Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
New LibreELEC.tv Leia build #0716: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.12.2 #1 SMP Sun Jul 16 23:48:31 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170716234603-#0716-gd8db9d5 [Build #0716]
# Kodi version
(18.0-ALPHA1 Git:734cda1). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (d8db9d5b, changelog) and tip of XBMC master (bfeb2e9d, changelog) with the following modifications: Build Highlights:
  1. New 4.12.2 kernel
  2. Fix black screen when playing games
  3. inputstream.adaptive updates
  4. udev cleanup
Build Details:
  1. LibreELEC.tv:
    • system-tools: update addon (PR:1734, 18 commits, 31 files changed)
    • linux: update to linux-4.12.0 (PR:1629, 40 commits, 33 files changed)
  2. XBMC:
    • [mediamanager] Use meta data provided disc names and add Blu-ray detection. (PR:12488, 5 commits, 5 files changed)
    • [swig] Partially revert 71151fe2b9. Causes problems with swig < 3.0 (PR:12490, 1 commit, 20 files changed)
    • VideoPlayer: reset dataCacheCore when new player is created (PR:12505, 1 commit, 3 files changed)
    • added: SortByDateAdded in Music Video title node (PR:12495, 1 commit, 1 file changed)
    • exit GIL when calling into GUI (PR:12504, 1 commit, 6 files changed)
    • [cmake][linux] Fix CodeCoverage.cmake path (PR:12509, 1 commit, 1 file changed)
    • Update README.android (e35ea401)
  3. inputstream.adaptive:
  4. pvr.mythtv:
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] compare: linux: update to linux-4.12.2
    • Added: [env] patch: scripts/image: hack to resolve nvidia.ko symbols
    • Added: [env] PR:1800: udev: cleanup
    • Added: [pkg] PR:12507: RetroPlayer: Fix black screen when playing games
Hello, I was using the kernel module lirc_xbox until build #0712. In the next builds (including #0716) I can't found the kernel module Sad Has the linux kernel drop his support for this module? (lirc_xbox is the usb support for the original xbox ir receiver).
Thanks in advance.
Yes, LIRC support is changing in favour of in-kernel support, and we've disabled LIRC_STAGING in the latest builds which disables LIRC_XBOX support. As I understand it this is going to happen by default in 4.13. Not sure if there's anything that can be done to reverse this - maybe time to get a new IR receiver - 15 years isn't a bad run...
Hello Milhouse, is it possible, that your inpustream did not accept other decrypter? I will use my Sky Ticket addon (https://www.kodinerds.net/index.php/Thre...post393896) and must use a decrypter. But InputStream Adaptive say it found no decrpyter
ERROR: AddOnLog: InputStream Adaptive: No decrypter found for encrypted stream
With oficial Version 8.0.2 it run very nice.
Did you install the widevine decrypter library? I know Netflix and Amazon are working but I've no idea about Sky. A lot has changed between Kodi 17 in 8.0.2 and Kodi 18 in these builds.
(2017-07-17, 21:42)Mister XY Wrote: [ -> ]I make this
https://www.kodinerds.net/index.php/Thre...post333953
I have no idea what those instructions relate to (they're seriously out of date for a start) but those instructions are not what you need to do to install the Widevine library and at least get Netflix and Amazon working with these test builds - just follow the instructions in Note #6 of the first post in this thread. Although now that you've already done weird things on your system I'd suggest you run "rm -fr /storage/.kodi/cdm" before following the instructions in Note #6.
Alternatively, if you're following installation guides on Kodinerds then you should get your support from Kodinerds - I can only give you support for what is provided in this thread.
Ok with your instruction it's run very nice. Thanks.
I did not see your indruction before.
