(2017-02-21, 01:28)marcelveldt Wrote: [ -> ] (2017-02-16, 18:39)lviperz Wrote: [ -> ]However, I have now lost the ability to select the random pvr recordings background. It was there when I first installed the beta and I selected it, but it never would show the background. Thought I would give it time, even tried exiting spmc and waiting again when I relaunched spmc. Now I don't even have the option to select it.
Also I've noticed that there is a delay after a fresh launch of spmc before I can see any of the playlist options when setting backgrounds and thumbnails. Is there something I can manually run to get these to show up in the menu?
It should be called "Random PVR Background", I believe it was renamed a few weeks back.
As for the second issue that it takes some time before they're available, I will fix this in the next update.
Yes, I know it's called Random PVR Background and I have it selected. Problem is the fanart will not always display for the thumbnail or background. When that happens the option to select Random PVR Background is gone. WHen it does display, some of them are blank.
This is on my Nvidia Shield TV running SPMC 16.5.5. I did a test on a windows box to get access to the log easily. Here is a section of the log showing the pvr fanart not being found but it is actually there. However, the log shows it is looking for a folder but it isn't a folder, it's actually a jpg image stored without the extension.
10:00:04 T:11752 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6251_1475546460_00d\
10:00:15 T:1544 ERROR: Previous line repeats 2 times.
10:00:15 T:1544 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6441_1478224800_024\
10:00:24 T:11752 ERROR: Previous line repeats 2 times.
10:00:24 T:11752 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6251_1475719200_00f\
10:00:35 T:11752 ERROR: Previous line repeats 2 times.
10:00:35 T:11752 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6442_1476144000_012\
10:00:54 T:9440 ERROR: Previous line repeats 2 times.
10:00:54 T:9440 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6251_1476324000_014\
10:01:05 T:8136 ERROR: Previous line repeats 2 times.
10:01:05 T:8136 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\6251_1477620000_020\
10:01:13 T:11520 ERROR: Previous line repeats 2 times.
And here is the folder listing for C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart\
Directory of C:\Users\davea\AppData\Roaming\Kodi\userdata\addon_data\pvr.mythtv\cache\fanart
02/21/2017 10:07 AM <DIR> .
02/21/2017 10:07 AM <DIR> ..
02/20/2017 09:56 AM 357,137 6141_1483754400_04b
02/20/2017 09:56 AM 357,137 6141_1484359200_04e
02/20/2017 09:56 AM 357,137 6141_1484964000_054
02/20/2017 09:56 AM 357,137 6141_1485568800_05d
02/20/2017 09:56 AM 357,137 6141_1486173600_064
02/20/2017 09:56 AM 357,137 6141_1486778400_068
02/20/2017 09:56 AM 357,137 6141_1487383200_0b3
02/21/2017 09:59 AM 521,708 6141_1487646000_0c6
02/20/2017 09:56 AM 466,943 6251_1474509600_003
02/20/2017 09:56 AM 306,261 6251_1474596000_005
02/20/2017 09:56 AM 466,943 6251_1475114400_008
02/20/2017 09:56 AM 306,261 6251_1475200800_00b
02/20/2017 09:56 AM 534,786 6251_1475546460_00d <-- first error in log
02/20/2017 09:56 AM 466,943 6251_1475719200_00f
02/20/2017 11:23 AM 306,261 6251_1475805600_010
02/20/2017 09:56 AM 534,786 6251_1476151260_009
02/20/2017 09:56 AM 466,943 6251_1476324000_014
02/20/2017 09:56 AM 306,261 6251_1476410400_016
02/20/2017 09:56 AM 534,786 6251_1476756060_019
02/20/2017 09:57 AM 306,261 6251_1477015200_01b
02/20/2017 09:57 AM 534,786 6251_1477360860_01c
02/20/2017 09:57 AM 466,943 6251_1477533600_01f
02/20/2017 09:57 AM 306,261 6251_1477620000_020
02/20/2017 09:57 AM 306,261 6251_1478224800_025
02/20/2017 09:57 AM 534,786 6251_1478574060_028
02/20/2017 09:57 AM 466,943 6251_1478746800_02a
02/20/2017 09:57 AM 306,261 6251_1478833200_02d
02/20/2017 09:57 AM 534,786 6251_1479178860_026
02/20/2017 09:57 AM 306,261 6251_1479438000_030
02/20/2017 09:57 AM 534,786 6251_1479783660_035
02/20/2017 09:57 AM 534,786 6251_1480388460_039
02/20/2017 09:57 AM 466,943 6251_1480561200_03a
