2022-05-08, 11:28
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
2022-05-08, 11:28
2022-05-10, 00:50
the last release was October 2021 - how is that great support?
I see the issue listed (only it doesn't just take me back to the video menu - it completely crashes Kodi)
2022-05-10, 20:46
i try to play 4k Youtube video on my pc.
2022-05-10 13:39:37.095 T:9000 INFO <general>: CPythonInvoker(59, C:\Users\htpc\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\default.py): script successfully run
2022-05-10 13:39:37.099 T:8300 INFO <general>: VideoPlayer::OpenFile: plugin://plugin.video.youtube/play/?video_id=a8Gx8wiNbs8
2022-05-10 13:39:37.504 T:5788 INFO <general>: Creating InputStream
2022-05-10 13:39:37.648 T:5788 INFO <general>: Creating Demuxer
2022-05-10 13:39:38.076 T:5788 ERROR <general>: CDVDDemuxFFmpeg::Open - error probing input format, https://www.youtube.com/watch?v=a8Gx8wiNbs8
2022-05-10 13:39:38.076 T:5788 ERROR <general>: CVideoPlayer::OpenDemuxStream - Error creating demuxer
2022-05-10 13:39:38.076 T:5788 INFO <general>: CVideoPlayer::OnExit()
2022-05-10 13:39:38.099 T:8300 INFO <general>: CVideoPlayer::CloseFile()
2022-05-10 13:39:38.099 T:8300 INFO <general>: VideoPlayer: waiting for threads to exit
2022-05-10 13:39:38.100 T:8300 INFO <general>: VideoPlayer: finished waiting
2022-05-10 13:39:50.375 T:8300 INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
2022-05-10 13:39:52.592 T:8300 INFO <general>: Stopping player
2022-05-10 13:39:52.592 T:8300 INFO <general>: Storing total System Uptime
2022-05-10 13:39:52.592 T:8300 INFO <general>: Saving settings
2022-05-10 13:39:52.596 T:8300 INFO <general>: Saving skin settings
2022-05-10 13:39:52.597 T:8300 INFO <general>: Stopping all
2022-05-10 13:39:52.597 T:8300 INFO <general>: ES: Stopping event server
2022-05-10 13:39:53.003 T:8372 INFO <general>: ES: UDP Event server stopped
2022-05-10 13:39:53.273 T:7588 INFO <general>: CPythonInvoker(1, C:\Users\htpc\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\startup.py): script successfully run
2022-05-10 13:39:53.307 T:7588 INFO <general>: Python interpreter interrupted by user
2022-05-10 13:39:53.307 T:8300 INFO <general>: CServiceAddonManager: failed to stop service.xbmc.versioncheck (may have ended)
2022-05-10 13:39:53.327 T:9000 INFO <general>: Python interpreter interrupted by user
2022-05-10 13:39:53.342 T:8300 INFO <general>: Skipped 4 duplicate messages..
2022-05-10 13:39:53.342 T:8300 INFO <general>: Application stopped
2022-05-10 13:39:53.542 T:8300 INFO <general>: XBApplicationEx: destroying...
2022-05-10 13:39:53.831 T:8300 INFO <general>: AddOnLog: peripheral.joystick: Disabling joystick interface "directinput"
2022-05-10 13:39:53.831 T:8300 INFO <general>: AddOnLog: peripheral.joystick: Disabling joystick interface "xinput"
2022-05-10 13:39:53.831 T:8300 INFO <general>: ADDON: Dll Destroyed - Joystick Support
2022-05-10 13:39:53.832 T:8300 INFO <general>: unload skin
2022-05-10 13:39:53.844 T:8300 WARNING <general>: CGUITextureManager::Cleanup: Having to cleanup texture lists/focus.png
2022-05-10 13:39:53.865 T:8300 INFO <general>: Unloaded skin
2022-05-10 13:39:53.922 T:8300 INFO <general>: unload sections
2022-05-10 13:39:53.930 T:8300 INFO <general>: [WS-Discovery]: terminating
2022-05-10 13:39:53.934 T:8300 INFO <general>: XBApplicationEx: application stopped!
i got this msg.
i got this msg.
