Razor_109 Wrote:i'm running XBMC on linux and wonder if this script should work on linux also?
got the beta 3.2.0a3 running perfectly on my Xbox but on my Linux HTPC it wont start playing video's.. just nothing when i select them. Browsing trough the episodes en channels works though.
If you send me an complete uzg.log I could have a look for you. It should work.
Basje Wrote:If you send me an complete uzg.log I could have a look for you. It should work.
Here's my uzg.log
http://pastebin.ca/1200448
20:44:18 is the time i pressed the button to play an episode.. no errors in log though.
If you need anything else, let me know..
btw, tested with 2 SVN's, atm running latest svn 15523. But didnt work before .
Razor_109 Wrote:btw, tested with 2 SVN's, atm running latest svn 15523. But didnt work before .
Seems like XOT is doing it's job correctly. It could be however that the Linux version of XBMC does not know WVX stream files. Perhaps I will have to add some extra parsing.
I will check it this weekend. Could you add a issue to the XOT googlecode page?
I've got a problem with putting a episode of some serie on hold (pause)
Whenever i pause a file i streamed with this great script, i can't continue watching it.
It will resume, but after a few seconds or a minute at the most it will stop.
I think this is at the point the cache is empty or something of this sort.
Anyone else having trouble with this?
Maybe there is already a fix?
I'm using: "XOT-Uzg.v3.2.0a3" with "XBMC-SVN_2008-09-08_rev15452-T3CH"
It would be nice if there is a solve to this problem, so i can pause to go to the bathroom
greetings Henry
Henky85 Wrote:Hi,
greetings Henry
The problem is the combination of the stream and XBMC. Some streams just can't be pauses. Nothing I can do about that with the script. It would also occur if you would open the stream without the script.
Sorry. You could post in the bug forum and give them the stream you try to play (it is in the uzg.log file) and mention them your problem.
Thanks for replying so soon.
I understand that some streams can't be paused. It only occurs to the streams from uitzendinggemist.nl (ned1 t/m ned3).
When i watch a stream on the PC i can pause it and resume watching afterwards.
I don't want to be annoying or anything, but i was just curious if this is a problem everyone encounters?
If it is something which can't be fixed because it is due to the stream then I don't mind.
The script is still the best one I've had!
Greetings Henry
Henky85 Wrote:Thanks for replying so soon.
Greetings Henry
I know there are issues with those streams and XBMC. I posted those problems a long time ago. Never heard about it since. Search the forums and see if you can find them. Perhaps then will have a look at it now.
thanks about making this clear,
I read your posts, and understand the nature of the problem.
I hope the player used by your script will start supporting the searching through streams.
For now I will go to the bathroom in between episodes
If I use uzg on Ned 1, 2 or 3, the episodes I am watching stop about halfway?
Is this something other people encounter?
sanssems Wrote:Hi,
Did you try adjusting your cache settings of XBMC?
No, I didn't. I just installed a later t3ch and uzg version.
Before it always worked just fine.
How should I check this cache?
sanssems Wrote:No, I didn't. I just installed a later t3ch and uzg version.
Yeah, sounds like XBMC runs out of cache.
But how can I solve this cache problem?
sanssems Wrote:But how can I solve this cache problem?
Check the cache settings of XBMC and play around with them. There is no real perfect solution. All I can say is that all of my XBMC cache settings have values around 2MB.
