(2022-12-14, 07:06)Klojum Wrote: [ -> ] (2022-12-14, 01:24)Basje Wrote: [ -> ]Did you update Widevine on your Kodi install? Retrospects install the InputStream Adaptive Helper add-on. Use it to update Widevine and let me know.
Does that helper add-on also work on Raspberry Pi 4 setups, because LibreELEC for is currently useless without a working widevine version. Is there even a working one for RPi4? Because it doesn't seem to update by itself anymore.
It should. You make sure you have the latest version of the helper-addon and then run it and manually install WideVine.
(2022-12-14, 13:22)Basje Wrote: [ -> ]It should. You make sure you have the latest version of the helper-addon and then run it and manually install WideVine.
"Hey Mike, this is amazing!!1!"... ( in true infomercial speak). It apparently did the trick, although it needs a 1.2GB download first
Just wish I had known about the helper add-on sooner. Oh well, better late than never. Thanks again.
EDIT: it seems I need to update Widevine for every Kodi profile..?! Or can I simply copy certain files over?
(2022-12-14, 14:44)Klojum Wrote: [ -> ] (2022-12-14, 13:22)Basje Wrote: [ -> ]It should. You make sure you have the latest version of the helper-addon and then run it and manually install WideVine.
Great to hear that. The 1.2 GB download sucks, been there, done that. But it solves problems with Widevine. Enjoy Retrospect.
(2022-12-14, 14:47)Basje Wrote: [ -> ]Great to hear that.
(2022-12-14, 14:44)Klojum Wrote: [ -> ]EDIT: it seems I need to update Widevine for every Kodi profile..?! Or can I simply copy certain files over?
Our posts crossed each other... One more helping hand please?
My RPi has some 4 profiles (for testing stuff).
(2022-12-14, 15:00)Klojum Wrote: [ -> ] (2022-12-14, 14:47)Basje Wrote: [ -> ]Great to hear that.
Yes, it will need to update it for each profile (I think). But you can just copy them over.
Okay... and what's the default location for that to copy from?
(I'm lazy today)
(2022-12-14, 15:07)Klojum Wrote: [ -> ]Okay... and what's the default location for that to copy from?
(I'm lazy today)
That you can find in the Helper add-on.
(2022-12-14, 01:24)Basje Wrote: [ -> ] (2022-12-12, 15:54)WeirdH Wrote: [ -> ] (2022-12-11, 18:12)Basje Wrote: [ -> ]Let me know if the problem comes back, then I will double check Retrospect.
My problem hasn't even gone away yet. How long does something like that usually take if it actually IS a fault on the provider's or server's end? A day? A week?
Manual update didn't do anything, but my wife said she got prompted to accept new Google-terms or something, that also mentioned Widevine. She accepted and now everything works again.
(2022-12-14, 18:38)WeirdH Wrote: [ -> ] (2022-12-14, 01:24)Basje Wrote: [ -> ] (2022-12-12, 15:54)WeirdH Wrote: [ -> ]My problem hasn't even gone away yet. How long does something like that usually take if it actually IS a fault on the provider's or server's end? A day? A week?
Nice! Thank your wife and enjoy Retrospect.
Somehow Swedish Tv4 programs ain't got sound any longer..Any fix for this?
(2022-12-16, 23:45)Basje Wrote: [ -> ] (2022-12-16, 23:20)Blommen Wrote: [ -> ]Somehow Swedish Tv4 programs ain't got sound any longer..Any fix for this?
https://github.com/retrospect-addon/plug...ssues/1662 Working on it. Test the patch there.
Now the sound on TV4 programs works again!
(but there is some strange numbers under the subtitles, but thats not a big deal for me)
