Full Version: Retrospect v5.5.x Video Add-On
dahlSTROM Wrote:How's it going with TV4? Is it fixable?
This issue is caused by the stream type (some strange RTMPE version). I can't fix that at the moment, it should be fixed in XBMC.
Basje Wrote:I checked: both "Keuringsdienst van Waarde" and "De wereld draait door" have the same quality for my XBMC. So I don't know what is wrong with your version. Please note that only the BETA UZG channel has high quality streams, not the normal NED1,2&3.
Could you provide an uzg.log (or uzgplugin.log) after playing back both episodes?
I can reproduce this issue and will look into it. It is strange.
My fault. I know what happened, I watched the Keuringsdienst van Waarde in BETA and DWDD in normal NED3. Didn't knew there was a significant difference in these channels.
Thanks anyway!
Mart. Wrote:My fault. I know what happened, I watched the Keuringsdienst van Waarde in BETA and DWDD in normal NED3. Didn't knew there was a significant difference in these channels.
Thanks anyway!
The NOS fix is in the Repository and should be updated by XBMC (on non-xbox versions). On xbox the auto update feature should be used.
EDIT: So is a fix for the RTL channel that was also broken.
Hi
I just noticed your excellent plugin!!
Do any of you know why I cannot get the Belgian channel Een to start playing?
I am in Denmark, so I am thinking that it might be due to geo-blocking? Or maybe it is somehing else?
Any help/information is appreciated, as my wife is eager to start watching some programs from home :-)
Thanks,
anwha
anwha Wrote:Hi
Thanks,
anwha
Could you please post a complete uzg.log or uzgplugin.log on pastebin.ca?
EDIT: I think I fixed it: Een changed their stream URL's. I updated the channel (also fixed another small bug) and it's in the repository. Read here how to update it: How to update
Basje Wrote:Could you please post a complete uzg.log or uzgplugin.log on pastebin.ca?
Hi again
here is the uzg.log: http://pastebin.com/vWfJpYaG
and the uzgpluginlog: http://pastebin.com/qHwGuRWj
Thanks for the help
anwha Wrote:Hi again
Thanks for the help
This issue is the one I just fixed. So after the update, they should be working.
Basje Wrote:This issue is the one I just fixed. So after the update, they should be working.
hi again
I appreciate the efforts but neither addon or program will play the Een programs after the updates.
new uzg log: http://pastebin.com/58M5wViw
new plugin log: http://pastebin.com/ty4Kq1DH
thanks again
anwha Wrote:hi again
thanks again
Well, that is because you did not update anything! From your logfile:
Loading net.rieter.xot.channel.be version 3.2.10.0
Loading net.rieter.xot.channel.mtg version 3.2.10.0
Loading net.rieter.xot.channel.mtv version 3.2.10.0
Loading net.rieter.xot.channel.nick version 3.2.10.0
Loading net.rieter.xot.channel.nos version 3.2.10.0
Loading net.rieter.xot.channel.regionalnl version 3.2.10.0
Loading net.rieter.xot.channel.rtlnl version 3.2.10.0
Loading net.rieter.xot.channel.sbsnl version 3.2.10.0
Loading net.rieter.xot.channel.se version 3.2.10.0
Loading net.rieter.xot.channel.streams version 3.2.10.0
Loading net.rieter.xot.channel.videos version 3.2.10.0
The net.rieter.xot.channel.be should be version 3.2.10.1, the net.rieter.xot.channel.nos should be version 3.2.10.1 and the net.rieter.xot.channel.rtl should be version 3.2.10.2.
So my question would be: how did you update? You can't download the main version again! Channels need to be updated using the XBMC Addon Manager. It should tell you there are updates.
The new channel updates will only be included in the next XOT version.
See here: http://www.rieter.net/pages/XOT:FAQ#How_...hannels.3F
Basje Wrote:Well, that is because you did not update anything! From your logfile:
I have updated through XBMC add on center. In my video add ons I have
- XOT-Uzg.v3 Belgium Channels enabled and in version 3.2.10.1
But when I go to my video add ons, I can only see the general XOT-Uzg.v3 in version 3.2.10. The Belgium one is missing. Do you have any idea if it should be that way? My guess is that I haven't enabled them correctly, for some reason.
In my pastelog it says that I am still running 3.2.10. for Belgian channels. Weird when I have enabled the Belgian 3.2.10.1
I have no idea what to do. Thanks for helping out a noob
A
anwha Wrote:Thanks
A
They will not show up as separate addons. Just open XOT-Uzg and it will use the updated versions.
