Hello, I have this error when I try to Sign In;
Login Exception: [401] invalid_client Invalid Client Type
All other works, but I can't login and
live stream section is blank.
Can you help me?
I'm using Kodi 18.9. Youtube addon 6.8.15 by anxdpanic, bromix
For everyone having buffering issues, you might have to change YouTube settings-advanced-cache size(MB) I put it on 65, now I don't have buffering in 1080p .mpd files anymore
My Subscriptions seem to have stopped working for me this morning. Is anyone else having the same issue?
Watch Later is still working, so it's not a log in problem. Hopefully it is just a temporary outage from Google.
(2021-07-10, 23:48)davidx Wrote: [ -> ]For everyone having buffering issues, you might have to change YouTube settings-advanced-cache size(MB) I put it on 65, now I don't have buffering in 1080p .mpd files anymore
Didn't work for me.
Thanks for the tip but it didn't work for me.
This buffering behavior is so annoying l can't tell you, I'd be grateful for any other idea how to eliminate this...
Didn't work for me. The issue has been identified. Waiting on development to fix.
(2021-07-12, 01:53)jmh2002 Wrote: [ -> ]My Subscriptions seem to have stopped working for me this morning. Is anyone else having the same issue?
Back up again today for me
Hello,
have you a solution for the youtube "quota exceed" problem ?
(2021-07-12, 23:13)McFly1985 Wrote: [ -> ]Hello,
Do you have your own API Keys ?
API Keys Wiki
(2021-07-12, 10:21)C.O.D. Wrote: [ -> ] (2021-07-10, 23:48)davidx Wrote: [ -> ]For everyone having buffering issues, you might have to change YouTube settings-advanced-cache size(MB) I put it on 65, now I don't have buffering in 1080p .mpd files anymore
I found that using the option "Play (ask for quality)", and selecting a 720p stream eliminates my buffer issue. I have also disabled MPEG-DASH, which I had previously enabled because of issues from a while ago, but now seems not to be necessary.
(2021-07-12, 23:30)blueribb Wrote: [ -> ] (2021-07-12, 23:13)McFly1985 Wrote: [ -> ]Hello,
API Keys Wiki
Yes I have a API Key.
But I think can login.
Thanks for this great addon.
But for last 2 weeks internet is half working in my kodi 17.6 krypton r pi 2.
No video addon is working. Weather app is also not working. But in network status it shows all the right settings and status as connected.
Youtube error check log same error eveytime.
I changed lan cable and saw not fixed.
Any help would be appreciated.
Please upload your debug log to our paste site and supply the URL here.
Don't use sites like Google Drive if you can avoid it, and if you must use such sites make the log publically accessible without having to jump through hoops of requesting access etc.
Kodi 19.1 I am using my own API key. I'm getting No Streams found. Any help would be much appreciated.
Thank you!
