Basje Wrote:could be that the format is the same, just the protocol not (like mms:// vs http://).
Ok, tried to debug it myself, without much success. Seems it has nothing to do with the "CFileFactory::CreateLoader - Unsupported protocol plugin", it throws that a lot in the logs.
I found some other suspicious messages in the log. All seems to go well untill here:
00:15:42 T:2881661808 M:1431932928 NOTICE: Traceback (most recent call last):
00:15:42 T:2881661808 M:1431932928 NOTICE: File "/home/bram/.xbmc/addons/net.rieter.xot/resources/libs/plugin.py", line 276, in ProcessVideoItem
00:15:42 T:2881661808 M:1431932928 NOTICE: pickleItem = pickle.loads(pickleString)
00:15:42 T:2881661808 M:1431932928 NOTICE: File "/usr/share/xbmc/system/python/python24.zip/pickle.py", line 1394, in loads
00:15:42 T:2881661808 M:1431932928 NOTICE: return Unpickler(file).load()
00:15:42 T:2881661808 M:1431932928 NOTICE: File "/usr/share/xbmc/system/python/python24.zip/pickle.py", line 872, in load
00:15:42 T:2881661808 M:1431932928 NOTICE: dispatch[key](self)
00:15:42 T:2881661808 M:1431932928 NOTICE: File "/usr/share/xbmc/system/python/python24.zip/pickle.py", line 1083, in load_inst
00:15:42 T:2907700080 M:1431932928 DEBUG: WaitOnScriptResult- plugin returned failure
00:15:42 T:2907700080 M:1431932928 DEBUG: CGetDirectory::DoWork retrieving plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]processvideo[[#]](imediaitem
00:15:42 T:2907700080 M:1431932928 DEBUG: CGetDirectory::OnJobComplete called
00:15:42 T:2881661808 M:1431932928 NOTICE: klass = self.find_class(module, name)
00:15:42 T:2881661808 M:1431932928 NOTICE: File "/usr/share/xbmc/system/python/python24.zip/pickle.py", line 1140, in find_class
00:15:42 T:2881661808 M:1431932928 NOTICE: klass = getattr(mod, name)
00:15:42 T:2881661808 M:1431932928 NOTICE: AttributeError: 'module' object has no attribute 'mediaitem'
00:15:42 T:3078264688 M:1431932928 ERROR: GetDirectory - Error getting plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]processvideo[[#]](imediaitem
00:15:42 T:3078264688 M:1431932928 ERROR: CGUIMediaWindow::GetDirectory(plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]processvideo[[#]](imediaitem
00:15:42 T:3078264688 M:1431932928 DEBUG: CGUIMediaWindow::GetDirectory (plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]http://www.rtl.nl/(vm=/programma/yourbodyenmind/uitzendingen/)/system/video/menu/programma/yourbodyenmind/uitzendingen/videomenu.xml )
00:15:42 T:3078264688 M:1431932928 DEBUG: ParentPath = [plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]http://www.rtl.nl/(vm=/programma/yourbodyenmind/)/system/video/menu/programma/yourbodyenmind/videomenu.xml ]
00:15:42 T:3078264688 M:1431932928 DEBUG: Loading fileitems [plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]http://www.rtl.nl/(vm=/programma/yourbodyenmind/uitzendingen/)/system/video/menu/programma/yourbodyenmind/uitzendingen/videomenu.xml ]
00:15:42 T:3078264688 M:1431932928 DEBUG: -- items: 6, directory: plugin://net.rieter.xot/?chn_rtl.py[[#]][[#]]http://www.rtl.nl/(vm=/programma/yourbodyenmind/uitzendingen/)/system/video/menu/programma/yourbodyenmind/uitzendingen/videomenu.xml sort method: 0, ascending: false
00:15:42 T:3078264688 M:1431932928 WARNING: CFileFactory::CreateLoader - Unsupported protocol plugin
00:15:42 T:3050167152 M:1431044096 WARNING: Previous line repeats 3 times.
00:15:42 T:3050167152 M:1431044096 DEBUG: thread start, auto delete: 0
00:15:42 T:3050167152 M:1430663168 DEBUG: Thread 3050167152 terminating
00:15:42 T:2881661808 M:1430409216 INFO: Scriptresult: Success
00:15:42 T:3078264688 M:1426092032 ERROR: ClearBlock: Trying to clear non existent block /home/bram/.xbmc/addons/net.rieter.xot/
00:15:42 T:2881661808 M:1428504576 INFO: Python script stopped
00:15:42 T:2881661808 M:1428504576 DEBUG: Thread 2881661808 terminating
00:15:42 T:3078264688 M:1428504576 DEBUG: python thread 6 destructed
00:15:42 T:3078264688 M:1432068096 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
Anyone has a clue?
miseryshining Wrote:Ok, tried to debug it myself, without much success. Seems it has nothing to do with the "CFileFactory::CreateLoader - Unsupported protocol plugin", it throws that a lot in the logs.
