Just that this isn't the RPi thread, it's the x86 thread...
(2017-04-05, 20:03)Milhouse Wrote: [ -> ]Just that this isn't the RPi thread, it's the x86 thread...
my bad, yes i just noticed that, too many tabs open
, thanks milhouse
@SharpCoder: Please re-post your details in the RPi thread, if anyone else has a similar issue they can confirm. Would be great if you can identify when (which build) the issue starts... most likely a kernel bump, although if 8.0/8.1 behaves the same then it's not a recent bump (they're both using 4.9.13, I believe). Including dmesg/journalctl/lsusb details would also help identify your dongle chipset.
New LibreELEC.tv Leia build #0405:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.8 #1 SMP Wed Apr 5 21:05:43 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170405210421-#0405-g8cd9fa5 [Build #0405]
# Kodi version
(18.0-ALPHA1 Git:78cce57). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (8cd9fa57,
changelog) and tip of
XBMC master (656f12ce,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8563411d, ahead +11)
- Includes latest libnfs master (1052ba94, ahead +58)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (b02876dd, +2), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
- Include [env] compare: linux: update to linux-4.10.8
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: rapidjson: update to rapidjson-1.1.0
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1469: samba: update to samba-4.6.1
- Include [env] PR:1491: linux: cp project and device device tree, silence errors
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:62: #change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11911: [cmake] fix package names that find_package is equal to find_package_handle_standard_args
Build Highlights:
- [pvr] no need to run a job to announce channel switch
Build Details:
- XBMC:
- [osx] - add the minimum required osx version to the info.plist - this… (PR:11932, 1 commit, 1 file changed)
- [pvr] no need to run a job to announce channel switch (PR:11895, 1 commit, 3 files changed)
- [depends] use ccache for binary add-ons (PR:11930, 2 commits, 3 files changed)
New LibreELEC.tv Leia build #0406:
Generic
# uname -a
Linux NUC 4.10.8 #1 SMP Thu Apr 6 21:04:09 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170406210249-#0406-gf3caa55 [Build #0406]
# Kodi version
Based on tip of
LibreELEC.tv master (f3caa554,
XBMC master (da6dd533,
- Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (0baf85af, +3), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
- Include [env] compare: tvheadend42: update (pngquant)
- Include [env] PR:1508: Update to RTL8192DU-efc8508
- Include [pkg] PR:11934: [PVR] Fix timers map after f47956f9d2dc50ace7b7dc3a529eafc988f4471e
Build Highlights:
- compare: tvheadend42: update (pngquant) - improve png compression in documentation
- PR:1508: Update to RTL8192DU-efc8508
- PR:11934: [PVR] Fix timers map after f47956f9d2dc50ace7b7dc3a529eafc988f4471e
Build Details:
- LibreELEC.tv:
- RTL8812AU: add device ID for TP-Link T4U ver 2 (PR:1498, 1 commit, 1 file changed)
- XBMC:
- Disable gcc printf verifier for logging function (PR:11913, 2 commits, 2 files changed)
- FFmpegImage: Document and change alignment (PR:11668, 2 commits, 1 file changed)
- AMLCodec: fix 720p -> 1080p switching (PR:11935, 1 commit, 1 file changed)
- [cmake] fix package names that find_package is equal to find_package_handle_standard_args (PR:11911, 2 commits, 12 files changed)
- peripheral.joystick:
- CMake 3.1+ is required (PR:97, 1 commit, 1 file changed)
- pvr.hts:
- 4.0.9: Fix timeshift state and data calculation if demuxer is not active. Fixes #292 (PR:293, 1 commit, 4 files changed)
- Added: [env] compare: tvheadend42: update (pngquant)
- Added: [env] PR:1508: Update to RTL8192DU-efc8508
- Added: [pkg] PR:11934: [PVR] Fix timers map after f47956f9d2dc50ace7b7dc3a529eafc988f4471e
Even will adsp addons become available?
