According to 3.6.115:
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]a) Lower the widget doesn't work as before.
Try to set the widget layout to single row to see if that helps.
The problem happens only in "Widget rows: Single Widget Large" (With the others it's ok)
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]b) Why when choosing "Widget rows: Single Widget Large" the squares/landscapes items are arranged in columns and not by rows as before? Where can I change it to be by rows as before?
Should be fixed already in latest update.
Can you still make it as an option also?
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]c) Where can I set the alignment of the widgets? (To the left/right) because it was to the right and now it's to the left.
Skin setings --> homescreen layout --> align widgets to the right.
I don't find it there.
There is only main menu alignment.
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]d) I see you change the tags info title on the widgets, is there any settings to configure their content? (Like add date etc... instead episode name)
Not yet but I'm working on that. It will be configurable in next release version so after the current version is released to stable.
* By the way, there is a known problem (No just here), when there is multi language in the same title (The text swapped, and there is no space)
Is there any thing that can be done to fix this?
https://s3.postimg.org/4nsk08ao3/screenshot026_e.png
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]e) It seems that you expanded the gap between the widgets or increased the widget size. So in some menu items there is now vertical scroll bar which isn't looking nice. ("Widget rows: Multiple Widgets" )
Should be fixed already in most recent update
There is still not equal gaps, small difference - OCD thing
* Gap 1 is a little bigger then 2.
Screenshot:
https://s10.postimg.org/t5e1rwwbt/screenshot026_b.png
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]f) Set background as widget fanart for main menu item - doesn't work.
(Checked with Single Box widget, as single widget or as widget number 2 in multiple widgets)
Correct, it will be fixed again but it will no longer be possible to specify for which widget.
It's still not working.
The background is changing only when I focus on the widget.
I want that the background will follow a specific widget even when standing on the main menu item (As before)
Or by widget when you stand in it, by the focused item.
And regarding your comment, why?
I have always used it until now.
For example the constellation is like this:
https://s10.postimg.org/nv930mc2x/screenshot026_c.png
So I want the background will be by widget 2 as default (Like it was previously)
Can you bring it back please?
(* By the way, I still have the options of "Use widget # fanart as background" when there are more then one widget)
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]g) It seems that the single box design has changed, so there is no gap between the info text to the frame of the widget.
Will be fixed in next update
But again, OCD thing, can you reduce the border of the text in more one or two pixels ?
Look here:
https://s8.postimg.org/4dnntnevp/screenshot019.png
(2017-03-04, 15:03)marcelveldt Wrote: [ -> ] (2017-03-01, 23:25)burekas Wrote: [ -> ]* Why the scrollbar is showing here if all the items in the screen?
(By the way, with landscape layout there is no scrollbar, but still it arranged by columns and not by rows as before)
Should both be fixed in next update, please test
New issues:
h) [bug] There is annoying vertical line in the single box layout.
screenshot:
https://s16.postimg.org/khs0umg9x/screenshot029.png
i) I still need to check this, but it seems that the TV Shows fanarts doesn't included in the "Global Movies & Tv Shows background" option.
j) Sometimes when moving between items fanarts in the widgets, there are flickers of the global background.
