(2017-04-26, 20:19)Milhouse Wrote: [ -> ]@sw4y if you can narrow down the build when this started...
went back to build #1201 - still not working there, so as I said I think it's not a problem with your builds only.
IRW is giving me output as expected, but no reaction in kodi itself.
I'll open a new thread in the remote section, maybe that helps.
Running build #0426 I still get double presses on my remote, when LIRC is enabled in Libreelec-Settings, fyi.
*edit*
LIRC seems to work and OnKey-demands seem to be processed
Quote:17:31:42.118 T:139984956856384 DEBUG: LIRC: Update - NEW at 9902:6c 0 KEY_DOWN devinput (KEY_DOWN)
17:31:42.118 T:139984956856384 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
17:31:42.121 T:139984956856384 DEBUG: CDirectoryProvider[pvr://channels/tv/*?view=lastplayed]: refreshing..
17:31:42.122 T:139984956856384 DEBUG: CDirectoryProvider[pvr://recordings/tv/active?view=flat]: refreshing..
17:31:42.123 T:139984728225536 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/*?view=lastplayed)
17:31:42.126 T:139984845657856 DEBUG: CPVRDirectory::GetDirectory(pvr://recordings/tv/active?view=flat)
17:31:42.146 T:139984728225536 WARNING: CreateLoader - unsupported protocol(pvr) in pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_48.tbn
17:31:42.147 T:139984728225536 WARNING: CreateLoader - unsupported protocol(pvr) in pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_192.tbn
17:31:42.147 T:139984728225536 WARNING: CreateLoader - unsupported protocol(pvr) in pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_196.tbn
17:31:42.148 T:139984728225536 WARNING: CreateLoader - unsupported protocol(pvr) in pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_179.tbn
17:31:42.163 T:139984956856384 DEBUG: ffmpeg[7F50C9A09840]: [swscaler] Forcing full internal H chroma due to input having non subsampled chroma
17:31:42.873 T:139984956856384 DEBUG: Previous line repeats 3 times.
17:31:42.873 T:139984956856384 DEBUG: LIRC: Update - NEW at 10658:160 0 KEY_OK devinput (KEY_OK)
17:31:42.873 T:139984956856384 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
Kodi 18.0 Alpha bug?
(2017-04-27, 10:24)sw4y Wrote: [ -> ]Running build #0426 I still get double presses on my remote, when LIRC is enabled in Libreelec-Settings, fyi.
This means your remote presses are both decoded by the kernel and by lirc. In this case disable lirc in LE settings so that only in-kernel decoding is used. If needed you can change remote button configuration via ir-keytable (instead of lircd.conf) - see here for more details about it:
https://forum.libreelec.tv/thread-7152-p...l#pid43745
so long,
Hias
(2017-04-27, 13:26)HiassofT Wrote: [ -> ] (2017-04-27, 10:24)sw4y Wrote: [ -> ]Running build #0426 I still get double presses on my remote, when LIRC is enabled in Libreelec-Settings, fyi.
so long,
Hias
Thank you!
I knew that disabling LIRC solves the problem, but did not know, that also in-kernel decoding is used.
Remote works as expected with lirc disabled so I'm fine with it.
But still going for the details, thank you!
Why in the last versions there are no drivers for MSI C847MS-E33 (Intel Celeron 847, Intel NM 70, PCIe 2.0 x16), when updating the black screen? ; (
(2017-04-27, 21:36)sboa Wrote: [ -> ]Why in the last versions there are no drivers for MSI C847MS-E33 (Intel Celeron 847, Intel NM 70, PCIe 2.0 x16), when updating the black screen? ; (
Which is the last build that you are happy with? What drivers in particular are you missing in the latest build?
I do not remember anymore, I had to put alexelec, and on top of the multi-house, I do not remember the version, but 1-2 months ago
PS
LibreELEC-Generic.x86_64-9.0-Milhouse-20170417210430-#0417-ge271629
Afraid I can't really help without knowing what the problem is. Enable debug logging and then upload the latest zip file from your samba LogFiles directory. Do this for both alexelec and my latest build.
On Saturday and Sunday I'll try to experiment
How to attach a file?
Where is the log?
PS
I apologize for the translator, I do not speak English.
Do you speak Russian?
(2017-04-27, 21:50)sboa Wrote: [ -> ]PS
You're saying
#0417 is the last working build? The only noteworthy change in
#0418 is a minor kernel bump (and updated media_build). So now we need to know what is broken... your logfiles should reveal this.
(2017-04-27, 22:10)sboa Wrote: [ -> ]How to attach a file?
Where is the log?
