that we bumped in 4.10.11 (and included in .4.11-rc8), so we can rule out the media_build package.
However Kodi (and Xorg) can't find a valid display, so Kodi fails with:
14:07:54.271 T:139709900728384 WARNING: CXRandR::Query - output HDMI1 has no current mode, assuming disconnected
Are you performing clean installs each time you install one of these test builds (ie. install LibreELEC 8.0.1 from disk image, then upgrade using a test build tar)? To be honest this shouldn't be necessary, but would ensure you are working from a known starting point.
Have you changed any BIOS configuration recently, or changed your hardware configuration in any way? Maybe try a different HDMI cable?
Other than a clean installation I don't know what else to suggest...
(2017-04-30, 20:39)HiassofT Wrote: [ -> ]
(2017-04-30, 18:25)swaggerwocky Wrote: [ -> ]I'm about 99% sure that the 4/07 build's lirc code cleanup has broken something with my Zotac CI520's media remote functionality. I find myself having to reboot the system once or twice to get it working. I've reverted back to 4/06 after trying several newer builds (haven't updated in awhile).
Please post logfiles when this happens:
dmesg | paste
journalctl -a | paste
systemctl status lircd.service | paste
ir-keytable | paste
Without the logfiles we won't be able to help you.
so long,
Hias
Cheers!
http://sprunge.us/FQgW
http://sprunge.us/QQLC
http://sprunge.us/IBGe
http://sprunge.us/EgeE
(2017-05-01, 00:26)sboa Wrote: [ -> ]Tomorrow I'll try to install.
log Sad
I get the Geforce 210 everything works and is updated
....."Fix for guilib version - does this resolve "incompatible" addon issues?"....
Yes - many thanks!
(2017-05-01, 06:05)swaggerwocky Wrote: [ -> ]Cheers!
Thanks for the logs! Please disable Lirc in LibreELEC settings, I'm quite sure this is causing your issues.
so long,
Hias
New LibreELEC.tv Leia build #0501: Generic
# uname -a
Linux NUC 4.10.13 #1 SMP Mon May 1 21:05:04 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170501210342-#0501-g33a82f9 [Build #0501]
# Kodi version
Based on tip of LibreELEC.tv master (33a82f91, changelog) and tip of XBMC master (3d14131d, changelog) with the following modifications:
  • Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (28350d6e, +3), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (8549a31c), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
  • Include [env] PR:1582: tvheadend42: update addon
Build Highlights:
  1. Minors
Build Details:
  1. LibreELEC.tv:
    • pvr.vdr.vnsi: change url, bump version (PR:1583, 1 commit, 1 file changed)
  2. XBMC:
    • [fix] guilib versions after pull/12011 (PR:12037, 1 commit, 2 files changed)
    • [buildsteps][windows] fix BuildSetup.bat after 0a14316 (#12031) (PR:12041, 1 commit, 1 file changed)
    • [PVR] pvr windows cleanup and refactoring of class hierarchy (PR:12042, 2 commits, 21 files changed)
    • [guilib] Isolate included expressions $EXP (PR:12012, 1 commit, 1 file changed)
    • [tests][windows] TestSystemInfo.GetDiskSpace: use correct overload of std:Confusedtring::assign (PR:12045, 1 commit, 1 file changed)
    • Added: [env] PR:1582: tvheadend42: update addon
Weekly Linux 4.11.0 (FINAL) build #0501x: Generic
Same as #0501 but without the xf86-video-nvidia 375.39 driver which can't be updated for legal reasons (incompatible license). This build DOES include the xf86-video-nvidia-legacy 340.102 driver.
I'm not yet cutting over to 4.11.0 for regular builds while it is not possible to build a common kernel for RPi/RPi2/Generic. Once Nvidia push an updated 375.xx driver I'll make the switch.
