2009-02-03, 22:48
tvalacarta Wrote:I think i will continue with option 3.
Thanks again,
No problem, but like I said. It won't be XOT anymore than, so you cannot name it like that.
Thanks again,
Bram77 Wrote:Would it be possible to make the RTL stream more easily accessible.
Some content I can't find. For instance.... I'm a motorsports fan. I like A1GP. I had a hard time finding the last race on the RTL Gemist website and couldn't find it at all at the RTL GP Gemist website. But eventually I've found it. The RTL Gemist ite seems to be a mess... But in XOT Uzg, I couldn't find the race at all! I hoped to be able to watch it on my TVNo luck, I've looked thrue the whole RTL Gemist section in XOT-Uzg, couldn't find it. Not in the places you'd expect it, and the not in the places you wouldn't expect it.
One other thing. It would be really nice to be able to pause streams. Right now, after a pause the video plays for a few seconds and then stops. But this is probably related to Mplayer..?
macardi Wrote:Thanks a lot for this script, i love it and using it almost every day!
The Swedish Television SVT have updated their streaming site once again and no files are apearing when chosing SVT anymore. The new site are located here:
http://svtplay.se/
Would it be possible to fixed this in the next release?
Basje Wrote:Could you post an issue report on the googlecode site? http://code.google.com/p/xot-uzg/
Quote:Did you check which version of XBMC they are using?
It is possible it is too old and the script won't run properly on it.
Quote:20090206 21:50:36 - DEBUG - common.py - 131 - | Version: XBMC 8.10 - ATLANTIS
20090206 21:50:36 - DEBUG - common.py - 131 - | Environment: win32
20090206 21:50:36 - DEBUG - common.py - 131 - + BuildDate: Nov 14
20090206 21:50:37 - INFO - default.py - 131 - ************** Starting XOT-Uzg (XOT-Uzg.v3) version v3.2.0b1 **************2008)
Quote:http://www.uitzendinggemist.nl/index.php...um&pgNum=6 was opened successfully
20090206 21:50:44 - INFO - uriopener.py - 148 - Opening requested uri Async: http://www.uitzendinggemist.nl/index.php...um&pgNum=7 (already 1 threads)
20090206 21:50:44 - INFO - uriopener.py - 417 - Determining which Progessbar to use....
20090206 21:50:44 - INFO - uriopener.py - 425 - FileSize is unknown
Quote:20090206 21:50:50 - CRITICAL - progwindow.py - 171 - OnAction::unknow action (id=112). Do not know what to do
20090206 21:50:50 - DEBUG - progwindow.py - 118 - Resetting self.click
20090206 21:50:50 - CRITICAL - progwindow.py - 171 - OnAction::unknow action (id=0). Do not know what to do
mr_xbox Wrote:I think I'm running the proper version. From my uitzendinggemist log:
As v3.2.0b1 is from 2008-09-29 I should have a good xbmc version.
However I'm getting these error messages (repeating over and over):
Basje Wrote:These messages don't show errors. Could you post a complete logfile on pastebin.ca (not here)?
mr_xbox Wrote:http://www.pastebin.ca/1333867
peterpan Wrote:Hi,
I am trying to use the XOT-UZG plugin to watch Dutch TV in the UK.
All the public channels NED 1, 2 and 3 are coming through perfectly from uitzendinggemist.nl. Unfortunately however, none of the other channels are unfortunately.
I am mainly interested in rtlgemist.nl, which I can watch in Safari after having installed Silverlight. This means that the fact that I am in the UK shouldn't matter.
Does anyone recognise this problem and know how to solve this? What I have done so far is the following:
I am running XBMC Atlantis on and Apple iMac running OSX 10.5.6. I have dowloaded XOT-Uzg.v3.2.0b3.zip from Bas' website and installed it in the XBMC/plugins/video folder.
This was enough to get the channels from uitzendinggemist.nl working. I can see the programmes that are available on rtlgemist.nl, but when I try to start one, it is immediately terminated.
For example, I tried to watch some GTST which did not work. Links to the log files showing this are below:
xbmc.log file:
http://pastebin.com/m4f734cd1
uzgPlugin.log file:
http://pastebin.com/m7c9bb043
Any help would be great! Many thanks....
