Blurayx - Great! Glad we got that one figured out.
VikkiXavier - Nice idea. Was really simple to implement, so I've added it on latest git.
(2018-03-04, 08:52)jurialmunkey Wrote: [ -> ]@VikkiXavier - Nice idea. Was really simple to implement, so I've added it on latest git.
Wow you re quick indeed. Many thanks. It doesn't seem to appear for TV shows. Could you fix that please. Also, any ideas about using plot outline instead of summary?
(2018-03-04, 09:25)VikkiXavier Wrote: [ -> ] (2018-03-04, 08:52)jurialmunkey Wrote: [ -> ]@VikkiXavier - Nice idea. Was really simple to implement, so I've added it on latest git.
Ah that is strange. Kodi doesn't return the path to the tvshow with ListItem.Path for some reason. However, I worked out a dirty hack.
Will only work at tvshows and seasons level, not the episodes level (nothing I can do about that).
I use ListItem.Plot because some scrapers don't provide outline.
about default widgets... any chance for videos and photos sources widget ? (because i didn't manage to make my custom ones to work, see post #91 )
(2018-03-04, 10:30)chrispe Wrote: [ -> ]about default widgets... any chance for videos and photos sources widget ? (because i didn't manage to make my custom ones to work, see post #91 )
Done.
Default Widgets > Other > Video Sources / Music Sources / Picture Sources
Thank you for the addition but same behavior, I cant understand why the same widgets work fine on horizon and not on this skin.
(2018-03-04, 13:14)chrispe Wrote: [ -> ]Thank you for the addition but same behavior, I cant understand why the same widgets work fine on horizon and not on this skin.
They work perfectly for me.
Is there a plausible way to add games from rom collection browser to the main menu as a widgey?
(2018-03-04, 13:18)joeyd2424 Wrote: [ -> ]Is there a plausible way to add games from rom collection browser to the main menu as a widgey?
I don't use RCB, But with AEL Advanced Emulator Launcher I use this setup..
Skin Settings > Home > Customize Home Menu
On the Edit Shortcut tab > Submenu > Action > Add-on > Programs > AEL (Rom Collection Browser somewhere there hopefully)
Hope this helps!
When I enter info dialog from widgets, the "Images" section do not show up. Maybe it can be corrected?
When I try to play any of the episodes from info dialog of TV shows (from
next up section), instead of playing the episode it takes me to ExtendedInfo page and returns blank information. Could you perhaps modify it to make it play.
ANOTHER THING....
AEON MQ7 uses this cool feature that lets its users to stay attached to the
feel of the skin (in the background) while playing trailers. You could implement this feature.
I am seeing odd behavior with widget fan-art.
Widget fan-art for “Movies” takes 8-10 seconds to display. Even if I limit widgets to 10.
TV shows however display fan-art in a second or less, even if set to unlimited.
I am tested this with only one widget used for each menu -tvshows and movies.
I tried updating the library and removed an reinstalled all Aura related files from the userdata folder.
Anyone else seeing this?
Thank you