(2017-04-30, 09:21)HiassofT Wrote: [ -> ]
(2017-04-28, 22:08)khaoohs Wrote: [ -> ]Remote has stopped working with build 0418, works with 0417.
Tried 0427, still not working, logs below.
LibreELEC:~ # pastebinit .kodi/temp/kodi.log
http://sprunge.us/bEEf
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/fhTj
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/eIJH
Could you please upload logs from the working 0417 build as well?
Do you use the IR receiver built into your box or did you add an additional (USB) one? There's an error message in dmesg, the builtin nuvoton_cir receiver could not be initialized, so if you are using that this could be the cause of the issues.
so long,
Hias
Thanks for taking the time to look at this. Yes, I am using the builtin IR receiver.
0417 remote working logs
http://sprunge.us/aKAD
http://sprunge.us/HXTc
http://sprunge.us/LgKf
(2017-05-02, 03:03)khaoohs Wrote: [ -> ]0417 remote working logs
Thanks for the logs! Could you try disabling lirc in LE settings and report back if that works?
so long,
Hias
New LibreELEC.tv Leia build #0502: Generic
# uname -a
Linux NUC 4.10.13 #1 SMP Tue May 2 21:04:31 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170502210309-#0502-g33a82f9 [Build #0502]
# Kodi version
Based on tip of LibreELEC.tv master (33a82f91, changelog) and tip of XBMC master (d0a790d4, changelog) with the following modifications:
  • Includes latest libnfs master (a523f843, ahead +59)
  • Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (f83990a4, +4), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (8549a31c), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
Build Highlights:
  1. pvr.iptvsimple: Revert "change to automatic interface version set"
Build Details:
  1. XBMC:
    • Encasulate all the is playcount set functionality in CVideoInfoTag (PR:12022, 1 commit, 5 files changed)
    • [buildsteps][windows] run-tests: use 64-bit toolset if available (PR:12048, 1 commit, 1 file changed)
  2. libnfs:
    • Clamp read/write max size for servers that accept huge PDUs (a523f843)
  3. pvr.iptvsimple:
    • Revert "change to automatic interface version set" (PR:122, 1 commit, 1 file changed)
(2017-05-01, 10:00)sboa Wrote: [ -> ]
log Sad
Sorry, still don't know. Your Intel HDMI GPU isn't being detected, for some reason. Maybe it's a BIOS issue, because if this were a kernel issue I'd expect more people to be complaining (and the only change between #0417/#0418 of note is a kernel bump).
Have you tried a clean install from LibreELEC 8.0.1 disk image, then upgrading to the latest test build? Make a backup of your data first.
Can you also upload a logfile zip from #0417 when using only the Intel GPU, ie. the logfiles from a working system.
In the last updates (since you did the BUMP screensaver.shadertoy I'm getting the next errors:
01:53:41.370 T:140375828931008 WARNING: Unable to resolve: /visualization.shadertoy.so.1.1.5 ADDON_GetTypeVersion, reason: /storage/.kodi/addons/visualization.shadertoy/visualization.shadertoy.so.1.1.5: undefined symbol: ADDON_GetTypeVersion
01:53:41.370 T:140375828931008   ERROR: Unable to resolve exports from dll /storage/.kodi/addons/visualization.shadertoy/visualization.shadertoy.so.1.1.5
01:53:41.382 T:140375828931008 WARNING: Unable to resolve: /visualization.shadertoy.so.1.1.5 ADDON_GetTypeVersion, reason: /storage/.kodi/addons/visualization.shadertoy/visualization.shadertoy.so.1.1.5: undefined symbol: ADDON_GetTypeVersion
01:53:41.382 T:140375828931008   ERROR: Unable to resolve exports from dll /storage/.kodi/addons/visualization.shadertoy/visualization.shadertoy.so.1.1.5
Is something I'm missing?
@ferent update to the version in the add-ons folder (link at end of first post) however one of them - screensaver or visualization, can't remember - is crashing on x86_64.
