2018-08-26, 09:46
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355
2018-08-26, 13:13
Still sound misfires during video playback with the current build here my logs
I hope that my sound interruption will be fixed soon, because so my mini-PC for Libreelec is worthless to me. With Windows 10 I have no audio dropouts, so I think that the hardware has no defect but it must be under Linux.
Crash log
System log
Here again the log what my manufacturer has changed in my zotac zbox on a bios update.
Version 2K180626
- Updated ME / TXE for Intel Vulnerability fix
- Updated Intel CPU microcode patch for "Spectre" issue
- Fixed HDCP2.2 for 4K UHD Bluray Disk Playback issue
- Fixed Win7-UEFI mode boot issue
- Updated DMI content for match with SKU
Crash log
System log
Version 2K180626
2018-08-26, 19:38
(2018-08-25, 05:54)Milhouse Wrote: [ -> ](2018-08-25, 01:52)UrushibaraRuka Wrote: [ -> ]As far as I understand it we don't get the 1080p and higher streams anymore because of the DRM Amazon and the like use and that it partially has to do with OpenGL.I'm pretty sure that OpenGL or Vulcan has nothing to do with Netflix/Amazon DRM limitations, as you can already view 1080p Netflix/Amazon streams with OpenGL today. The most common limitation is that of your CPU as the Netflix/Amazon DRM streams need to be software decoded - a weak CPU may only manage 720p, and stutter with 1080p or higher.
These are my inputstream.adaptive settings, and I'm able to view 1080p without a problem (the 4K HEVC option in the Netflix add-on is disabled as it causes the temperature on my Skylake i5 NUC CPU to go through the roof):
Maybe this comment on github is relevant: https://github.com/asciidisco/plugin.vid...-414315046:
Quote:inputstream.adaptive will by default not let you play a stream with a resolution larger than your active display resolution. If your display is running below 1920x1080, enable Ignore display resolution in the inputstream.adaptive settings.
If you have further problems viewing Netflix or Amazon content, I'd suggest contacting the relevant developers on their github.
Sorry for the late reply @Milhouse
It's not that I don't get 1080p streams on Amazon at all, some TV Shows such as Lucifer are delivered in 1080p, I'm just not sure if it's done with the software decoder (in which case my CPU is enough for it) or hardware decoded (in which case Amazon has a very inconsistent implementation of their DRM).
But Movies such as "The Dark Knight" are only delivered in sub 720p (9XX x 5XX). It worked in 1080p hardware some (long) time ago but then Amazon decided to change the DRM and now most Movies and even some TV Shows are delivered in sub 720p.
In the German addon thread for the Amazon VOD addon it was explained like this:
The server gets a request for a Movie, the server asks if the device is able to conform with the DRM (trusted memory so the content can't be copied) and if the answer is "no" the server only deliveres the next highest stream below 720p (which is usually the mentioned 9XX x 5XX).
Now to my understanding, Vulkan 1.1 adds this "trusted memory" to prevent copying the content thus making the ask of the server a "yes" which would enable 1080p with the hardware decoder again.
And just to clarify, my inputstream is set like in your screenshot and my display is running at 1080p as well (also tried the ignore display resolution and still only got the mentioned 9XX x 5XX streams on most Movies).
I also got the same result on my Ryzen 1600X system running at 3,9GHz all core.
For bandwidth, everything is connected with a 400Mbps connection (1Gbps LAN), so there is also no issue here.
Thanks again for your clarification.
2018-08-26, 23:52
2018-08-27, 01:12
New LibreELEC.tv Leia build #0826: Generic
(Supercedes previous build)
SHA256 Checksum:
Based on tip of LibreELEC.tv master (6476bcf, changelog) and tip of XBMC master (4e198a9, changelog) with the following modifications:
SHA256 Checksum:
70a59dc7e4036aed382d8c31d02c1cc6fae8c9e46cb5e7ec07040eb04d895454
(Generic)text:# uname -a
Linux NUC 4.18.5 #1 SMP Sun Aug 26 23:36:32 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180826233458-#0826-g6476bcf [Build #0826]
# Kodi version
(18.0-BETA1 Git:4e198a9). Platform: Linux x86 64-bit
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (b63e867), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (e61f47c), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (12134c8), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Include [env] b3b57d4: RPi: fix Alsa card confs for new driver on kernel 4.18
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2872 (perma): update dvb addons
- Include [env] PR:2892 (perma): scripts/image: use maximum lzo and zstd compression level for images
- Include [env] PR:2907 (perma): config/functions: clean up recursion test
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.5
- Include [env] PR:2909 (perma): kodi: next (Sept || kodi bump)
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.4
- Include [env] PR:2915 (perma): linux: fix Module.symvers generation
- Include [env] PR:2920 (perma): mesa: update to mesa-18.1.7
- Include [env] PR:2923 (perma): linux: replace ancient rc6 decode hack with proper fix
- Include [env] PR:2929 (perma): scripts/extract: improve tar file handling
- Include [pkg] PR:14356 (perma): PythonInvoker: fix thread termination check
- Report correct Kodi git rev in kodi.log
- PythonInvoker: fix thread termination check
- [videoplayer] Fix external vob subs usage.