Since Kodi isn't starting it's probably not worth enabling the Kodi debug log.
Upload your latest zip file from Logfiles:
Upload the zip file to Dropbox, Googledrive, One drive or whatever file hosting site you prefer to use (preferably one that isn't laden with ad-borne viruses). Then post a link to the download.
Repeat for both alexelec and the latest of these test builds.
New LibreELEC.tv Leia build #0427:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.13 #1 SMP Thu Apr 27 21:11:51 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170427210352-#0427-ga5bf4d2 [Build #0427]
# Kodi version
(18.0-ALPHA1 Git:91a9066). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a5bf4d28,
changelog) and tip of
XBMC master (69f4545b,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (1052ba94, ahead +58)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d), pvr.iptvsimple (e842a935, +1), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (d61c5013), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea), pvr.wmc (5aa3b1ca), vfs.rar (c3e051dd), vfs.sacd (bdfc8938), vfs.sftp (add60314)
- Exclude [env] ffmpeg-99.1010-tls-1.2.patch: upstream ffmpeg-3.3
- Include [env] compare: tvheadend42: update (pngquant)
- Include [env] compare: linux: update to linux-4.10.13
- Include [env] patch: vfs addons: add vfs.rar, vfs.sacd and vfs.sftp kodi-binary-addons
- Include [env] patch: ffmpeg: update to ffmpeg-3.3
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.2
- Include [env] PR:1567: kodi: bump kodi and binary add-ons to current
- Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:12004: changed: always expand iso images in music window
- Include [pkg] PR:12005: changed: remove internal sftp support
- Revert [pkg] PR:118: Remove not used part (reason: depends on unmerged PR12011) (pvr.iptvsimple)
Build Highlights:
- New 4.10.13 kernel
- connman: update to 1.34 and drop patches
- Kodi: Revert "DVDDemuxFFMPEG: Increase FFMPEG_FILE_BUFFER_SIZE to 128K"
- Drop incompatible pvr.iptvsimple bump
Build Details:
- LibreELEC.tv:
- connman: update to 1.34 and drop patches (PR:1569, 1 commit, 3 files changed)
- XBMC:
- AE: improve tempo filter (PR:12002, 1 commit, 5 files changed)
- Revert "DVDDemuxFFMPEG: Increase FFMPEG_FILE_BUFFER_SIZE to 128K" (PR:12013, 1 commit, 1 file changed)
- [buildsteps][windows] correct evaluation of make jobs (PR:12010, 1 commit, 3 files changed)
- [gui][refactor] add window id as arg to GetWindow template because window instance is not unique (PR:12003, 1 commit, 87 files changed)
- For addon created ListItems dont overwrite playcount data from DB (#11998) (27dc9a69)
- Reverted: [pkg] PR:118: Remove not used part (reason: depends on unmerged PR12011) (pvr.iptvsimple)
- Updated: [env] compare: linux: update to linux-4.10.13
@laric: can you test build #0427 and confirm if the
CU+ PVR addon continues to crash.
(2017-04-27, 23:24)Milhouse Wrote: [ -> ]@laric: can you test build #0427 and confirm if the CU+ PVR addon continues to crash.
It is working fine on #0427 and it is VU+/Enigma Pvr addon. My bad in writing the wrong one before.
Thanks for the help
Milhouse
1. install
2. Update
3. Backup your saved settings
New LibreELEC.tv Leia build #0428:
Generic
# uname -a
Linux NUC 4.10.13 #1 SMP Fri Apr 28 21:38:53 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170428213652-#0428-ga01c088 [Build #0428]
# Kodi version
Based on tip of
LibreELEC.tv master (a01c0887,
XBMC master (5e12c614,
- Include [env] PR:1571: createlog: bring sanity to kodi log order
- Include [pkg] PR:65: update language from transifex (service.libreelec.settings)
Build Highlights:
- AESinkAUDIOTRACK: Refactor and separate PCM and Passthrough Enumeration
- busybox: enabling CONFIG_FEATURE_USERNAME_COMPLETION
Build Details:
- LibreELEC.tv:
- busybox: enabling CONFIG_FEATURE_USERNAME_COMPLETION in busybox-targe… (PR:1572, 1 commit, 1 file changed)
- XBMC:
- guilib: only update container after condition changed (PR:12016, 1 commit, 2 files changed)
- AESinkAUDIOTRACK: Refactor and separate PCM and Passthrough Enumeration (PR:11997, 2 commits, 2 files changed)
- Added: [env] PR:1571: createlog: bring sanity to kodi log order
- Added: [pkg] PR:65: update language from transifex (service.libreelec.settings)
