(2014-04-12, 09:08)asiuhas Wrote: [ -> ]Would it possible to add "latests shows" for the Swedish channels, especially TV4 and SVT. SVT only seems to have "latest newscasts".
Everyhing is possible. Make an feature request on the XBMC Online TV bitbucket issue tracker for this. I cannot give an ETA though, but it won't be before XBMC 13 hits final.
Why can I not get/find the dutch ned1,2,3 live channels in the npo.nl live section (I see only 3FM), or where else do I need to look for them?
So all the channels here:
http://www.npo.nl/live
Hi can you add the belgium channel vier they have a website meer.be where you can see episode's of some tv-shows it would be very nice.
(2014-04-29, 12:18)sompie Wrote: [ -> ]Hi can you add the belgium channel vier they have a website meer.be where you can see episode's of some tv-shows it would be very nice.
If you create a feature request at the Bitbucket page of XBMC Online TV I will see what I can do.
First time user of XOT, running Gotham 13.0.
Did a fresh installation, which went fine .i.e. I can see and choose which channels I want to watch (and they install too).
However, when I try to add the video add-on as a new item to the main menu, i doesn't show (other video add-ons do).
Being new to this - am I missing something basic - or is it due to Gotham 13.0 being to new?
(2014-05-08, 20:40)erik.p Wrote: [ -> ]First time user of XOT, running Gotham 13.0.
Weird, I assume you would like to have it appear like in the start of this video
https://www.youtube.com/watch?v=_h8H8SbCmtY
If you want that make sure that you add the main "XBMC Online TV" add-on and not the specific channel add-ons. I tested it with Gotham and it should be fine.
Hi Basje,
when I set up my Pi using Raspbmc and then installing the XOT add-on from the zipfile I asked here about the bad video quality of the SVTplay transmissions.
Then you directed me to someplace in XOT settings where I could specify to not use some video mode (forgot what it was named) and trade the poorer video quality for overall functionality. Apparently the video stream from SVTplay was not compatible with XBMC 12.
You also stated that the Gotham test builds did not have this problem.
Now I have seen that my Pi has auto-updated to XBMC 13 (Gotham) release and I wanted to go in and modify the settings I had done.
But I cannot find where they are located anymore. In principle it looks very much like XOT has also been updated, has it?
Or I am looking in the wrong place.....
EDIT:
Seems I am remembering wrong because I cannot find the posts exchanged about the bad streaming quality from SVT...
I must have discussed this on another forum like STM-labs or similar....
Sorry for the confusion.
(2014-05-08, 23:46)Bosse_B Wrote: [ -> ]Hi Basje,
EDIT:
XOT has a bitrate setting. Set it to the maximum value. That should play SVTPlay on 720p (if your internet is fast enought).
I am on a 100/10 Mbit/s fiber connection!
I will change it to the maximum value then.
By the way, I feel like a lot of on-line video looks much better now than before.
One case is The Daily Show, which was stuttering and behaving badly before but now it is as if it was broadcast over the air.
Much, much better!
I guess it is thanks to Gotham?
(2014-05-09, 00:52)Bosse_B Wrote: [ -> ]I am on a 100/10 Mbit/s fiber connection!
Much, much better!
Great to hear that. I myself have not yet fully tested the performance with Gotham, but they did a lot of optimizing for low end systems like the rpi.
(2014-05-08, 21:53)Basje Wrote: [ -> ] (2014-05-08, 20:40)erik.p Wrote: [ -> ]First time user of XOT, running Gotham 13.0.
Weird, I assume you would like to have it appear like in the start of this video https://www.youtube.com/watch?v=_h8H8SbCmtY
Doh! Thanks - that solved it - I had only added the specific channel add-on, not the main "XBMC Online TV" - thanks!
(2014-05-10, 13:34)erik.p Wrote: [ -> ] (2014-05-08, 21:53)Basje Wrote: [ -> ] (2014-05-08, 20:40)erik.p Wrote: [ -> ]First time user of XOT, running Gotham 13.0.
Didn't I also reply that suggestion on the tweet you sent me?
(2014-05-10, 14:32)Basje Wrote: [ -> ] (2014-05-10, 13:34)erik.p Wrote: [ -> ] (2014-05-08, 21:53)Basje Wrote: [ -> ]Weird, I assume you would like to have it appear like in the start of this video https://www.youtube.com/watch?v=_h8H8SbCmtY
Errr.. I didn't tweet you (as far as I know). Regardless, it now work's so thanks again.
I am using the AMBER skin with a vertical arrangement of the main menu.
Is that somehow blocking the additions of shortcuts like shown for XOT?
