(2024-03-08, 11:21)phyrros1 Wrote: [ -> ]I updated to 7.0.3.2 yesterday. Since this version of the add-on skipping does not seem to work as it used to (at least on a Firecube).
The clip freezes for a 3-6 seconds while the sound continues till the video catches up again. Does anybody else have the same issues?
Never mind..figured it out. InputStream Adaptive was enabled. After I disabled it skipping worked as it used to….
What is InputStream Adaptive for anyway?
(2024-03-08, 17:46)phyrros1 Wrote: [ -> ] (2024-03-08, 11:21)phyrros1 Wrote: [ -> ]I updated to 7.0.3.2 yesterday. Since this version of the add-on skipping does not seem to work as it used to (at least on a Firecube).
ah ok. think i enabled that for live streams.
you could try to turn off InputStream Adaptive in the plug-in setting….
I added it and installed the update now I get and error that the api keys have been suspended
(2024-03-08, 20:14)phyrros1 Wrote: [ -> ]you could try to turn off InputStream Adaptive in the plug-in setting….
Great! Thank you.! It works fine!
Dear experts,
Could you please help me understand why I have this situation?
Kodi Addon Repository 3.3.1 shows YouTube addon version 7.0.2.2, but if I go to Github, I can download the 7.0.3.2?
I’m sorry if I ask something obvious!
Thanks for mentioning the alpha 7. I had the same issue but was running v18.9 Leia since I found no reason to upgrade.
Installed the latest v20.5 and YT 7.0.3.2 which ran quite well but I had no subtitles.
Downgraded to 7.0.0 and YT broke. Alpha was the sweet spot.
I’m sorry, but my question was about the version differences.
(2024-03-09, 20:15)warning Wrote: [ -> ]Dear experts,
I think it's simply that the Kodi addon repository hasn't been updated with the latest build. Unfortunately that means that the only way to update at the moment (and get a functional version) is to download and install the Zip from the github repo.
Cool, it works perfectly again with a manual installation of the latest version.
However, by manually installing this version, will automatic updates continue?
(2024-03-10, 15:17)Bindou Wrote: [ -> ]Cool, it works perfectly again with a manual installation of the latest version.
The answer is no
You must check manually if there is a new version from public repo.
If there is a new version you can install this version then automatic update start again
Hi, I got the latest from github (7.0.3.2) and was able to do a search but was unable to watch any videos. I checked my log and it said it was a 400 - bad request error.
Using osmc with pi 4.
https://paste.kodi.tv/niwizusuge
