(2017-08-23, 16:25)Angelinas Wrote: [ -> ]You dont use script for all content...after your try, we will see are you change your question..
Try music, for example...
Most loved song ....I cant image extended info for some Artist without this info
You're correct. I do not use every aspect of this script cause I cannot guarantee it will always work. If I rely on scripts for everything then things are gonna break on a regular basis due to a number of factors beyond my control i.e. API changes, script updates, lack of script updates, and/or even feature removals.
I may add things that are nice to have but will always do my best to use skin engine over scripts whenever possible and if it is not possible try to at least be real picky about what to use to minimize any issues in the first place
I just want things to work without sending users to update this or that when >90% of them just want to play their media without any issues.
IMHO of course
(2017-08-23, 20:14)HumanGoing Wrote: [ -> ]Hi,
Is it possible to set up a home menu shortcut that can run a search through extendedinfo? Or maybe a submenu action? Thanks!
Try Super Favorites addon. It may be able to.
This module is not working....on android TV. Works on Windows just fine
21:27:15.513 T:138535216208 WARNING: SMBFile::OpenForWrite() called with overwriting enabled! - smb://192.168.1.4/xbmcsql/userdata/Thumbnails/8/806fd450.jpg
21:27:19.569 T:138552464464 NOTICE: script.module.youtube.dl: youtube_dl core version: 2017.07.09
21:27:19.681 T:138092250192 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=extendedtvinfo&&id=62127
21:27:19.877 T:138552464464 WARNING: CPythonInvoker(12, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.extendedinfo/plugin.py): the python script "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.extendedinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
21:27:55.555 T:138402776144 NOTICE: script.module.youtube.dl: youtube_dl core version: 2017.07.09
21:27:55.656 T:138092250192 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=extendedtvinfo&&id=62127
21:27:55.846 T:138402776144 WARNING: CPythonInvoker(13, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.extendedinfo/plugin.py): the python script "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.extendedinfo/plugin.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui10DialogBusyE
21:28:47.253 T:138092250192 NOTICE: Samba is idle. Closing the remaining connections
21:28:52.715 T:138402776144 WARNING: SMBFile::OpenForWrite() called with overwriting enabled! - smb://192.168.1.4/xbmcsql/userdata/Thumbnails/0/056cc63a.jpg
21:28:56.417 T:138526286928 NOTICE: script.module.youtube.dl: youtube_dl core version: 2017.07.09
21:28:56.503 T:138092250192 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=extendedtvinfo&&id=1429
Guys, its an issue since since 17.4.
For people experiencing issues with Extended info script on Android/ATV with v17.4 :
Download & install script.module.pil from
here
(I did not make any changes, I simply extracted it from the 17.3.apk)
For me it fixed the issue on android but I do not own any Apple stuff so if someone with an ATV4 could try & confirm please?
(2017-08-25, 10:45)Quihico Wrote: [ -> ]For people experiencing issues with Extended info script on Android/ATV with v17.4 :
Download & install script.module.pil from here
Thanks working for me with script.extendedinfo.5.6.0[Krypton(17.x)_Fix] form
here.
(2017-08-24, 01:57)mikeSiLVO Wrote: [ -> ] (2017-08-23, 16:25)Angelinas Wrote: [ -> ]You dont use script for all content...after your try, we will see are you change your question..
IMHO of course
(2017-08-29, 14:13)pcristi Wrote: [ -> ] (2017-08-25, 10:45)Quihico Wrote: [ -> ]For people experiencing issues with Extended info script on Android/ATV with v17.4 :
Thanks working for me with script.extendedinfo.5.6.0[Krypton(17.x)_Fix] form here.
Is there one for version 5.04 (mod version)
(2017-08-29, 15:50)dcamacho Wrote: [ -> ]Is there one for version 5.04 (mod version)
Extended Info Mod is not the same addon and is not made by the same people than Extended Info
Why don't you ask for a fix to those who make this modded version?
(2017-08-29, 16:25)Gracus Wrote: [ -> ] (2017-08-29, 15:50)dcamacho Wrote: [ -> ]Is there one for version 5.04 (mod version)
Sorry about that, wrong forum.
[/quote]
here.
[/quote]
Didn't work
I was running 17.3 on my ShieldTV just fine. It upgraded to 17.4 and ExtendedInfo stopped working.
(2017-08-31, 00:03)mmccking Wrote: [ -> ]I was running 17.3 on my ShieldTV just fine. It upgraded to 17.4 and ExtendedInfo stopped working.
kodi 7.3 is also running great on my Shield TV. No need for me to upgrade at the moment.
1) Backup your kodi using the Backup add-on. make sure you have all the boxes ticked shown below
2) Uninstall kodi 7.4
3) Turn off auto update in the google store
4) Install kodi 7.3
5) Restore kodi using Backup
Thanks Blurayx. What's the safest way to get the 17.3?
