Hi! I am wondering if there is a way to disable to pin code. Since I logged in for NPO I randomly need to enter a pin code. I don't see the benefit of that..
(2023-01-02, 12:17)powermarcel10 Wrote: [ -> ]Hi! I am wondering if there is a way to disable to pin code. Since I logged in for NPO I randomly need to enter a pin code. I don't see the benefit of that..
No there is not.....don't log in to NPO. The problem lies within the Python `http.cookiejar` library. It does not like the NPO cookie, and corrupts it while storing. The next run, you will need to login in again to get a new cookie. At this point I can't really help this and can only say that entering a PIN is a lot less work then inputting your whole password each time: Retrospect stores encrypted passwords and uses the PIN to decrypt.
Until now I have not encountered this issue myself. It seems Linux (LibreElec) only. Can you post a full debug Retrospect.log (you can create one via Retrospect) so I can verify?
linuxrules007 Also note that most browsers have disabled the use of FTP connections these days, so downloading your .webp files is a bit difficult.
But if the PIN is only needed to decrypt the password then surely disabling the PIN and the vault would be a nice workaround? After all only a very small number of people would want to protect their passwords from their kids that way?
(2023-07-26, 02:30)murphy233 Wrote: [ -> ]But if the PIN is only needed to decrypt the password then surely disabling the PIN and the vault would be a nice workaround? After all only a very small number of people would want to protect their passwords from their kids that way?
The PIN is not to protect it from kids. But to make sure your NPO password is not store in plain text in the settings XML file.
Retrospect finds no content on SVT.
Season 37 (säsong 37) of the Postkodmiljonären show does not show up in the list, when I search for Postkodmiljonären in retrospect (National (Swedish) / TV4).
There is a season 37 on TV4 Play:
https://www.tv4play.se/program/dd9fe14d7...n%C3%A4ren , but I can't find it from within Retrospect.
I can find and watch season 36 with no trouble at all, but I'd like to see the latest season too.
(I'm using a Raspberry 2 with Leia OS.)
I have a issue with the TV4 content. The new season of "Maria Wern" is missing.
Is there maybe a way to fix this?
Would it at some point be possible to add t oTV4 Play the restricted material.
Now when I try it the picture goes bananas and time seems to go backwards...
I can what it is resricted (the yellow dot ones)..
I know you are a busy person so no hurry...
But if you do not ask, you get no answers...
/Philip Arthur Dent ¤ kind regards
(2023-12-08, 12:03)Philip_Arthur_Dent Wrote: [ -> ]Would it at some point be possible to add t oTV4 Play the restricted material.
All content should be accessible if you are in the right geografical area. Make sure you have the right and latest widevine libraries installed.