Anyone has a clue?
Could you post an issue on the XOT googlecode page and attach a complete uzgplugin.log and uzgplugin.log.old
Basje Wrote:Could you post an issue on the XOT googlecode page and attach a complete uzgplugin.log and uzgplugin.log.old
here it is
miseryshining Wrote:here it is
It will be fixed in the 3.2.1 release somewhere this week.
Just installed 3.2.1 following this guide:
http://www.rieter.net/pages/XOT:Installa...s_an_Addon
All goes well.
Then I go to Main Menu > Addons > "XOT-Uzg.v3 0 B" and click it. I see a progress bar filling and when its done... NOTHING!
Is this thing broken?
Running rev32555 on WinXP SP3.
BTW in the guide above it says the script version appears under "Programs" but programs doesn't exist in XBMC, not anymore.
I also tried:
Main Menu > Videos > "XOT-Uzg.v3", again nothing happens.
zilexa Wrote:Just installed 3.2.1 following this guide:
All goes well.
I also tried:
You have to give me more information:
- Did you install the XOT Repository?
- Does it appear under System -> Add-ons?
- Where do you find Main Menu > Addons > "XOT-Uzg.v3 0 B", XBMC does not have such a menu?
- XBMC does have a Programs folder! So I am wondering what version you are using?
For me the addon is only working on the Confluence skin.
I tried several other skins (Night, Black Row, PM3.HD, Mediastream Redux) but in all of them neither the video addon nor the program addon is working.
yep, same here. i believe the plugin "view/option" is supposed to be skin independent. but you're right: it only works with the default skin.
bosel Wrote:yep, same here. i believe the plugin "view/option" is supposed to be skin independent. but you're right: it only works with the default skin.
Go into net.rieter.xot/resources/skins/Default/PAL and copy all those files into the net.rieter.xot/resources/skins/Default/PAL16x9 Folder. It will then work. I will fix it in 3.2.2.
The fact that it does not work as a plugin is caused by the way XOT works: even the plugin uses WindowXML objects which require a valid XML.
I did exactly as you described, but for me it seems not to work.
I tried several restarts of XBMC, but neither in the Addon section nor in the video section it is working. Same as before.
I´ve only had this wonderful script to work with Confluence skin only!!!
And I´ve tried like 15 skins.
I´m running latest Dharma-Branch under windows 7 x32
ridler Wrote:I did exactly as you described, but for me it seems not to work.
Post a complete logfile on pastebin.ca please and make sure you are running a very recent (not more than 2 weeks old) Dharma build.
h3nk3 Wrote:I´ve only had this wonderful script to work with Confluence skin only!!!
Could you try the same thing? Go into net.rieter.xot/resources/skins/Default/PAL and copy all those files into the net.rieter.xot/resources/skins/Default/PAL16x9 Folder.
And also make sure that you are using a very recent (2 weeks old at most) Dharma build.
Im trying to run xot on openelec.tv embedded XBMC. It installs just fine but when i try to run it, it won't start. The following is the error in xbmc log file:
01:06:44 T:140025243584272 M:1627291648 NOTICE: WebServer: GET | /xbmcCmds/xbmcHttp
01:06:44 T:140025069004560 M:1627291648 NOTICE: -->Python Interpreter Initialized<--
01:06:44 T:140025069004560 M:1627267072 ERROR: Error Type: <type 'exceptions.IOError'>
01:06:44 T:140025069004560 M:1627267072 ERROR: Error Contents: (10, 'No child processes')
01:06:44 T:140025069004560 M:1627267072 ERROR: Traceback (most recent call last):
File "/storage/.xbmc/addons/net.rieter.xot/default.py", line 22, in <module>
env = envController.GetEnvironment()
File "/storage/.xbmc/addons/net.rieter.xot/resources/libs/envcontroller.py", line 30, in GetEnvironment
(bits, type) = platform.architecture()
File "./Lib/platform.py", line 1028, in architecture
File "./Lib/platform.py", line 976, in _syscmd_file
IOError: (10, 'No child processes')
I'm running the latest version of this script and openelec.tv. Is there a way to fix this?