- LibreELEC.tv:
- bchunk: remove unneeded patch (PR:2924, 1 commit, 2 files changed)
- XBMC:
- [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2. (PR:14316, 6 commits, 27 files changed)
- [libUPnP] fix device discovery on windows (PR:14347, 2 commits, 3 files changed)
- [videoplayer] Fix external vob subs usage. (PR:14353, 1 commit, 2 files changed)
- [depends] bump pcre to 8.42 (PR:14342, 2 commits, 5 files changed)
- Android: Joystick improvements (PR:14308, 13 commits, 12 files changed)
- Updated: [env] patch: rev hack for kodi
- Updated: [env] PR:2872 (perma): update dvb addons
- Updated: [env] PR:2909 (perma): kodi: next (Sept || kodi bump)
- Added: [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Added: [env] PR:2929 (perma): scripts/extract: improve tar file handling
- Added: [pkg] PR:14356 (perma): PythonInvoker: fix thread termination check
2018-08-27, 04:38
(2018-08-25, 19:19)fritsch Wrote: [ -> ]i don't mean to hijack this post but would this have anything to do with my issue? there was a fix back in July that for some reason seems to have regressed in the newer builds. i personally tested fix releases and its bottling my mind.(2018-08-25, 16:23)phunkyfish Wrote: [ -> ](2018-08-25, 10:40)fritsch Wrote: [ -> ]There is no xvid video playing in your log, but 720x404 video playing at 3840x2160@60 hz. Does it also stutter if you change the resolution before hand to 1920x1080?
Hah, I can’t believe that was it. Thanks Fritsch!
Could you please play it again a bit longer with 3840x2160 with debug loggin enabled? Then after 2 minutes press some button on the keyboard and enable the OSD? We want to understand what happens, e.g. what is stuck / too slow.
2018-08-27, 08:27
(2018-08-27, 04:38)lwrcase Wrote: [ -> ]Can you reproduce and provide logfiles?(2018-08-25, 19:19)fritsch Wrote: [ -> ]i don't mean to hijack this post but would this have anything to do with my issue? there was a fix back in July that for some reason seems to have regressed in the newer builds. i personally tested fix releases and its bottling my mind.(2018-08-25, 16:23)phunkyfish Wrote: [ -> ]Hah, I can’t believe that was it. Thanks Fritsch!
2018-08-27, 14:53
(2018-08-25, 19:19)fritsch Wrote: [ -> ]I used advancedsettings to enable debug without the overlay. If I switch on debug logging in the GUI it adds an overlay which mitigates it.(2018-08-25, 16:23)phunkyfish Wrote: [ -> ](2018-08-25, 10:40)fritsch Wrote: [ -> ]There is no xvid video playing in your log, but 720x404 video playing at 3840x2160@60 hz. Does it also stutter if you change the resolution before hand to 1920x1080?
Here you go: http://ix.io/1llE
I would be interested to learn why the overlay makes a difference. I see similar behaviour with netflix and amazon addons regardless of setting 1920/1080 resolution in GUI.
2018-08-27, 18:38
(2018-08-25, 23:10)dapharsyde Wrote: [ -> ](2018-08-25, 22:59)ksooo Wrote: [ -> ]Which pvr add-on?Thanks for the pointer - I will try to contact @janbar and see if he can update the plugin.
EDIT: nvm
For that, the add-on needs to implement the GetStreamTimes API function (properly).
Would all plugins need this? I use VU+ and the problem is the same.
Worked one version and not the next.
2018-08-27, 18:51
(2018-08-27, 18:38)phunkyfish Wrote: [ -> ](2018-08-25, 23:10)dapharsyde Wrote: [ -> ](2018-08-25, 22:59)ksooo Wrote: [ -> ]Which pvr add-on?Thanks for the pointer - I will try to contact @janbar and see if he can update the plugin.
EDIT: nvm
Every pvr add-on that wants to provide time shifting needs to implement this, yes.
And no, it never worked with vuplus add-on - at least not reliably. This lies in the nature of the add-on to just hand Kodi a url to an http iptv stream.
