(2012-05-01, 09:34)Basje Wrote: [ -> ]Ok, I can't help you if you don't give me a step by step list of what you did. So tell me exactly what you did, including files you downloaded an what you copied where including full path names. I still think you did not add the plugin as a video source (you need to do that on Xbox).
Ok, More clean then this can´t it be i think
1: I download this file "
net.rieter.xot.repository-1.0.1.zip"
2: I open it whit WinRAR and Unpack it to my desktop then i have a folder whit name "net.rieter.xot.repository" in the folder it contains two files "icon.png" and "addon.xml"
3: I open FTPRush and go to "/C/plugins/video/" and upload "net.rieter.xot.repository" to that folder
4: I go in to XMBC and under VideoAddons its there i don´t have to add it and i can´t add it ether, I try whit both XBMC 3.01 and XBMC 3.1
5: XBMC 3.0.1 has the option to add VideoAddons but when i chose the folder nothing happens
6: XBMC 3.1 Don´t have this option and can´t be added that way, But its still in VideoAddons when it uploaded to that folder
7: Just to make some stuff clear here, I checked on "
YouTube" how to do this, Its a new menu on XBMC today, But it works the same in 3.0.1
8: You did never told me if the py file shuld exist in the zip, or if its shuld be automatic created by XBMC
XBMC 3.1: Here is a Movie on
YouTube that i did to show you exactly how it looks, Its relly relly relly bad quilty but its enoth to see whats happen
Notice: 1-1; If i add a VideoPlugin from the program repo plugins installer, I got the option lets see how that looks, And what happens is exactly the same that happens in XBMC 3.0.1, Here is that
YouTube Video
Notice: 1-2: Here is a new YouTube Video where i just add it as a normal movie, Then i can see the icon on the folder, But its still not happen anything when i enter it, Here is that
YouTube Video
/ Anton