New LibreELEC.tv Leia build #0717: Generic
# uname -a
Linux NUC 4.12.2 #1 SMP Mon Jul 17 21:06:26 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170717210504-#0717-gd8db9d5 [Build #0717]
# Kodi version
Based on tip of LibreELEC.tv master (d8db9d5b, changelog) and tip of XBMC master (84cd8cdf, changelog) with the following modifications:
  • Includes latest kodi-platform master (36fb4937)
  • Includes latest libcec master (f2c4ca77, ahead +24)
  • Includes latest libnfs master (df94ae93, ahead +56)
  • Includes latest p8-platform master (fe904839)
  • Includes latest addons: inputstream.adaptive (af04e438, +7), inputstream.rtmp (39d7979a), peripheral.joystick (6e18bc74, +4), pvr.argustv (4e8c838b), pvr.demo (f67dff13), pvr.dvblink (640629ca), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (48868e44), pvr.hts (1653a3a7), pvr.iptvsimple (8ccf85cc), pvr.mediaportal.tvserver (642f9af1), pvr.mythtv (3417026f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (12d629c4), pvr.vdr.vnsi (3473225b), pvr.vuplus (55e4f5f9), pvr.wmc (1d655540)
  • Include [env] compare: kodi updates
  • Include [env] compare: linux: update to linux-4.12.2
  • Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
  • Include [env] patch: scripts/image: hack to resolve nvidia.ko symbols
  • Include [env] patch: tvheadend42: fixup ffmpeg patch
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
  • Include [env] PR:1726: [WIP] lirc: update to 0.10.0
  • Include [env] PR:1773: init: make break after behaviour really break after
  • Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
  • Include [env] PR:1791: nss/nspr: include in main image [rfc]
  • Include [env] PR:1800: udev: cleanup
  • Include [env] PR:1801: addons: remove duplicated install code
  • Include [env] PR:1802: v4l-utils: fix racy udev rule
  • Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
  • Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
  • Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
  • Include [pkg] PR:12507: RetroPlayer: Fix black screen when playing games
  • Include [pkg] PR:12513: Fix several settings that broke after the last few ServiceManager refactorings
Build Highlights:
  1. kodi: [linux] treat rbpi as linux not a separate platform
  2. Fix several settings that broke after the last few ServiceManager refactorings
Build Details:
  1. XBMC:
    • [xbmc][depends][win32] Fix python that broke in #12502 (PR:12512, 1 commit, 7 files changed)
    • [xbmc][win32] Fix a crash for subtitle rendering in 4k on amd cards (PR:12516, 1 commit, 4 files changed)
    • [linux] treat rbpi as linux not a separate platform (PR:12021, 14 commits, 55 files changed)
    • [VideoPlayer] WinRenderer: re-work video rendering (PR:12475, 27 commits, 47 files changed)
    • Fix 3d mode switching for Wetek HUB on Libreelec (PR:12316, 2 commits, 5 files changed)
  2. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1801: addons: remove duplicated install code
    • Added: [env] PR:1802: v4l-utils: fix racy udev rule
    • Added: [pkg] PR:12513: Fix several settings that broke after the last few ServiceManager refactorings
Hey,
I`m using an Intel Apollo-Lake NUC in combination with a pulse-eight internal CEC adapter (firmware v7). CEC is working fine except the fact, that I can`t open the cec-settings under input-settings. Is this behavior known to somebody?
If needed, i can help logfiles.
Thanks in advance,
Manuel
(2017-07-15, 11:35)qwerty0987654321 Wrote: [ -> ]Milhouse,
pls consider including in your build workaround patch
https://trac.kodi.tv/attachment/ticket/1...w-wh.patch
for issue https://trac.kodi.tv/ticket/17516 , at least until it's fixed properly.
(2017-07-15, 19:27)Milhouse Wrote: [ -> ]I'd rather not include patches that aren't pushed (ie. don't exist as a pull request - if you do that, then you can have a conversation with the developers about the fix), and I'm also not keen on patches that are hacks as that just results in even less support for these builds.
I will however include it in a one-off test build, then you can give feedback on the ticket or progress with a pull request.
Build #0714x: Generic
@Milhouse,
Sorry for the late reply, had some days off.
Build 0714x fixes the problems for me.
Can you tell me how to "progress with a pull request" as I found that trac tickets are not always working as I suspect (posted the same problem (https://trac.kodi.tv/ticket/17477) in May and no one responded).
Blush I asume you're very busy and I've no idea how much work is involved, but Is it possible to create just one more patched build now Libretro and Netflix are working for x86 and RPI2? Blush
(2017-07-18, 16:51)rudrood Wrote: [ -> ]
@Milhouse,
Unfortunately, I don't have time to deal with pull req.
Feel free to apply patch and submit pull req.
For that you'd need clone https://github.com/xbmc/xbmc repository and then clone your repo locally, apply patch to local repo, then push change to github and send pull request to https://github.com/xbmc/xbmc from there.
Milhouse: Is Nvidia fix planed for the problem that you have also experienced (black screen when sync to display is selected)?
TNX
Thanks Milhouse for this build. Been using it on one of my kodi boxes in my home for a couple of days now. Is it possible to use a normal keyboard to control emulated games? It does not seem to work...
(2017-07-18, 20:13)illiac4 Wrote: [ -> ]Milhouse: Is Nvidia fix planed for the problem that you have also experienced (black screen when sync to display is selected)?
TNX
I've opened a ticket. https://trac.kodi.tv/ticket/17545
