(2021-10-27, 16:46)Doeloe Wrote: [ -> ]Got the Auro Mod installed but get frequently a pop up about Youtube acces not installed. Can I get rid of this? Trailers play fine.
Sounds like you didn't install youtube correctly, or have the old one installed. Make sure you setup the api keys correctly for youtube/account and it should work.
If I could find an official link to give you on the process I would, but I can't find one atm sorry. Google might help for that though
good day. I have a problem. I would like to change the default view from 50 to 500. Does anyone happen to know what exactly I need to change? in which file and what exactly. I can't find anything there. please help me.. Mfg
sorry for my bad English. I use google translator
Chalklands
I honestly hate to suggest it but jurialmunkey might have some answers, since it's through his plugin you do that in.
I DO suggest going through his wiki prior to posting an issue, he's pretty thorough:
https://github.com/jurialmunkey/plugin.v...elper/wiki
If you find out, please try to post it in here or contact me in some type of way.
I definitely would like to know.
If I ever find out, I'll do the same.
Heya!
I love aura mod with Netflix Style. I've been using it as my daily driver for sometime now. Recently I acquired a TV with bad gray uniformity tho, and I wonder if there is a way to change the dark gray background to black or other colors?
(2023-02-06, 09:33)teamrocket Wrote: [ -> ]Heya!
Yeah as far as I know you can:
Go into Settings > Skin Settings > Color >:
I think the setting you're looking for is `Background overlay color`
I could be wrong though, if I am please post a picture so I see where you're talking about exactly.
hi. I can't find any amount for the auramod skin. that's why I'm just asking here. maybe someone can tell me what the widget settings are for. it's about ... (widget info slide) and about (widget showcase overlay). what do they do? when i activate it i see no difference.