New LibreELEC.tv Leia build #0407:
Generic
# uname -a
Linux NUC 4.10.8 #1 SMP Fri Apr 7 21:28:06 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170407212644-#0407-gf3caa55 [Build #0407]
# Kodi version
Based on tip of
XBMC master (984fe69c,
- Includes latest libcec master (3953f8dc, ahead +12)
- Include [env] PR:1320: lirc cleanup: switch to upstream fixes and configuration
- Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:63: lircd: settings changes required for LE PR 1320 (service.libreelec.settings)
Build Highlights:
- PR:1320: lirc cleanup: switch to upstream fixes and configuration
Build Details:
- XBMC:
- [PVR] Fix timers map after f47956f9d2dc50ace7b7dc3a529eafc988f4471e (PR:11934, 1 commit, 2 files changed)
- [MediaCodec] Fix videoBuffer video dimensions (PR:11936, 1 commit, 1 file changed)
- libcec:
- Added: [env] PR:1320: lirc cleanup: switch to upstream fixes and configuration
- Added: [pkg] PR:63: lircd: settings changes required for LE PR 1320 (service.libreelec.settings)
ksooo, since build #0330, seek-to-timecode (ie. punching numbers on a numeric keypad while playing a video) no longer works - digits no longer appear on the screen, there is no seeking.
Reproducible on both RPi and Generic builds. Works fine in build #0329, doesn't work in build #0330.
Other than an unrelated Estuary change, the only Kodi changes in build #0330 are:
(2017-03-31, 02:30)Milhouse Wrote: [ -> ]Build Details:
- XBMC:
- [PVR] CPVRTimers fixes and optimization (PR:11920, 2 commits, 7 files changed)
- [PVR] Rework CPVRActionListener and CPVRGUIActions lifecycle (PR:11919, 1 commit, 23 files changed)
At a guess, PR11919 would be the most likely culprit.
New LibreELEC.tv Leia build #0408:
Generic
# uname -a
Linux NUC 4.10.8 #1 SMP Sat Apr 8 21:04:04 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170408210240-#0408-gf494a5f [Build #0408]
# Kodi version
Based on tip of
LibreELEC.tv master (f494a5fd,
XBMC master (2b2c6295,
- Include [env] PR:1512: Update RTL8192EU to a7fd035
Build Highlights:
- Fix seek-to-timecode
- PR:1512: Update RTL8192EU to a7fd035
Build Details:
- LibreELEC.tv:
- Port forward of #1492 (PR:1493, 3 commits, 4 files changed)
- linux: cp project and device device tree, silence errors (PR:1491, 1 commit, 1 file changed)
- net-snmp: make addon configurable through gui settings (PR:1500, 1 commit, 10 files changed)
- Forward port of #1496 (PR:1502, 1 commit, 4 files changed)
- imx6: update libcec patch for 3.14 kernel (PR:1507, 1 commit, 1 file changed)
- imx6/linux: kernel fixes from vero (forward port of #1436) (PR:1506, 1 commit, 1 file changed)
- imx6/linux: export symbol used by gpio-ir-recv (forward port of #1494) (PR:1505, 1 commit, 1 file changed)
- VDR: dynamically resize buffer for caids (PR:1475, 1 commit, 1 file changed)
- XBMC:
- erase unsupport tags in TX3G subtitle (PR:11792, 1 commit, 1 file changed)
- [PVR] Trac #17374: enabled "PVR -> Power saving -> Wakeup command" setting is not called (PR:11905, 5 commits, 11 files changed)
- [PVR] CPVRActionListener: Fix direct number input handling (PR:11938, 1 commit, 1 file changed)
- Added: [env] PR:1512: Update RTL8192EU to a7fd035
Since #0407 lirc changes remote key press registers twice
(2017-04-09, 00:31)neox387 Wrote: [ -> ]Since #0407 lirc changes remote key press registers twice
Can you provide a debug log and details/description of your remote control hardware?
I got the problem to occur when switching to 0408. (The remote control doublepress) when I went down to 0407 it went away.
My remote is an original microsoft RC6 remote on an Intel NUC using the built in ir receiver there. Can try to fix a debug log in the morning.
(2017-04-09, 04:40)laric Wrote: [ -> ]I got the problem to occur when switching to 0408. (The remote control doublepress) when I went down to 0407 it went away.
In addition to the kodi debug log please also post the output of the following commands:
ir-keytable
journalctl -a | paste
Do you have lirc enabled in LibreELEC settings? If yes, run the following command, press a few keys and post the output:
irw /run/lirc/lircd.socket
Also try disabling lirc in LibreELEC settings. In most cases you don't need to run lircd, the kernel should support your IR receiver and handle MCE remotes out of the box. Still, if you enable lircd it should automatically disable kernel decoding so the logs will be useful to see if/what went wrong.
so long,
Hias
I have the same remote key press issue on my Chromebox with 0408 (Didn't try 0407), two really fast presses seem to occur.
I can't provide a log tonight but mine is the Harmony Touch set up as a Microsoft remote using the big old IR Microsoft dongle.
