I need a tuner TV-SAT dual. Raspberry Pi / OdroidC2 have tuners? Besides, I want a machine that works fast and does not jam. That's why I wanted HTPC. A year ago I was playing wet2 play2 and it seemed to work on it but it often stuck
Hi, I'm getting a strange error.
When i want to play a "in progress Tv show" from the start page I'm getting the error "Playback failed/can't find a next item to play[/code]".
If i navigate trough the point "TV shows" the file plays.
If i choose to play a "in progress Movie", it works like a charm.
I've also tested the setting with NFS-shares with the same results.
On the Offical LE 8.0.1 build everything works fine.
My Specs are:
Intel NUC6CAYS (Apollo Lake)
Clean install (LE8 + mh-tar)
Log abstract:
16:33:15.055 T:140188448263680 NOTICE: VideoPlayer: Opening: videodb://inprogresstvshows/43/4/1199?season=4&tvshowid=43
16:33:15.056 T:140186433312512 NOTICE: Creating InputStream
16:33:15.056 T:140186433312512 ERROR: CVideoPlayer::OpenInputStream - error opening [videodb://inprogresstvshows/43/4/1199?season=4&tvshowid=43]
16:33:15.056 T:140186433312512 NOTICE: CVideoPlayer::OnExit()
16:33:15.057 T:140188448263680 ERROR: Playlist Player: skipping unplayable item: 7, path [videodb://inprogresstvshows/43/4/1199?season=4&tvshowid=43]
16:33:15.076 T:140188448263680 NOTICE: CVideoPlayer::CloseFile()
16:33:15.076 T:140188448263680 NOTICE: VideoPlayer: waiting for threads to exit
16:33:15.076 T:140188448263680 NOTICE: VideoPlayer: finished waiting
16:33:16.351 T:140188448263680 NOTICE: VideoPlayer: Opening: videodb://inprogresstvshows/43/4/989?season=4&tvshowid=43
16:33:16.351 T:140188448263680 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
16:33:16.352 T:140186416527104 NOTICE: Creating InputStream
16:33:16.352 T:140186416527104 ERROR: CVideoPlayer::OpenInputStream - error opening [videodb://inprogresstvshows/43/4/989?season=4&tvshowid=43]
Logilfe:
http://paste.ubuntu.com/24517288/
(2017-05-05, 15:57)kowalmisiek Wrote: [ -> ]I need a tuner TV-SAT dual. Raspberry Pi / OdroidC2 have tuners? Besides, I want a machine that works fast and does not jam. That's why I wanted HTPC. A year ago I was playing wet2 play2 and it seemed to work on it but it often stuck
You should probably ask on the LibreELEC forum, they've got a dedicated DVB sub-forum.
(2017-05-05, 16:54)kafisc Wrote: [ -> ]Hi, I'm getting a strange error.
Can you enable
debug log (wiki) and upload your log again? It's a little difficuly to say what the issue is.
How did you populate your library, did you import it from a backup, or scan it from scratch? Which scraper did you use (The TVDB, Local Information only, or some other scraper?)
When you install LE 8.0.1, do you have this issue?
New LibreELEC.tv Leia build #0505:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.14 #1 SMP Fri May 5 21:10:15 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170505210731-#0505-g2911c4a [Build #0505]
# Kodi version
(18.0-ALPHA1 Git:91a9066). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (2911c4af,
changelog) and tip of
XBMC master (b8ad238a,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (4abadb79, ahead +64)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (f83990a4, +4), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
- Exclude [env] ffmpeg-99.1010-tls-1.2.patch: upstream ffmpeg-3.3
- Include [env] patch: vfs addons: add vfs.rar, vfs.sacd and vfs.sftp kodi-binary-addons
- Include [env] patch: imagedecoder.raw: update imagedecoder.raw
- Include [env] patch: screensaver.shadertoy: bump screensaver.shadertoy to 434f5ce
- Include [env] patch: visualization.projectm: bump visualization.projectm to 7489e4a
- Include [env] patch: visualization.shadertoy: bump visualization.shadertoy to ae677ac
- Include [env] patch: visualization.spectrum: bump visualization.spectrum to d7d9c14
- Include [env] patch: ffmpeg: update to ffmpeg-3.3
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.2
- Include [env] PR:1582: tvheadend42: update addon
- Include [env] PR:1597: build system: verify package downloads using sha256 checksum
- Include [pkg] PR:2: Update b43 firmware (wlan-firmware)
- Include [pkg] PR:24: Remove not used part (inputstream.adaptive)
- Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:65: update language from transifex (service.libreelec.settings)
- Include [pkg] PR:72: Remove not used part (pvr.mythtv)
- Include [pkg] PR:73: libXBMC_codec.h removed and changed to libXBMC_pvr.h (pvr.mythtv)
- Include [pkg] PR:12034: KODI: Update NEON support
Build Highlights:
- New 4.10.14 kernel
- libnfs: Export nfs_set_timeout() and nfs_get_timeout()
Build Details:
- LibreELEC.tv:
- imx6/u-boot: update to ad02f49 (PR:1592, 1 commit, 5 files changed)
- xf86-video-nvidia: update to 375.66 (PR:1595, 1 commit, 3 files changed)
- linux: fix options dropped when CONFIG_INITRAMFS_SOURCE is not set (PR:1594, 1 commit, 2 files changed)
- linux: update to linux-4.10.14 (PR:1599, 6 commits, 5 files changed)
- libnfs:
- libnfs: Export nfs_set_timeout() and nfs_get_timeout() (PR:196, 1 commit, 1 file changed)
- Remove old declarations of nfs_get|set_timeout (4abadb79)
- Added: [env] PR:1597: build system: verify package downloads using sha256 checksum
(2017-05-05, 20:20)Milhouse Wrote: [ -> ] (2017-05-05, 16:54)kafisc Wrote: [ -> ]Hi, I'm getting a strange error.
