Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
New LibreELEC.tv Krypton build #0107: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.1 #1 SMP Sat Jan 7 21:37:25 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170107213606-#0107-gc7cd1d4 [Build #0107]
# Kodi version
(18.0-ALPHA1 Git:5c40b5c). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (c7cd1d4a, changelog) and tip of XBMC master (2b073a7e, changelog) with the following modifications: Build Highlights:
  1. New 4.9.1 kernel
  2. Minor libcec and libnfs updates
Build Details:
  1. LibreELEC.tv:
    • settings: update githash for 0.8.7 (PR:1144, 1 commit, 1 file changed)
    • repo: correct minimum add-on version for ls.io repo (PR:1145, 1 commit, 1 file changed)
  2. XBMC:
    • Replace raw new/delete in Util with stack object (PR:11387, 1 commit, 1 file changed)
    • Add python scrapers (PR:9984, 3 commits, 13 files changed)
    • App Name for Windows OS is not reflected at APPDATA directory. (PR:11085, 1 commit, 1 file changed)
    • [cmake/win32] Don't use system wide installed dependencies (PR:11246, 1 commit, 1 file changed)
    • [Android] disable zeroconf (PR:11393, 1 commit, 1 file changed)
  3. libcec:
    • Install pkgconfig in arch-specific dir (PR:284, 1 commit, 1 file changed)
  4. libnfs:
    • Revert "socket: batch pdu read in function rpc_read_from_socket" (PR:162, 1 commit, 1 file changed)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1146: linux: update to linux-4.9.1
(2017-01-04, 23:26)Milhouse Wrote: [ -> ]You'll then need to remove the current patch for the nvidia-legacy package as the current patch is for 340.101. Not sure if the 304 driver needs any patches to build with the 4.9 kernel - hopefully not, but if so you'll need to add them in the patches folder.
just FYI - mtrr patch needs for 304 legacy drivers and recent kernel
https://forum.libreelec.tv/thread-3523-p...l#pid27187
New LibreELEC.tv Krypton build #0108: Generic
# uname -a
Linux NUC 4.9.1 #1 SMP Sun Jan 8 21:03:32 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170108210211-#0108-g9e4c5ea [Build #0108]
# Kodi version
Based on tip of LibreELEC.tv master (9e4c5ea8, changelog) and tip of XBMC master (ec07c1dc, changelog) with the following modifications: Build Highlights:
  1. Include media_build
  2. fluxbox: start applications maximized by default
  3. move back to DRI2
Build Details:
  1. LibreELEC.tv:
    • media_build for Generic and RPi (PR:1138, 6 commits, 12 files changed)
    • linux: update to linux-4.9.1 (PR:1146, 2 commits, 5 files changed)
    • fluxbox: start applications maximized by default (PR:1142, 1 commit, 2 files changed)
    • move back to DRI2 (PR:1093, 2 commits, 2 files changed)
    • scripts/create_addon: use PKG_REV as part of the binary addon version (PR:1025, 1 commit, 1 file changed)
  2. XBMC:
    • Replace raw new/delete inside CDVDFactorySubtitle (PR:11396, 3 commits, 14 files changed)
    • spelling: acquire (PR:11363, 1 commit, 4 files changed)
    • Replace raw new/delete with unique_ptr in GUIWindowSlideShow (PR:11398, 1 commit, 2 files changed)
  3. pvr.hts:
    • Don't reconnect immediately on register error (PR:274, 2 commits, 4 files changed)
How to add Games menu in home screen like Irusak builds?
(2017-01-09, 19:38)vali Wrote: [ -> ]How to add Games menu in home screen like Irusak builds?
Modify skin I believe
Try the Konami Code... works best with a keyboard or joystick. Smile
(2017-01-09, 23:36)Milhouse Wrote: [ -> ]
Took a couple trys but it does work! Big Grin
Hi Milhouse,
long time ago i reported kodi does instantly crash if i do an instant record in live tv with the option "ask what to do" in pvr settings.
Today i got some time and setup libreelec from scratch. in the first time of testing all works fine,but after a while the bug comes back.
Now i got the trick -> it's the language setting. if i set libreelec to english language all works fine -> choose german language in regional settings and the nice "ask what to do" option in pvr setting crashes kodi if you want to use it.
(2017-01-10, 02:13)schlumpfschlaubi Wrote: [ -> ]Hi Milhouse,
Can you upload your crashlog (see note #4 in the OP)
kodi.log
http://sprunge.us/NZFC
dmesg | pastebinit
http://sprunge.us/HTbM
journalctl -a | pastebinit
http://sprunge.us/SjFb
i did trigger instant record at 01:43:10
it also happens in other languages, for example french. only with english language i get the "instant recording action" windows instead of a crash
(2017-01-10, 02:51)schlumpfschlaubi Wrote: [ -> ]kodi.log
dmesg | pastebinit
Thanks. Hopefully a PVR developer can look into it.
@pvrdevelopers - if a debug-enabled crashlog would help, please shout and I'll get one uploaded so that schlumpfschlaubi can hopefully re-test.
New LibreELEC.tv Krypton build #0109: Generic
# uname -a
Linux NUC 4.9.2 #1 SMP Tue Jan 10 02:22:58 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170110022138-#0109-gf8d7242 [Build #0109]
# Kodi version
Based on tip of LibreELEC.tv master (f8d7242e, changelog) and tip of XBMC master (fa383a18, changelog) with the following modifications: Build Highlights:
  1. New 4.9.2 kernel
  2. Bump GUI ABI - this will break backward compatability with skins
Build Details:
  1. LibreELEC.tv:
    • RBP: enable SND_BCM2708_SOC_HIFIBERRY_AMP (PR:1151, 1 commit, 4 files changed)
    • imx6: update kodi patch (fix partially broken deinterlace) (PR:1152, 1 commit, 1 file changed)
  2. XBMC:
    • [gui] Bump GUI version ABI as we start to break backwards compatibility. (PR:11306, 2 commits, 4 files changed)
    • spelling: json (PR:11403, 1 commit, 2 files changed)
    • spelling: output (PR:11402, 1 commit, 7 files changed)
    • [PVR] PVRMananger::m_currentFile: CFileItem* -> CFileItemPtr. (PR:11397, 1 commit, 2 files changed)
    • [cmake] fixes cpack dependency list generation (PR:11370, 2 commits, 17 files changed)
    • spelling: paths (PR:11401, 1 commit, 1 file changed)
    • spelling: strings (PR:11406, 1 commit, 2 files changed)
    • spelling: DestroyDispmanxWindow (#11365) (2f1c47c9)
  3. pvr.hdhomerun:
    • Use correct channel number parsed from GuideNumber (PR:32, 0 commits, 0 files changed)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1153: linux: update to linux-4.9.2
Weekly Linux 4.10-rc3 build #0109x: Generic
Same as #0109, but without media_build extensions (not compatible with this kernel).
(2017-01-10, 03:45)Milhouse Wrote: [ -> ]
dmesg | pastebinit
This is actually a translation bug. The resource string was not translated correctly, interestingly for both German (de_DE) and French (fr_FR). All other languages I checked are okay. For German language I just fixed this in Transifex. For French I do not have the needed access priviledges. My fix will be avaliable with next Transifex update for Kodi.
Many thanks @ksooo!
