(2019-11-15, 21:18)manpeace Wrote: [ -> ]Quote:
Indeed, the wrong ID for the
Just updatet to version 5.1.1
Still the same problem unfortunately. I Know Bas is working on the problem with SVT Play
I know that SVT Play Addon had the same problem but was resolved this wednesday. So Im stuck to that addon till Bas fix Retrospect. I love retrospect and as soon as there is a fix I will switch back to retrospect for SVT. Still using it for all the other Swedish television Chanells
(2019-11-15, 21:23)manpeace Wrote: [ -> ] (2019-11-15, 21:18)manpeace Wrote: [ -> ]Quote:
Working on it. But unfortunately I had some two very very busy weeks in real life, so I just started on it yesterday.
(2019-11-16, 12:55)manpeace Wrote: [ -> ] (2019-11-15, 22:46)Basje Wrote: [ -> ] (2019-11-15, 21:23)manpeace Wrote: [ -> ]Just updatet to version 5.1.1
don't worry about it. we can wait
There is a patch here:
https://github.com/retrospect-addon/plug...ssues/1254
Will try to get an official one later.
Hi There,
I have a problem with the Swedish channels. For some time TV4 and TV 7 is no longer running (no streams). I also have a Swedish VPN but it does not work anymore. Can you help me? Kodi 18.5 / Retrospect 5.12. THANXXL
(2019-12-01, 21:03)Rudiruessel Wrote: [ -> ]Hi There,
I assume you are not in Sweden if you are using a VPN. It seems TV4 has started blocking VPN IPs.
Edit: Removed parts not to break Kodi's forum rules.
(2019-12-01, 21:25)Rudiruessel Wrote: [ -> ] (2019-12-01, 21:18)Snaah Wrote: [ -> ] (2019-12-01, 21:03)Rudiruessel Wrote: [ -> ]Hallo zusammen, ich habe ein Problem mit den schwedischen Sendern. Seit einiger Zeit laufen TV4 und TV 7 nicht mehr (keine Streams). Ich habe auch ein schwedisches VPN, aber es funktioniert nicht mehr. Können Sie mir helfen? Kodi 18.5 / Retrospect 5.12. THANXXL
Ich gehe davon aus, dass Sie nicht in Schweden sind, wenn Sie ein VPN verwenden. Ich habe das auch bemerkt und es scheint, dass TV4 VPN-IPs blockiert hat. Die Modheader-Lösung funktioniert weiterhin mit Chrome. Die einzige andere Lösung, die ich gefunden habe, ist ein privates VPN, dh auf Ihrem eigenen Router.
Danke für die schnelle Antwort. Wie funktioniert die Modheader Lösung?
(2019-12-01, 21:03)Rudiruessel Wrote: [ -> ]I also have a Swedish VPN but it does not work anymore.
I think I have to point out the
VPN policy (wiki) which is active on this forum.
(2019-12-01, 21:32)Rudiruessel Wrote: [ -> ] (2019-12-01, 21:25)Rudiruessel Wrote: [ -> ] (2019-12-01, 21:18)Snaah Wrote: [ -> ]Ich gehe davon aus, dass Sie nicht in Schweden sind, wenn Sie ein VPN verwenden. Ich habe das auch bemerkt und es scheint, dass TV4 VPN-IPs blockiert hat. Die Modheader-Lösung funktioniert weiterhin mit Chrome. Die einzige andere Lösung, die ich gefunden habe, ist ein privates VPN, dh auf Ihrem eigenen Router.
Yes, please also stop discussing any other solutions to circumvent Geo blocking in this forum. I really don't want to get this thread closed.
Hi Basje, can you please look at my problem please?
On the Apple TV I can't put in a password on the channel settings from the Retrospect settings or Kodi freezes, username is no problem. For Stevie, VRT NU, ...
Also on the change vault pin. When I want to put in a pin Kodi freezes
I am using Apple TV 4K, tvOS 13.3, Kodi 17.6, Retrospect 5.1.3
But it also happens on the Kodi 19 nightlies
Only on Apple TV. On iPhone, iPad, Mac no problems.
Retrospect logfile: https:/paste.kodi.tv/ulavikovit
Kodi logfile:
https://paste.kodi.tv/huzisefila
And sorry to bother you so soon in the new year ;-)
Happy new year
Wormpy
Retrospect logfile:
https://paste.kodi.tv/ulavikovit
Kodi logfile:
Happy new year
Wormpy
(2020-01-01, 13:17)wormpy Wrote: [ -> ]Hi Basje, can you please look at my problem please?
Retrospect logfile: https://paste.kodi.tv/ulavikovit
Kodi logfile: https://paste.kodi.tv/huzisefila
Happy new year
Wormpy
Interesting. Seems like somehow there is an issue with showing dialogs. Could you try setting it from the add-on settings without actually being in Retrospect? So got to "My Add-ons" and try setting it up there.
And do you use a different skin on the Apple TV 4K?
