(2021-10-24, 20:11)shedrock Wrote: [ -> ]I've never used inputstream.adaptive before and I have no clue as to what setting I'm suppose to use in the configuration, as well in the MPEG-Dash configuration in YouTube. I'm asking because if I leave for example Newsmax or France 24 streaming live for over 30 minutes, the video starts to jitter and freeze up. Can someone please tell me what the best setting should be?
shedrock
Here is a basic setup (it might seem complicated but it's not really, just follow the steps):
1: YouTube > Settings > MPEG-DASH > Use MPEG-DASH > Enabled
2: YouTube > Settings > MPEG-DASH > Use for Videos > Enabled
(set Video Quality as required. If on a low powered device also set HDR > Disabled, and Limit to 30fps > Enabled)
3: YouTube > Settings > MPEG-DASH > Use for Live Streams > Enabled
Some Live Streams (eg: France24)
specifically require MPEG-DASH in order for them to work.
This requires numbers 1 and 3 to be enabled as a minimum.
Enable number 2 if you also want to use MPEG-DASH for YouTube videos
other than Live Streams.
NB: If you Enable MPEG-DASH for all Videos and Live Streams then the setting YouTube > Settings > General > Video Quality will not have any effect. For clarity set the same quality as above.
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive
(NB: YouTube addon has it's own quality settings - so some of these settings will only apply to other Kodi addons)
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive > Max Resolution > For clarity set the same quality as above.
(NB: you can of course set it to a different quality too, if required for other Kodi addons also using InputStream Adaptive)
(NB: you can also set a Min and Max Bandwidth for fine tuning too, but it's not essential)
(NB: In general all of the quality settings should be set in relation to your device power, and internet speed)
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive > Stream Selection > Automatically Select Streams
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive > Media > All
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive > Override HDCP Status > Specific to your setup
(if you have/need this you will know)
YouTube > Settings > MPEG-DASH > Configure InputStream Adaptive > Ignore Display Resolution > Specific to your setup
For a complete setup I also installed InputStream Helper
YouTube > Settings > MPEG-DASH > Install InputStream Helper
Kodi > My Addons > Programs > InputStream Helper > Configure > Nothing is essential to change here
(but you can tweak the Update Frequency and the Number of Backups if you wish)
I think that covers a basic setup for YouTube, MPEG-DASH, and InputStream Adaptive.
All of these settings can however be tweaked if you have a specific use case.
Hope this helps