2022-05-13, 03:21
anyone pls help me.
2022-05-14, 21:02
I started getting the same error after I updated my API key with a new google project to solve an API not valid issue.
Full Log here
2022-05-14 11:56:19.488 T:128 ERROR <general>: Open - error probing input format, https://www.youtube.com/watch?v=DSqDfW203Rc
2022-05-14 11:56:19.488 T:128 ERROR <general>: OpenDemuxStream - Error creating demuxer
Full Log here
2022-05-17, 14:13
(2022-05-14, 21:02)ltai0001 Wrote: [ -> ]I started getting the same error after I updated my API key with a new google project to solve an API not valid issue.Also started getting this error more and more often on 18.9 Leia a while ago, mostly when starting Playback on 720p, going down a quality level fixed playback on most playbacks. Toogle "Ask quality for every playback" is set. Updated Last Weekend to 19.4 matrix an now it is worse. Nearly NO YT Video (mostly Let´s Plays) do not seem to work anymore! :-(
Code:2022-05-14 11:56:19.488 T:128 ERROR <general>: Open - error probing input format, https://www.youtube.com/watch?v=DSqDfW203Rc
Full Log here
Hopefully, there is a solution to this!
Full Log here
2022-05-17, 14:22
(2022-05-17, 14:13)ThePunisher1971 Wrote: [ -> ]Might be this open issue?(2022-05-14, 21:02)ltai0001 Wrote: [ -> ]I started getting the same error after I updated my API key with a new google project to solve an API not valid issue.Also started getting this error more and more often on 18.9 Leia a while ago, mostly when starting Playback on 720p, going down a quality level fixed playback on most playbacks. Toogle "Ask quality for every playback" is set. Updated Last Weekend to 19.4 matrix an now it is worse. Nearly NO YT Video (mostly Let´s Plays) do not seem to work anymore! :-(
Full Log here
Full Log here
https://github.com/anxdpanic/plugin.vide...issues/302
2022-05-23, 10:01
I have two Android TV Boxes. Do I need to create two Client API Keys to use the Youtube Addon on each Box ?
2022-05-23, 12:04
No, they can share one.
2022-05-23, 12:12
Thank you
2022-05-24, 15:47
When I add/subscribe a public playlist from another user to my own mediathek, it is not shown in the addon under playlists.
In the web YouTube it is shown.
My workaround for now is to create a new playlist and add all videos from the other playlist manually.
Did I miss any option?
2022-05-24, 17:14
(2022-05-10, 00:50)xenophrenia Wrote: [ -> ]the last release was October 2021 - how is that great support?
If the current addons version it's correctly configurated it basically works worthily.
At my advise the only the only aspect how the addons need some fix it's on VIDEO BLOCKED by AGE Restiction or other stu**d idea recently things added by youtube.......
2022-05-27, 20:37
Sorry for double post but i don't know because... when try to edit i obtain an error when try to save them... strange.
Anyway i have found another things need to be fix or improve the experience if possible....... the support of "Premiere" Video.
Currently when you found and when you try to reproduce a Video in "Premiere" there's no possible to step backward or step forward during the reproduction. When try to open the video you can only watch the video at current timeline....... during a livestream, if i remember, you can step backward.
2022-05-28, 11:59
I am having an issue where some videos only play in 480p.
I know for a fact that there are higher resolution versions of the videos available, I can pick those when watching through the website, however Kodi only shows the 480p stream available.
Some videos play just fine in 720p, there seems to be no pattern to it.
2022-05-28, 13:51
(2022-05-28, 11:59)Doc_f11 Wrote: [ -> ]I am having an issue where some videos only play in 480p.
Update:
Messing with the bandwidth limits and HDCP settings in InputstreamAdaptive seems to have resolved this issue. No clue why.