Can you enable debug log (wiki) and upload your log again? It's a little difficuly to say what the issue is.
Thank you very much for your reply.
Here is the new debug log for the path: "In progress" --> "2 Broke Girls":
https://pastebin.com/X7wGYCik --> not working
And to compare, the debug log for the path: "TV Shows" --> "2 Broke Girls"
https://pastebin.com/vyuQ7gQZ --> is working
- the library is scanned from the stratch
- Scraper: The TVDB (no local information are provided)
- On LE 8.0.1 I do not have this issue
Thank you in advance
kafisc
New LibreELEC.tv Leia build #0506:
Generic
# uname -a
Linux NUC 4.10.14 #1 SMP Sat May 6 21:08:26 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170506210327-#0506-g763397e [Build #0506]
# Kodi version
Based on tip of
LibreELEC.tv master (763397eb,
XBMC master (ed057680,
- Include [env] PR:1601: RTL8723BS: add support for OBDA8723 - Bluetooth
- Include [pkg] patch: Remove not used part (inputstream.adaptive)
Build Highlights:
- Kodi: Estuary language updates
- Kodi: Settings updates
Build Details:
- LibreELEC.tv:
- imx6/linux: update patches for som v1.5 from solidrun (PR:1602, 1 commit, 3 files changed)
- imx-gpu-viv: update to galcore v5 on linux 4.4 (PR:1603, 1 commit, 1 file changed)
- projects/imx6: init terminal with reset command in console service (PR:1600, 1 commit, 1 file changed)
- XBMC:
- [cmake] copy_files_from_filelist_to_buildtree: add KEEP_DIR_STRUCTURE option (PR:12053, 1 commit, 1 file changed)
- [settings] fix default formatting of slider settings (PR:12060, 1 commit, 1 file changed)
- Set Param1 to WINDOW_INVALID for plugins when Init is called (PR:12050, 1 commit, 1 file changed)
- Update README.linux testing information (PR:12006, 1 commit, 1 file changed)
- [settings] multiple improvements (PR:12062, 4 commits, 2 files changed)
- [settings] CGUIControlListSetting: don't disable control for multiselect settings (PR:12061, 1 commit, 1 file changed)
- [lang][kodi.core] automatic syntax corrections for the en_GB language file (b9bed17a)
- [lang][skin.estuary] automatic syntax corrections for the en_GB language file (0db2ef5f)
- [lang][skin.estuary] updated language files from Transifex (c5988a43)
- [lang][skin.estouchy] updated language files from Transifex (54fb0788)
- Added: [env] PR:1601: RTL8723BS: add support for OBDA8723 - Bluetooth
New LibreELEC.tv Leia build #0507:
Generic
# uname -a
Linux NUC 4.11.0 #1 SMP Sun May 7 21:07:41 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170507210620-#0507-gbdb3738 [Build #0507]
# Kodi version
Based on tip of
LibreELEC.tv master (bdb37380,
XBMC master (f160c829,
- Includes latest addons: inputstream.adaptive (7bde41f9, +3), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (f83990a4, +4), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
- Include [env] PR:1441: linux: update to linux-4.11.0
- Include [env] PR:1442: Intel HDMI/DP LPE audio config
- Include [env] PR:1610: OdroidC2/RTL8192CU: no longer needed after #1513
- Include [pkg] PR:12067: FTPParse.cpp: use std:tring
Build Highlights:
- New 4.11.0 kernel with support for ALL video drivers (ie. nvidia and nvidia-legacy)
- Intel HDMI/DP LPE audio config
Build Details:
- LibreELEC.tv:
- tvheadend42: update addon (PR:1582, 2 commits, 8 files changed)
- XBMC:
- Fix compilation on sh4/sparc/arc/xtensa (PR:12014, 4 commits, 4 files changed)
- RssReader: Fix comparison between pointer and zero (PR:12033, 1 commit, 1 file changed)
- inputstream.adaptive:
- Added: [env] PR:1441: linux: update to linux-4.11.0
- Added: [env] PR:1442: Intel HDMI/DP LPE audio config
- Added: [env] PR:1610: OdroidC2/RTL8192CU: no longer needed after #1513
- Added: [pkg] PR:12067: FTPParse.cpp: use std:tring
New LibreELEC.tv Leia build #0508:
Generic
# uname -a
Linux NUC 4.11.0 #1 SMP Mon May 8 21:05:01 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170508210341-#0508-gbdb3738 [Build #0508]
# Kodi version
Based on tip of
XBMC master (61e98fd3,