02/20/2017 09:57 AM 534,786 6251_1480993200_03d
02/20/2017 09:57 AM 466,943 6251_1481166000_040
02/20/2017 09:57 AM 466,943 6251_1481770800_03e
02/20/2017 09:57 AM 534,786 6251_1483326000_047
02/20/2017 09:57 AM 534,786 6251_1483930800_04c
02/20/2017 09:57 AM 534,786 6251_1484535600_04f
02/20/2017 09:57 AM 741,587 6251_1485482460_059
02/20/2017 09:57 AM 306,261 6251_1485486000_05b
02/20/2017 09:57 AM 534,786 6251_1485745200_055
02/20/2017 09:57 AM 741,587 6251_1486087260_060
02/20/2017 09:57 AM 306,261 6251_1486090800_062
02/20/2017 09:57 AM 741,587 6251_1486692060_069
02/20/2017 09:57 AM 306,261 6251_1486695600_06b
02/20/2017 09:57 AM 741,587 6251_1487296860_09d
02/20/2017 09:57 AM 306,261 6251_1487300400_09f
02/21/2017 09:59 AM 763,618 6251_1487646060_0c7
02/20/2017 09:57 AM 206,445 6441_1474419600_002
02/20/2017 09:57 AM 206,445 6441_1475024400_007
02/20/2017 09:58 AM 206,445 6441_1476234000_013
02/20/2017 09:58 AM 206,445 6441_1476838800_01a
02/20/2017 09:58 AM 206,445 6441_1477443600_01e
02/20/2017 09:58 AM 333,280 6441_1477620000_021
02/20/2017 09:58 AM 333,280 6441_1478224800_024 <-- log error
02/20/2017 09:58 AM 333,280 6441_1478833200_02c
02/20/2017 09:58 AM 206,445 6441_1479261600_02f
02/20/2017 09:58 AM 333,280 6441_1479438000_033
02/20/2017 09:58 AM 206,445 6441_1479866400_036
02/20/2017 09:58 AM 333,280 6441_1480042800_037
02/20/2017 09:58 AM 333,280 6441_1480647600_03c
02/20/2017 09:58 AM 206,445 6441_1481076000_03f
02/20/2017 09:58 AM 333,280 6441_1481252400_042
02/20/2017 09:58 AM 206,445 6441_1481680800_043
02/20/2017 09:58 AM 333,280 6441_1481857200_044
02/20/2017 09:58 AM 791,868 6441_1483320600_045
02/20/2017 09:58 AM 333,280 6441_1483324200_046
02/20/2017 09:58 AM 206,445 6441_1483495200_048
02/20/2017 09:58 AM 333,280 6441_1483671600_049
02/20/2017 09:58 AM 791,868 6441_1483837200_017
02/20/2017 09:58 AM 333,280 6441_1484276400_029
02/20/2017 09:58 AM 206,445 6441_1484704800_051
02/20/2017 09:58 AM 333,280 6441_1484881200_052
02/20/2017 09:58 AM 791,868 6441_1485046800_056
02/20/2017 09:58 AM 206,445 6441_1485309600_058
02/20/2017 09:58 AM 333,280 6441_1485486000_05a
02/20/2017 09:58 AM 791,868 6441_1485651600_05e
02/20/2017 09:58 AM 346,641 6441_1486090800_061
02/20/2017 09:58 AM 791,868 6441_1486256400_065
02/20/2017 09:58 AM 206,445 6441_1486519200_067
02/20/2017 09:58 AM 346,641 6441_1486695600_06a
02/20/2017 09:58 AM 791,868 6441_1486861200_06c
02/20/2017 09:58 AM 198,702 6441_1487041200_06e
02/20/2017 09:58 AM 206,445 6441_1487124000_070
02/20/2017 09:58 AM 460,617 6441_1487214000_087
02/20/2017 09:59 AM 346,641 6441_1487300400_09e
02/20/2017 09:59 AM 338,680 6441_1487383200_0b2
02/20/2017 09:59 AM 316,706 6441_1487386800_0b4
02/20/2017 09:59 AM 791,868 6441_1487466000_0b7
02/20/2017 09:59 AM 132,393 6441_1487556000_0bc
02/21/2017 09:59 AM 198,702 6441_1487646000_0c5
02/20/2017 09:59 AM 493,584 6442_1474329600_001
02/20/2017 09:59 AM 806,293 6442_1474592340_004
02/20/2017 09:59 AM 493,584 6442_1474934400_006
02/20/2017 09:59 AM 806,293 6442_1475197140_00a
02/20/2017 09:59 AM 493,584 6442_1475539200_00c
02/20/2017 09:59 AM 806,293 6442_1475801940_011
02/20/2017 09:59 AM 493,584 6442_1476144000_012
02/20/2017 09:59 AM 806,293 6442_1476406740_015
02/20/2017 09:59 AM 493,584 6442_1476748800_018
02/20/2017 09:59 AM 493,584 6442_1477353600_01d
02/20/2017 09:59 AM 806,293 6442_1477616340_00e
02/20/2017 09:59 AM 493,584 6442_1477958400_022
02/20/2017 09:59 AM 806,293 6442_1478221140_023
02/20/2017 09:59 AM 493,584 6442_1478566800_027
02/20/2017 09:59 AM 806,293 6442_1478829540_02b
02/20/2017 09:59 AM 493,584 6442_1479171600_02e
02/20/2017 09:59 AM 806,293 6442_1479434340_032
02/20/2017 09:59 AM 493,584 6442_1479776400_034
02/20/2017 09:59 AM 493,584 6442_1480381200_038
02/20/2017 09:59 AM 806,293 6442_1480643940_03b
02/20/2017 10:00 AM 806,293 6442_1481248800_041
02/20/2017 10:00 AM 493,584 6442_1484614800_050
02/20/2017 10:00 AM 493,584 6442_1485219600_057
02/20/2017 10:00 AM 493,584 6442_1485824400_05f
02/20/2017 10:00 AM 787,757 6442_1486432860_066
02/20/2017 10:00 AM 787,757 6442_1487037660_06d
02/21/2017 10:00 AM 787,757 6442_1487642460_0c4
