Hello when using my playlist, when I press remove, the video is not removed. If I press refresh then I can remove the video. Seems to remove a few videos and then I have to press refresh again. Any ideas or help to fix this? Thanks again for everything.
Has anything changed since yesterday?
Today I get
When trying to start a video in KODI, I get the message: Player response failed for video_id: v5_TF074S4g using android client (logged in).
Log:
https://paste.kodi.tv/ebotegubik.kodi
Having the same issue here.
Thank you.
Manual Update worked for me.
I'm getting player response failed ... using android client(logged in) when I try to play a vid.
update to "latest" (7.0.3.2) on github worked. says it is the same 7.0.2.2 in Kodi
(2024-03-07, 02:55)donbrew2 Wrote: [ -> ]update to "latest" (7.0.3.2) on github worked. says it is the same 7.0.2.2 in Kodi
Downgrading to 7.0.2~alpha7 worked for a quick fix. heading to github now for the upgrade. thanks guys!
same. will update and see how that goes
The watch later videos wouldn't play for me, so I installed 7.0.3 beta 5 and it got me up and running again.
I updated to 7.0.3.2 yesterday. Since this version of the add-on skipping does not seem to work as it used to (at least on a Firecube).
The clip freezes for a 3-6 seconds while the sound continues till the video catches up again. Does anybody else have the same issues?
I also updated from 7.0.2.2 to 7.0.3.2 since that time videos are played but picture and sound are not synchron. Pictures are to slow and after a minute or more pictures will be skiped.
(2024-03-08, 11:21)phyrros1 Wrote: [ -> ]I updated to 7.0.3.2 yesterday. Since this version of the add-on skipping does not seem to work as it used to (at least on a Firecube).
yes - been like that for a while for me (latest kodi on nvidia shield)