- Includes latest addons: inputstream.adaptive (7bde41f9, +3), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (f83990a4, +4), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (9aeb5e9d, +3), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
- Include [env] PR:1612: Package updates: various minor bumps
- Include [env] PR:1613: wlan-firmware: update to wlan-firmware-cf02ad3
Build Highlights:
- Large number of package updates - some add-ons might be broken, shout and I'll push what I can
Build Details:
- XBMC:
- FTPParse.cpp: use std:tring (PR:12067, 1 commit, 1 file changed)
- [cmake] copy_files_from_filelist_to_buildtree: fix 1afb6dcbd8 (PR:12068, 1 commit, 1 file changed)
- [cmake] AddonHelpers: fix install directory exclude syntax (PR:12070, 1 commit, 1 file changed)
- pvr.mythtv:
- Remove not used part (PR:72, 1 commit, 1 file changed)
- libXBMC_codec.h removed and changed to libXBMC_pvr.h (PR:73, 1 commit, 4 files changed)
- Added: [env] PR:1612: Package updates: various minor bumps
- Added: [env] PR:1613: wlan-firmware: update to wlan-firmware-cf02ad3
I just updated my hardware to a NUC7i5BNK (unexpectedly) and am now experiencing intermittent audio cutouts (~ 1 per minute), any thoughts on what to try? (Latest bios ans libreelec build as of today). Any thoughts? I'm really frustrated right now, my 5 year old managed to kill my Skull Canyon NUC and I bought this to replace it and now I'm having issues.
SIGH
UPDATE: I just installed 8.0.1, and I am not having the issue. anything I can test with the nightlies? If there a version with a kernel / driver update that would have effected the NUC line?
wallacebw I can only suggest trying the different kernels - LE8 is on 4.9.y, so try a build that uses 4.9.y, then if that has no problem then try 4.10.y and finally 4.11.y. Identifying the first build with the issue will help towards a solution - if it's not a kernel issue it might be a Kodi/videoplayer issue. Also upload a debug log.
Is Leia build #0508: supposed to use ./config/lirc_options.conf if present? I just tried it (needed to override some lircd parameters) and it doesn't seem to be using it.
(2017-05-03, 23:11)Milhouse Wrote: [ -> ] (2017-05-03, 22:41)sboa Wrote: [ -> ]Quote:Have you tried a clean install from LibreELEC 8.0.1 disk image, then upgrading to the latest test build? Make a backup of your data first.
Can you also upload a logfile zip from #0417 when using only the Intel GPU, ie. the logfiles from a working system.
I really do not know Linux, can you give me all the files in one archive?
Please upload the requested #0417 logfile (when using only the Intel GPU) before you blow your system away.
Follow the following instructions to perform a clean install, but first remove your Geforce card before proceeding as that's only going to confuse matters.
1) To perform a clean install, download the USB-SD Creator tool from https://libreelec.tv/downloads/ then select the "Generic AMD/Intel" build (currently LibreELEC 8.0.1). Follow the prompts and it will write a bootable image to your USB memory stick.
2) Boot the USB memory stick to install LibreELEC 8.0.1 to your HTPC. Note that IT WILL WIPE YOUR HARD DRIVE so backup any data you want to keep before attempting this clean install - use the LibreELEC Settings addon in Kodi, there's a "Backup" option.
3) Once your PC is booting into LibreELEC 8.0.1 (with working i915/Intel HDMI), copy the tar file of the latest test build into your Update folder (on the LibreELEC client) and reboot - you'll now be running the latest test build, which hopefully works as expected, with working i915 HDMI.
My log
Folder 1
1. Installed LibreELEC-Generic.x86_64-8.0.1.img
2. Update LibreELEC-Generic.x86_64-9.0-Milhouse-20170508210341- # 0508-gbdb3738.tar
3. The screen is black
Folder 2
2. Backup my
3. The OK screen
4. Update LibreELEC-Generic.x86_64-9.0-Milhouse-20170508210341- # 0508-gbdb3738.tar
5. The screen is black
Folder 3
2. Update LibreELEC-Generic.x86_64-9.0-Milhouse-20170417210430- # 0417-ge271629.tar
3. The OK screen
Folder 4
3. The OK screen
