Quote:Frequency requested 733
min hard:200, soft:200; max soft:756, hard:756
idle:200, efficient:400, boost:756
Xorg [441]: 0 boosts
kodi.bin [489]: 4 boosts
VideoPlayer [687]: 35 boosts
Kernel (anonymous) boosts: 3840
RPS Autotuning (current "high power" window):
Avg. up: 42% [above threshold? 90%]
Avg. down: 0% [below threshold? 70%]
So we see here, that VP boosts the GPU, but it sadly only upclocks when it uses > 90% and downclocks right away when using < 70%.
Try to echo 400 into that file and see if it already helps. If not try with 756. i915_min_freq
(2018-06-30, 19:46)fritsch Wrote: [ -> ]Quote:Frequency requested 733
kodi:~ # echo 400 > /sys/kernel/debug/dri/i915_min_freq
-sh: can't create /sys/kernel/debug/dri/i915_min_freq: Permission denied
(2018-06-30, 19:52)lwrcase Wrote: [ -> ] (2018-06-30, 19:46)fritsch Wrote: [ -> ]Quote:Frequency requested 733
You missed a directory in the path......
0/i915_min_freq
ah. my mistake.
setting it to 400 works! no more stutter/slowness.
will this stick after reboot?
A version with a newer kernel should fix that. There are some LE testbuilds here with 4.16 or later. Could you verify that?
i'm using #0629 which should have 4.17.3, issue still exists.
Just wanted to say that the min freq fix also worked for my Cubi N 8 GL.
Slightly out of sync on the audio but I’m sure that will get fixed in time.
Hello,
I am facing 2 issues on my NUC7PJYH:
1) No audio on TV
NUC7PJYH is connected to Philips 47PFL3007H/12 (somewhat old device) via HDMI. No issues with video at all, but no audio on TV through HDMI. It seems like the HDMI audio device is identified since there is a entry "PHL PHILIPS FTV on HDMI #0" in the audio output device section.
The NUC provides video + audio over the same HDMI cable when connected to a newer generation TV (Samsung). TV plays video + audio when connected to my old HTPC, so TV is not defect.
I assume this issue may be related to wrong codec or data format for audio negotiated between NUC and TV. Is there a way to force audio to a basic/native format?
2) IR remote control stops working after some inputs
I configured my Harmony 300 as MCE remote and first key press works out of the box. But after a few key presses (4-6) remote control via IR stops working. Seems like CIR in the NUC is disconnected but I do not find anything related in the logs.
Any ideas?
I am on latest BIOS and build #0629 on the NUC.
Logs:
http://ix.io/1fAi
(2018-07-01, 00:54)phunkyfish Wrote: [ -> ]Just wanted to say that the min freq fix also worked for my Cubi N 8 GL.
This also works on Apollo lake soc, lest few builds have some problems running hevc rips and gave some stutter, changed the gpu min freq to the max(700-Mhz) and no problems, even high bitrate uhd bluray like pacific rim2 with 108Mbit/s avg. works now flawless.
(2018-06-30, 03:41)phunkyfish Wrote: [ -> ] @Milhouse should I be getting a J5005 unit or would a J4005 be sufficient?
I can't in good conscience recommend buying anything from Intel right now as all recent hardware generations have potentially major problems of one kind or another (it just seems to be pot luck if you're affected or not), may not do 4K (older but more reliable generations), or won't ever do HDR (including the latest generations, even once the software side of things is fixed).
I can't recommend Nvidia either, given the uncertainty over long term Kodi support.
This leaves only AMD, either a discrete GPU or Ryzen+Vega APU, which as far as I'm aware seems to be working quite well, with few if any problems, without all the workarounds, kludges and fixes that Intel needs.
So if you're dead set on investing a significant sum of money on x86 hardware, I'd be looking at AMD.
New LibreELEC.tv Leia build #0630:
Generic
(Supercedes previous build)
SHA256 Checksum:
ed1ce612a0783915093e7f838112e8513c68c745372580dfb5a76bca695e0f8d
(Generic)
text:
# uname -a
Linux NUC 4.17.3 #1 SMP Sat Jun 30 21:04:41 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180630210315-#0630-g3e3cc3d [Build #0630]
# Kodi version
(18.0-ALPHA3 Git:95de5f5). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (3e3cc3d,
changelog) and tip of
XBMC master (8063088,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (fa6d63c, ahead +1)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (6f01a4b, +3), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.52
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2801 (perma): mesa: only build va tracker if using a gallium driver that uses it
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2805 (perma): ffmpeg: install ffmpeg from ffmpeg-tools, don't include in image
- Include [env] PR:2807 (perma): linux (RPi): disable IR timeout improvement on Formosa e017 receiver
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- AESinkPULSE: Fix enumeration callback
- Fix ocassional playback in background
- VideoPlayer: fixes for discarding streams
Build Details:
- XBMC:
- AESinkPULSE: Fix enumeration callback (PR:14133, 1 commit, 1 file changed)
- Fix ocassional playback in background (PR:14130, 1 commit, 1 file changed)
- VideoPlayer: fixes for discarding streams (PR:14127, 1 commit, 2 files changed)
Is anything new about that subtitle problem?
(2018-07-01, 08:29)Bromor Wrote: [ -> ]2) IR remote control stops working after some inputs
You are not alone, this seems to be a general problem with the newer NUCs.
https://forum.kodi.tv/showthread.php?tid...pid2734278
Not exactly sure what causes this issue or if/when it will be fixed.
It's probably easiest to just buy an MCEUSB IR receiver (the HP branded ones you can find on ebay for about 10 USD work fine) and use that instead of the built-in IR receiver.
Quote:Any ideas?
Stay away from current-gen NUCs :-)
so long,
Hias
I just fresh installed latest build. I cant install any addon from official repo and not even install new language. My internet connection works fine. Here is logfile:
https://pastebin.com/E9zn0JpZ
