Guilouz is DTS-HD/TrueHD still working with your NUC5i5RYH and #0129? Since #0127 there are some playback issues so maybe test #0126 with your NUC7i7BNH - your audio issues might be unrelated but worth ruling out (btw I just tested a Skylake NUC6i5SYH with #0129 and DTS-HD/TrueHD is working fine).
(2018-01-30, 03:39)Milhouse Wrote: [ -> ]@Guilouz is DTS-HD/TrueHD still working with your NUC5i5RYH and #0129? Since #0127 there are some playback issues so maybe test #0126 with your NUC7i7BNH - your audio issues might be unrelated but worth ruling out (btw I just tested a Skylake NUC6i5SYH with #0129 and DTS-HD/TrueHD is working fine).
Yes all was working with NUC5i5RYH.
Just try #0126, same issue.
I have found this :
http://nucblog.net/2017/02/apollo-lake-a...mware-fix/
But I have already updated HDMI firmware to 1.72.
(2018-01-27, 15:23)Ontige Wrote: [ -> ]Hey Folks,
im having Problems playing a specific bunch of files since release 0123 while the build Prior that Plays the files just fine. My Setup is an NUC6CAYH and here is the log: Log
The file whats causing the error is a bunch of episodes of Black Sails...
Does anybody have a clue?
Greatings
Ontige
Possibly the same smb:// chunk size issue I've just run into - can you test #0129d and see if it is any better:
Generic
Only difference to #0129 is the use of a 64KB chunk instead of 2MB (
patch).
Weekly Linux 4.15 build #0129x:
Generic
Changes:
Replace out-of-tree RTL8192CU driver with in-tree kernel driver
Added Gemini Lake WLAN firmware
Drop 20180108 intel-ucode
Restore Intel SST support
gcc-7.3.0 with full retpoline/Spectre v2 mitigation
Packages disabled/not included:
bcm_sta
DVB Driver Addons
Packages added/updated:
RTL8192DU
RTL8192EU
RTL8188EU
RTL8812AU
RTL8192CU (in-kernel)
Also, 64KB SMB chunk size
Hey,
here is finaly the debug log. Sorry for my inconvinience...
Http://ix.io/EXu
Will also test the weakly and report back ASAP.
Thanks,
Ontige
€dit: The weekly build from Milhouse with the smaler Chunksize indeed was the Problem and those specific files are working again now. The interesting Thing is, that not all files have refused to work. The Major part worked well...
Ontige what is your Samba server - is it Windows 7, Windows 10, or a Linux based NAS? You're getting the same connection aborts due to 2MB chunk size that I experience with Windows 7 but not with non-Windows Samba servers (and fixed in #0129d and #0129x by using a 64KB chunk).
(2018-01-28, 22:07)Milhouse Wrote: [ -> ] (2018-01-28, 17:40)c--mas Wrote: [ -> ]@Milhouse: No further support from your side regarding my problem?
I had intended to ping my colleague, but real life intervened (and I forgot). Have pinged him now.
Hi :-) Just for your information. I´m also active on libreelec.tv forum to test the other Libreelec Build 8.x with dvb drivers and i found before 2 days another thread regarding dvb devices. So i wrote some posts about my device and make 2 pictures:
Hauppauge WinTV-Nova Picture 1
Hauppauge WinTV-Nova Picture 2
One of the user has also contact with the developer of the Haupauge drivers and he goes in contact with him. The device is unknown for him and he will try to fix it. I´ve just give them the hint, that i assumed my issue is already placed at him. So i think it´s the same developer. Sorry for that. I hope it´s okay and i think all of you are informed to avoid more work on it than needed :-)
New LibreELEC.tv Leia build #0130:
Generic
(Supercedes previous build)
SHA256 Checksum:
a7ea459d45ea048637621419dfed349ed8b7b988c3d465617ece4ac52496465e
(Generic)
text:
# uname -a
Linux NUC 4.14.15 #1 SMP Tue Jan 30 21:21:25 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180130211943-#0130-gb62a040 [Build #0130]
# Kodi version
(18.0-ALPHA1 Git:b33ba4d). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (b62a040,
changelog) and tip of
XBMC master (3cd7a7c,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (f6e51c3, ahead +115)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
- Include [env] compare (perma): kodi: reduce arm memory fragmentation
- Include [env] compare (perma): busybox: 2nd attempt at disabling busybox parallel build
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2382 (perma): linux: DVB fixes
- Include [env] PR:2384 (perma): kodi: updates for Feb 2018
- Include [env] PR:2432 (perma): buildsystem: avoid if/then/else boiler plate when accessing hierarchy [RFC]
- Include [env] PR:2454 (perma): config: enable CONFIG_BPF_SYSCALL and CONFIG_CGROUP_BPF
- Include [env] PR:2456 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.25
- Include [pkg] compare (perma): Updated RPi3/ZeroW(H) WiFi firmware (version 7.45.98.38) (forum, github) (brcmfmac_sdio-firmware-rpi)
- Include [pkg] patch: mesa: add missing POLARIS12 pci-ids (mesa)
- Include [pkg] patch: xorg-server: add missing POLARIS12 pci-ids (xorg-server)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13435 (perma): Fix broken ctrl+shift modifiers
Build Highlights:
- Add 64KB SMB chunksize to Kodi PR
- Add POLARIS12 pci ids
Build Details:
- LibreELEC.tv:
- v4l-utils: Add wetek_play_2 to libreelec_multi_amlogic (PR:2457, 1 commit, 2 files changed)
- XBMC:
- [cleanup][DllLoader] quicktime isn't used anymore (PR:13455, 2 commits, 3 files changed)
- compile fix (PR:13456, 1 commit, 1 file changed)
- [AML] compile fix (#13450) (df582f4)
- Updated: [env] PR:2384 (perma): kodi: updates for Feb 2018
- Added: [pkg] patch: mesa: add missing POLARIS12 pci-ids (mesa)
- Added: [pkg] patch: xorg-server: add missing POLARIS12 pci-ids (xorg-server)
Any idea of my issue Milhouse ?
I have re-installed a windows builds to test and passthrough is OK, issue only with LibreELEC.
(2018-01-31, 05:18)Guilouz Wrote: [ -> ]Any idea of my issue Milhouse ?
Nope. I'd have told you if I did.
Milhouse
Start at Build #0127,# 0128, #0129 & #0130 all 4K video files are only output as 1080p, until and with Build # 0126 this works fine and 4k media is output as 4k.
Thanks @
pacoma2610, yes it's been reported but I don't know when it will be fixed.