@Basje iRTL does not seem to work for me; any program I try to open fails, this is what's in my log (if it helps):
tail: uzgPlugin.log: file truncated
20110918 18:02:58 - [1789MB] DEBUG    - settings.py          - 123  - Loading Settings into static object
20110918 18:02:58 - [1789MB] WARNING  - settings.py          - 130  - Settings :: Cannot use xbmcaddon.Addon() as settings. Falling back to  xbmcaddon.Addon(id)
20110918 18:02:58 - [1789MB] DEBUG    - channelimporter.py   - 282  - Checking for new channels to deploy
20110918 18:02:58 - [1789MB] INFO     - plugin.py            - 85   - *********** Starting XOT-Uzg (XOT-Uzg.v3) plugin version v3.2.10 ***********
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - Plugin Params: chn_rtlipad.py[[#]][[#]]KGltZWRpYWl0ZW0KTWVkaWFJdGVtCnAwCihkcDEKUydyYXRpbmcnCnAyCk5zUydfTWVkaWFJdGVt
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | X19kYXRlJwpwMwpTJzIwMTEtMDktMTgnCnA0CnNTJ3RodW1iVXJsJwpwNQpTJ2h0dHA6Ly93d3cu
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | cnRsLm5sL3N5c3RlbS9jb3Zlci9pcGFkLzE5NTA2OScKcDYKc1MnZGVjb2RlcicKcDcKKGloZWxw
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | ZXJzLmVuY29kaW5naGVscGVyCkVuY29kaW5nSGVscGVyCnA4CihkcDkKUydlbmNvZGVyJwpwMTAK
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | Uyd1dGYtOCcKcDExCnNnNwpnMTEKc2JzUyd0aHVtYicKcDEyCmc2CnNTJ3BhcmVudCcKcDEzCk5z
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | Uyd1cmwnCnAxNApTJ2ZpbGU6L2hvbWUveGJtYy8ueGJtYy91c2VyZGF0YS9hZGRvbl9kYXRhL25l
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | dC5yaWV0ZXIueG90L2NhY2hlL3J0bGNhY2hlLnhtbD8xOTUwNjknCnAxNQpzUydpdGVtcycKcDE2
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | CihscDE3CnNTJ2Rlc2NyaXB0aW9uJwpwMTgKUycnCnAxOQpzUydNZWRpYUl0ZW1QYXJ0cycKcDIw
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | CihscDIxCnNTJ2NoYW5uZWxzJwpwMjIKKGxwMjMKc1MnZG93bmxvYWRlZCcKcDI0CkkwMApzUydj
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | b21wbGV0ZScKcDI1CkkwMApzUydkb3dubG9hZGFibGUnCnAyNgpJMDAKc1MnX01lZGlhSXRlbV9f
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | dGltZXN0YW1wJwpwMjcKY2RhdGV0aW1lCmRhdGV0aW1lCnAyOAooUydceDA3XHhkYlx0XHgxMlx4
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | MDBceDAwXHgwMFx4MDBceDAwXHgwMCcKcDI5CnRwMzAKUnAzMQpzUydlcnJvcicKcDMyCkkwMApz
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | UydndWlkJwpwMzMKUydCQUQwRkMxM0Q2REQ1MTY5MjkxMDMxMkYxN0QwRUMwQi1maWxlOi9ob21l
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | L3hibWMvLnhibWMvdXNlcmRhdGEvYWRkb25fZGF0YS9uZXQucmlldGVyLnhvdC9jYWNoZS9ydGxj
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | YWNoZS54bWw/MTk1MDY5JwpwMzQKc1MnaWNvbicKcDM1ClMneG90X0RlZmF1bHRGb2xkZXIucG5n
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | JwpwMzYKc1MndHlwZScKcDM3ClMnZm9sZGVyJwpwMzgKc1MnbmFtZScKcDM5ClMnV2llIElzIERl
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - | IENoZWY/JwpwNDAKc2Iu
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 86   - +
20110918 18:02:58 - [1789MB] DEBUG    - plugin.py            - 124  - Found Channel data in URL: channel='chn_rtlipad', code=''
20110918 18:02:58 - [1789MB] DEBUG    - channelimporter.py   - 123  - Loading channels for class 'rtlipad'
20110918 18:02:58 - [1789MB] DEBUG    - stopwatch.py         - 45   - Stopwatch :: Set (ChannelImporter :: importing channels): 1316368978.95
20110918 18:02:58 - [1789MB] DEBUG    - channelimporter.py   - 157  - Loading net.rieter.xot.channel.rtlnl version 3.2.10.0
20110918 18:02:58 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ChannelImporter :: importing channels) : 1316368978.95, time elapsed: 7.21502304077 ms
20110918 18:02:58 - [1789MB] INFO     - channelimporter.py   - 202  - Importing chn_rtl
20110918 18:02:59 - [1789MB] INFO     - channelimporter.py   - 202  - Importing chn_rtlipad
