New LibreELEC.tv Leia build #0720:
Generic
(Supercedes previous build)
SHA256 Checksum:
a121b7df61195bb6009d7dbdd89434ffe8598f198ce9c07a5f54b6b6326a2c3a
(Generic)
text:
# uname -a
Linux NUC 4.17.8 #1 SMP Fri Jul 20 21:04:07 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180720210251-#0720-ga936505 [Build #0720]
# Kodi version
(18.0-ALPHA3 Git:b7583e3). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a936505,
changelog) and tip of
XBMC master (03acaf5,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (faf22f1), inputstream.rtmp (bf5351e), peripheral.joystick (dbdeded), peripheral.xarcade (1484c4f, +3), pvr.argustv (37a3a76), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (75e2447), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (306fac5), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (6439be6), pvr.mythtv (c4d8899), pvr.nextpvr (6f0515b), pvr.njoy (30aae48), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (bfb875e, +2), pvr.teleboy (0460536), pvr.vbox (12e1304), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3), pvr.wmc (ec652db), pvr.zattoo (12134c8), vfs.libarchive (1bc1517)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2837 (perma): linux (RPi): update to linux-4.14.56
- Include [env] PR:2838 (perma): linux (Generic): update to linux-4.17.8
- Include [pkg] PR:10 (perma): Add new ids (RTL8812AU)
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
- Include [pkg] PR:14194 (perma): Fix crash in zero-copy games if dimensions are changed
Build Highlights:
- [PVR] Fix deadlock when removing deleted channels & some code cleanup.
Build Details:
- LibreELEC.tv:
- tcpdump: fix missing dependency (PR:2841, 1 commit, 1 file changed)
- XBMC:
- [JSON]Fix filtering in GetSongs and GetAlbums (PR:14201, 1 commit, 2 files changed)
- [cleanup][win10] remove drive letter hacks (PR:14204, 1 commit, 3 files changed)
- [PVR] Fix deadlock when removing deleted channels & some code cleanup. (PR:14205, 1 commit, 5 files changed)
- [RetroPlayer] Configure renderer sooner (PR:14203, 1 commit, 1 file changed)
- OMXImage: Switch filename to std:tring (PR:14207, 1 commit, 2 files changed)
so I thought the issue of HD audio passthru with the use of a LSPCON was fixed for Kabylake/ApolloLake, but went to test with recent builds here and getting no audio for Dolby TrueHD and DTS HD-MA streams when using a USB-C to HDMI 2.0 adapter (which Kodi correctly identifies as a DisplayPort output).
(2018-07-21, 02:49)Matt Devo Wrote: [ -> ]so I thought the issue of HD audio passthru with the use of a LSPCON was fixed for Kabylake/ApolloLake, but went to test with recent builds here and getting no audio for Dolby TrueHD and DTS HD-MA streams when using a USB-C to HDMI 2.0 adapter (which Kodi correctly identifies as a DisplayPort output).
What has the USB-C to do with the internal LSPCON of the kabylake nucs? Same LSPCON? It for sure won't take the intel gpu driver path
(2018-07-21, 08:33)fritsch Wrote: [ -> ] (2018-07-21, 02:49)Matt Devo Wrote: [ -> ]so I thought the issue of HD audio passthru with the use of a LSPCON was fixed for Kabylake/ApolloLake, but went to test with recent builds here and getting no audio for Dolby TrueHD and DTS HD-MA streams when using a USB-C to HDMI 2.0 adapter (which Kodi correctly identifies as a DisplayPort output).
my understanding of the issue was it related more to the handling of audio/ELD when connected to a DisplayPort output of the GPU than the actual LSPCON itself (though the NUCs had issues with the LSPCON itself as well)
(2018-07-21, 10:34)Matt Devo Wrote: [ -> ] (2018-07-21, 08:33)fritsch Wrote: [ -> ] (2018-07-21, 02:49)Matt Devo Wrote: [ -> ]so I thought the issue of HD audio passthru with the use of a LSPCON was fixed for Kabylake/ApolloLake, but went to test with recent builds here and getting no audio for Dolby TrueHD and DTS HD-MA streams when using a USB-C to HDMI 2.0 adapter (which Kodi correctly identifies as a DisplayPort output).