Have you ever tried to pause a stream over a longer time, let's say longer than 60 seconds? Have you ever tried to seek in a stream? I doubt that this ever worked, because technically it can't work without the add-on buffering the stream data.
For Leia, we recently removed some nasty hacks and now it works like it should - namely no more non functioning pause and seek controls for those add-ons.
2018-08-27, 22:56
New LibreELEC.tv Leia build #0827: Generic
SHA256 Checksum:
Based on tip of LibreELEC.tv master (1f05ad3, changelog) and tip of XBMC master (c63b1a0, changelog) with the following modifications:
SHA256 Checksum:
c21166de2feb71ca29f5c7e58eacfd2d54e956a6914e6828d63e7ec3a6eb2296
Linux NUC 4.18.5 #1 SMP Mon Aug 27 21:16:57 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180827210827-#0827-g1f05ad3 [Build #0827]
# Kodi version
(18.0-BETA2 Git:c63b1a0). Platform: Linux x86 64-bit
- Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (b63e867), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (e61f47c), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (29e0bbf, +1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Include [env] patch: Kodi: use toolchain nm for generating wrapper.def
- Include [env] PR:2931 (perma): ffmpeg: cleanup
- Include [env] PR:2933 (perma): mariadb-connector-c: update to 3.0.6
- Include [env] PR:2934 (perma): kodi: fix CEC not turning TV off on exit
- Include [env] PR:2935 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.87
- Fix DVD nav when building Kodi with LTO on Ubuntu 16.04
- Fix turning off TV with CEC when Kodi shutdown
- ffmpeg: cleanup; mariadb-connector-c: update to 3.0.6
- xf86-video-nvidia: update to xf86-video-nvidia-390.87
- LibreELEC.tv:
- mesa: update to mesa-18.1.7 (PR:2920, 1 commit, 1 file changed)
- XBMC:
- pvr.zattoo:
- Fix loading detailed recording data (29e0bbf)
- Added: [env] patch: Kodi: use toolchain nm for generating wrapper.def
- Added: [env] PR:2931 (perma): ffmpeg: cleanup
- Added: [env] PR:2933 (perma): mariadb-connector-c: update to 3.0.6
- Added: [env] PR:2934 (perma): kodi: fix CEC not turning TV off on exit
- Added: [env] PR:2935 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.87
2018-08-28, 08:51
(2018-08-27, 18:51)ksooo Wrote: [ -> ](2018-08-27, 18:38)phunkyfish Wrote: [ -> ](2018-08-25, 23:10)dapharsyde Wrote: [ -> ] Thanks for the pointer - I will try to contact @janbar and see if he can update the plugin.
Thank ksooo, then it looks like I’ll restart my efforts to add the buffering into the VU+ addon. I thought I had gotten it for free 😉
2018-08-28, 13:40
Did that help me with my tonproblem?
https://bugzilla.redhat.com/attachment.c...ction=edit
[patch] Increase timeout in lspcon_wait_mode
2018-08-28, 15:01
(2018-08-25, 20:16)HiassofT Wrote: [ -> ]Below is the requested output:(2018-08-25, 11:13)dr88dr88 Wrote: [ -> ]My remote stopped working properly in version #0819 and higher.Could you please post the outputs of
It is a remote with a air mouse and on #0819 and higher the mouse pointer show up on the middel of the screen when it is disabled on the remote.
Every time I move the remote the navigation tries to move to the mouse pointer on the middel of the screen.
I have a Beworth T3 remote from https://www.aliexpress.com/item/Newest-F...4c4dIXi4FE
both from a working and a non-working build?Code:dmesg | paste
cat /proc/bus/input/devices | paste
so long,
Hias
working version
http://ix.io/1lr6
http://ix.io/1lr7
non working version
http://ix.io/1lr8
http://ix.io/1lr9
2018-08-28, 15:16
(2018-08-28, 15:01)dr88dr88 Wrote: [ -> ](2018-08-25, 20:16)HiassofT Wrote: [ -> ]Below is the requested output:(2018-08-25, 11:13)dr88dr88 Wrote: [ -> ]My remote stopped working properly in version #0819 and higher.Could you please post the outputs of
so long,
Hias
working version
http://ix.io/1lr6
http://ix.io/1lr7
non working version
http://ix.io/1lr8
http://ix.io/1lr9
The output is a bit odd, you seem to have 2 air mice / remotes / wireless keyboards connected: SAGE SAGE AirMouse (USB Vendor=400c Product=107a) and FREEWAY TECHNOLOGY RFIC-MOUSE (USB Vendor=0c45 Product=5012).
Could you connect only the problematic device so we know where to look at and post dmesg, cat /proc/bus/input/devices and in addition to that "lsusb" output on a non-working build?
so long,
Hias