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ChannelImporter :: importing channels) : 1316368979.14, time elapsed: 197.551012039 ms
20110918 18:02:59 - [1789MB] DEBUG    - channelimporter.py   - 240  - Initialized: RTL 4,5&7 [nl, 15D92364-42F4-11DD-AF9B-7BFF55D89593] (Order: 5)
20110918 18:02:59 - [1789MB] DEBUG    - channelimporter.py   - 240  - Initialized: iRTL 4,5&7 [nl, DE960970-70D3-11DF-B47C-FC51DFD72085] (Order: 5)
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 38   - Stopwatch :: Stop (ChannelImporter :: importing channels): 1316368979.15, time elapsed: 203.746080399 ms
20110918 18:02:59 - [1789MB] DEBUG    - plugin.py            - 137  - Caught the requested channel: iRTL 4,5&7 [nl, DE960970-70D3-11DF-B47C-FC51DFD72085] (Order: 5)
20110918 18:02:59 - [1789MB] INFO     - chn_class.py         - 750  - No login required of iRTL 4,5&7
20110918 18:02:59 - [1789MB] INFO     - plugin.py            - 146  - Loaded: iRTL 4,5&7
20110918 18:02:59 - [1789MB] DEBUG    - plugin.py            - 154  - Found 3 parameters
20110918 18:02:59 - [1789MB] INFO     - plugin.py            - 308  - Plugin::ProcessFolderList Doing ProcessFolderList
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 45   - Stopwatch :: Set (ProcessFolderList): 1316368979.16
20110918 18:02:59 - [1789MB] INFO     - uriopener.py         - 246  - Opening requested uri Async: file:/home/xbmc/.xbmc/userdata/addon_data/net.rieter.xot/cache/rtlcache.xml (already 1 threads)
20110918 18:02:59 - [1789MB] INFO     - uriopener.py         - 503  - Determining which Progessbar to use....
20110918 18:02:59 - [1789MB] INFO     - uriopener.py         - 508  - FileSize is known (fileSize=1719362)
20110918 18:02:59 - [1789MB] INFO     - uriopener.py         - 297  - Url file:/home/xbmc/.xbmc/userdata/addon_data/net.rieter.xot/cache/rtlcache.xml was opened successfully
20110918 18:02:59 - [1789MB] INFO     - chn_class.py         - 419  - Performing Pre-Processing
20110918 18:02:59 - [1789MB] DEBUG    - chn_class.py         - 421  - Pre-Processing finished
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ProcessFolderList) Folders Loaded: 1316368979.5, time elapsed: 340.296030045 ms
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ProcessFolderList) Folders Sorted: 1316368979.5, time elapsed: 340.599060059 ms
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ProcessFolderList) Video's Loaded: 1316368979.77, time elapsed: 610.465049744 ms
20110918 18:02:59 - [1789MB] DEBUG    - stopwatch.py         - 59   - Stopwatch :: Lap (ProcessFolderList) Video's Sorted: 1316368979.77, time elapsed: 610.872983932 ms
20110918 18:02:59 - [1789MB] DEBUG    - plugin.py            - 316  - ProcessFolderList returned 0 items
20110918 18:02:59 - [1789MB] INFO     - logger.py            - 115  - Flushing and closing logfile.
StrikerNL Wrote:@Basje iRTL does not seem to work for me; any program I try to open fails, this is what's in my log (if it helps):
Please post a complete uzgplugin.log on pastebin.ca. A lot of important information is in the beginning.
BTW: On Xbox iRTL does not work!
Basje Wrote:Please post a complete uzgplugin.log on pastebin.ca. A lot of important information is in the beginning.
What I pasted seems to be all of it; as you can see (first line), it gets truncated. How do I get a complete log?
Basje Wrote:BTW: On Xbox iRTL does not work!
Ubuntu 10.04 (XBMC Live)
StrikerNL Wrote:What I pasted seems to be all of it; as you can see (first line), it gets truncated. How do I get a complete log?
The Tail part is not mine! It's a file in the .xbmc\addons\net.rieter.xot folder.
EDIT: What Live version (that normally is in the top of the logfile)? For iRTL you need a very recent one?
