Full Version: Aura
Screenshots
watch gallery
https://imgur.com/a/tFkQH
Hey everyone. So I've been putting most of my spare time for skinning into the creation of a new skin. Yes, another one! Although, this time it is more a mashup/mod of my existing skins rather than starting from scratch. It combines the basic stylistic elements of Horizon with the text-centric minimalism and rounded edges of Arctic. So it's basically a minimalist version of Horizon. I have also tried to ensure that mouse/touch is supported in most sections (for home widgets there is an option in Skin Settings > Home to enable mouse support). The final skin will have themes for both round and square corners.
Dependencies
kodi.leia
script.skinshortcuts
script.skin.helper.service
script.extendedinfo
script.image.resource.select
plugin.program.autocompletion
resource.images.studios.white
resource.images.moviegenreicons.transparent
Please Note
There are additional supported addons which can be installed from Skin Settings > Manage Dependencies. Whilst they aren't necessary, I do recommend installing any you don't have for the full experience.
The horizon genre icon pack is supported, so I also recommend installing it:
https://github.com/Swageroni/resource.im...ns.horizon
RottenTomatoes and Metacritic Setup via SkinHelper and OMDB api
1. Install the beta version of skin helper from marcelveldt's beta repository (and update all relevant dependencies e.g. metadatautils and simplecache).
https://github.com/kodi-community-addons...-1.0.1.zip
2. Go to omdb and get an API key. If you are lucky you can get a free key, but please consider donating to omdb via Patreon to keep omdb alive
http://www.omdbapi.com/apikey.aspx
3. Once you have an API key, go to Skin Settings > Manage Dependencies and click "script.module.metadatautils" to open it's settings
4. Go to the API section of the settings and enter your omdb api key, then press OK to save your settings.
5. Close Kodi and delete simplecache.db from kodi/userdata/addon_data/script.module.simplecache/simplecache.db - this step is not necessary, but it will force skin helper to rebuild its info cache and retrieve the ratings.
6. Open kodi and your ratings should now work. It can take a little while for skin helper to retrieve ratings for the focused item the first time around, so make sure you give it a little bit of time before reporting problems.
7. SkinHelper is heavily rate limited if you do not also have api keys for TMDb and Fanart.tv - I recommend also getting api keys for these.
Download - Leia
Aura is on the Official Kodi Leia Repo.
Development is at:
https://github.com/jurialmunkey/skin.aura
Download - Krypton
https://github.com/jurialmunkey/skin.aura/tree/Krypton
Please note that the Krypton branch is no longer being developed. Current development is on the master branch (v18 Leia).
Excellent name for a skin. I'm going to give it a test drive right now!!!!  Big Grin
You are forcing me to use a 3rd skin...
@jurialmunkey
 I'm liking the skin so far, Navigation is very smooth  Smile
In Horizon there is an option to hide Display submenu as categories widget. will this option be added to Aura?
BUG REPORT
When I select whether widget I can not tab down or use arrow keys to save. I have to use the mouse.
Looks awesome mate!
beautiful skin thx for sharing it Cool
i hope it will be available on the official repo or a personal repo soon
may you add arial font like in Horizon
thx
@Edworld - Haha! Big Grin Though I'm thinking of this more as a companion skin to Horizon. I wanted to make it an option in Horizon, but the changes became too complex so it became much easier to manage as a separate skin. It's basically a more minimalist, mouse-centric version (though it might diverge more as time goes on).
@Blurayx - Added an option to hide the submenu widget. However, there isn't currently any alternative method to display the submenu - still trying to think of solution. The "save changes" in the customisation screen isn't actually necessary any more. You can just press back now. Fixed the navigation issue nonetheless. Also removed the text and changed the button to say "Close" rather than "Save".
@sualfred - Thanks! Big Grin
@Zombi - Thanks! Arial fontset added.
@jurialmunkey
Smile
Request 1: Would it be possible to add minimal busy loader
Request 2: please stop making amazing skins lol  Big Grin
I really like the Horizon/Arctic concept, it's the best of both worlds. Also, I like the new improved splash screen logo but I think it would look better without Krypton.Smile
@jurialmunkey
You highlighted that Next Aired is not properly skinned yet. does it include widgets(tv shows airing today) not displaying on the home screen?
@Blurayx
Minimal busy loader added.
I personally like the "krypton" part on the splash. Though I will probably add an option to select your own splash screen in the future.
Next Aired widgets should work fine if they work in Horizon. I don't have any episodes airing today, so can't really test. How did you set the widget? Through the "Skin Helper Default Widgets" section, or through the "Add-ons" section? Can you try the other way around (e.g. if you set it from default widgets, try going instead through Addons > Video Addons > Skin Helper > Episodes) - I remember there being this issue previously and that was the solution iirc.
(2018-02-17, 08:16)jurialmunkey Wrote: [ -> ]@Blurayx
Thanks for adding minimal busy loader  Smile
Unfortunately Addons > Video Addons > Skin Helper > Episodes) didn't work
Next aired widgets work fine with Horizon. I also have recently added TV shows selected.
Horizon
Aura: Widgets show for a few seconds then disappears(Currently I have no Episodes Aring today until Monday)
A few seconds later
"Recently added TV shows" works for TV Shows
I hope this is not  too confusing
@jurialmunkey
Not sure if it's intentional. In the settings menu, the add-on icon is missing
(2018-02-17, 10:50)Blurayx Wrote: [ -> ]
(2018-02-17, 08:16)jurialmunkey Wrote: [ -> ]Deleted
