I use this addon all the time. It's become a must that whatever skin I use has integrated it at least to some extent.
The only thing I have been hoping for is the option of disabling the numpad keyboard, so that the classic keyboard opens up by default.
Seems like it shouldn't be too hard to implement.
Here
tk's
EDIT : search for "Interscope Communications"
I have pressed "info" on a different movie.
Small heads-up for skinners:
For the next version some calls will change:
similarmoviestrakt --> traktsimilarmovies
similartvshowstrakt --> traktsimilartvshows
airingshows --> airingepisodes
premiereshows --> premiereepisodes
intheaters --> intheatermovies
boxoffice --> boxofficemovies
opening --> openingmovies
comingsoon --> comingsoonmovies
toprentals --> toprentalmovies
currentdvdreleases --> currentdvdmovies
newdvdreleases --> newdvdmovies
upcomingdvds --> upcomingdvdmovies
That way the call always ends with the content type of the list it returns, which should make things a bit easier for you skinners, too.
EDIT: forgot to mention that the calls returning images were removed, too. (I just released XKCD as well as Cyanide & happiness as separate image plug-ins in case you miss them
Thank you so much. ExtendedInfo is amazing. It should be included in Kodi by default.
Phil,
Seeing as you've dropped miscscraper and built plugins for XKCD & C&H then would it be possible for a plugin for Daily babe / Daily babes. I know that users use those options and as such if you had the time and it was possible?
I know you're very busy but just wondered, before all the questions start getting raised why they are broken in my skin.
and you see what happend on silvester in cologne when men dont get their daily babes anymore
Hey why isnt the In theater Widget working with my xperience1080 anymore?
Phil could you add support for the Trakt list manager
http://forum.kodi.tv/showthread.php?tid=161319, i tested it out by just adding the line above the one you have for couchpotato and it worked just fine. Although might wanna remove the notification as the addon gives one itself when added
I got an error that seems to be related to the Swedish characters ÅÄÖ
Log
(2016-02-24, 21:11)macardi Wrote: [ -> ]Hi,
Log
Please try latest commit.
20:55:17 T:15104 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named YDStreamExtractor
File "C:\Users\Hakker\AppData\Roaming\Kodi\addons\script.extendedinfo-master\plugin.py", line 10, in <module>
from resources.lib.process import start_info_actions
File "C:\Users\Hakker\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\process.py", line 17, in <module>
import VideoPlayer
File "C:\Users\Hakker\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\VideoPlayer.py", line 10, in <module>
import YDStreamExtractor
ImportError: No module named YDStreamExtractor
import VideoPlayer
20:57:23 T:2016 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/
20:57:23 T:2016 ERROR: CGUIMediaWindow::GetDirectory(plugin://script.extendedinfo/) failed -->End of Python script error report<--
20:55:17 T:13020 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/?info=directormovies&&director=Casey Walker
20:56:13 T:10388 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:57:22 T:2016 ERROR: Control 502 in window 10025 has been asked to focus, but it can't
I'm using it with the eminence mod 2 skin but I'm pretty sure it's a script issue and maybe the fact that I use the DSplayer. I just hope it helps.
(2016-02-26, 22:16)Hakker Wrote: [ -> ]Code:
import VideoPlayer
import VideoPlayer
You didn't install the addon properly. Some dependencies are not available on your machine.
