Does this addon still not support 2fa? I get an error 400 invalid_token
I just reset all settings in the addon to default and get the exact same error when I tap login
(2023-10-05, 03:00)DavidFW1960 Wrote: [ -> ]I just reset all settings in the addon to default and get the exact same error when I tap login
this developer hasn't posted on the forum i a very long time and support from other users is lacking
use
https://github.com/anxdpanic/plugin.vide...ube/issues
Good afternoon,
Can someone please tell me, or lead in the right direction as to where I can find a version for YouTube (Matrix), as well as the adaptive plugin? I've tried the plugin.video.youtube-7.0.2.2.matrix.unofficial.1, as well as the inputstream.adaptive.20.3.1 addon, but I get the message that says dependencies not met.
Thanks in advance,
Shedrock
izprtxqkft - Thank you. That seemed to have worked, but I can't access my channel. It's strange, on my Kodi (Leia) box I have no issues at all. Any idea why it won't work on Matrix?
Thanks,
Shedrock
(2023-10-11, 00:17)shedrock Wrote: [ -> ]Any idea why it won't work on Matrix?
no idea at all, in 10 months i have never been able to get this addon to work which is why i referred to the issues page in hopes you will actually get more help than i can provide
(2023-10-11, 00:34)izprtxqkft Wrote: [ -> ]no idea at all, in 10 months i have never been able to get this addon to work which is why i referred to the issues page in hopes you will actually get more help than i can provide
No problem, that's why I love Leia. Everything just works well. I also have the same issue with Nexus.
Anyway, thank you for your assistance. I'll keep at it to see if I can figure it out.
Regards,
Shedrock
Can someone update official Kodi repo with the latest version 7.0.2.2. Thanks.
is anyone else having problems with the YouTube recommended section? in my case I have the option in the folder settings but if I activate it doesn't show up. I'm using the 6.8.25 version which I believe is the latest available from the Kodi repo, I know there are newer versions but I've seen some people having trouble with those and I don't want to go through that.
(2023-10-15, 17:12)andresrgv Wrote: [ -> ]is anyone else having problems with the YouTube recommended section? in my case I have the option in the folder settings but if I activate it doesn't show up. I'm using the 6.8.25 version which I believe is the latest available from the Kodi repo, I know there are newer versions but I've seen some people having trouble with those and I don't want to go through that.
I'm running version
7.0.2.2+matrix.1 on Matrix, and on my RPi4, but I cannot access
"My Channel". On
Leia, there are no issues.
Shedrock