I had a different understanding here :-)
New LibreELEC.tv Leia build #0721:
Generic
SHA256 Checksum:
81b5fb2f5ec6a7563320ba42f056a262d1803289e2771bd1eb232eb5ae4cdbf1
(Generic)
text:
# uname -a
Linux NUC 4.17.8 #1 SMP Sat Jul 21 21:04:04 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180721210249-#0721-g27669a0 [Build #0721]
# Kodi version
Based on tip of
LibreELEC.tv master (27669a0,
XBMC master (0b8f23a,
Build Highlights:
- [gui] Kill g_audioManager
Build Details:
- LibreELEC.tv:
- gcc-linaro: update to latest version (PR:2812, 4 commits, 4 files changed)
- XBMC:
- [gui] Kill g_audioManager (PR:14198, 1 commit, 15 files changed)
- [cleanup] silence casts away qualifiers warnings (PR:14192, 18 commits, 73 files changed)
#0721 - I am getting irregularly freezes ... libreelec still accessable via ssh but GUI stops responding ... I cannot identify a specific action;
happens when playing/navigating music, watching/navigating movies or already at startup when loading widgets ... to me it seems has been getting worse after #0712;
changing skin to standard Estuary does not help; anything else I could try?
https://paste.ubuntu.com/p/8F9dXkK5m8/
thx
peter
See my post exactly above yours :-)
New LibreELEC.tv Leia build #0722:
Generic
SHA256 Checksum:
af8909b2731edcfabcc6c4c32b142d016d6086ff49a0aa7d239a0a9f0206d553
(Generic)
text:
# uname -a
Linux NUC 4.17.9 #1 SMP Sun Jul 22 21:11:39 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180722210247-#0722-g9677927 [Build #0722]
# Kodi version
Based on tip of
LibreELEC.tv master (9677927,
XBMC master (56383d5,
- Include [env] PR:2838 (perma): linux (Generic): update to linux-4.17.9
Build Highlights:
- New 4.17.9 kernel
- X11: some fixes to OML timings
- X11: implement GetFrameLatencyAdjustment
- GLContextEGL: Adjust sleeptime when detecing missed msc increase
Build Details:
- LibreELEC.tv:
- kodi binary addons (PR:2842, 2 commits, 2 files changed)
- libretro-mame: update to libretro-mame-c816514 (PR:2839, 1 commit, 1 file changed)
- XBMC:
- X11: some fixes to OML timings (PR:14211, 1 commit, 1 file changed)
- FFmpeg: Bump to 4.0.2-Leia-Alpha3 (PR:14212, 1 commit, 1 file changed)
- X11: implement GetFrameLatencyAdjustment (PR:14213, 1 commit, 5 files changed)
- GLContextEGL: Adjust sleeptime when detecing missed msc increase (PR:14214, 1 commit, 1 file changed)
- Added: [env] PR:2838 (perma): linux (Generic): update to linux-4.17.9
Are the NFS Boot issues solved with 0722?
(2018-07-22, 22:45)pyrodex Wrote: [ -> ]Are the NFS Boot issues solved with 0722?
No - it will be clear from the release notes when that particular issue is resolved.
Weekly Linux 4.18-rc6 build #0722x:
Generic
This includes a temporary fix for NFS booting - @
pyrodex please confirm if this now works.
Packages disabled/not included:
text:
DVB Driver Addons
Spinelplus support
(2018-07-23, 03:48)Milhouse Wrote: [ -> ]Weekly Linux 4.18-rc6 build #0722x: Generic
This includes a temporary fix for NFS booting - @pyrodex please confirm if this now works.
text:
DVB Driver Addons
Spinelplus support
Was able to upgrade on TFTP server and boot just fine with NFS boot and storage.
(2018-07-23, 04:08)pyrodex Wrote: [ -> ] Was able to upgrade on TFTP server and boot just fine with NFS boot and storage.
Thanks, we still need to determine why the changes to glibc broke the RPC protocol support in initramfs (which is what prevents NFS from being mounted).
