2021-07-17, 07:53
There is indeed a bug that I guess is Python 3, when getting extended info for a TV show episode. I have to check on seasons.
scott s.
scott s.
(2021-07-17, 07:53)scott967 Wrote: [ -> ]There is indeed a bug that I guess is Python 3, when getting extended info for a TV show episode. I have to check on seasons.
scott s.
(2021-07-17, 18:47)Bungee_G Wrote: [ -> ]@scott967 but I also have the bug with the tv show not only with tv show episode. the dbid=$INFO[ListItem.DBID] doesn't work it only works when name=$INFO[ListItem.Title] but name=$INFO[ListItem.Title] is not accurate, because there can be multiple tv show with the same name, for example I have a tv show named "Another" but it displays a tv show named "Another Life". That's why I have to use the dbid=$INFO[ListItem.DBID] but it doesn't work.I will look into this. Meanwhile, I have fixed the issue that caused an exception when skin requests extra info for seasons and episodes. Updated addon to +matrix.4 in my repo and also available on github. My skin uses ListItem.Title so I haven't tested for this. But it is in the same code area in process.py I think.
(2021-07-17, 18:47)Bungee_G Wrote: [ -> ]@scott967 but I also have the bug with the tv show not only with tv show episode. the dbid=$INFO[ListItem.DBID] doesn't work it only works when name=$INFO[ListItem.Title] but name=$INFO[ListItem.Title] is not accurate, because there can be multiple tv show with the same name, for example I have a tv show named "Another" but it displays a tv show named "Another Life". That's why I have to use the dbid=$INFO[ListItem.DBID] but it doesn't work.Probably need a debug log to confirm what is going on. In general, though, when supplied a DBID the script tried to get the tmdb id number from the videodatabase, and if none might try to lookup. But there's different things that can happen so need a log to see.
(2021-07-21, 04:15)scott967 Wrote: [ -> ](2021-07-17, 18:47)Bungee_G Wrote: [ -> ]@scott967 but I also have the bug with the tv show not only with tv show episode. the dbid=$INFO[ListItem.DBID] doesn't work it only works when name=$INFO[ListItem.Title] but name=$INFO[ListItem.Title] is not accurate, because there can be multiple tv show with the same name, for example I have a tv show named "Another" but it displays a tv show named "Another Life". That's why I have to use the dbid=$INFO[ListItem.DBID] but it doesn't work.Probably need a debug log to confirm what is going on. In general, though, when supplied a DBID the script tried to get the tmdb id number from the videodatabase, and if none might try to lookup. But there's different things that can happen so need a log to see.
Also need to see how the script was called (parameters).
scott s.
to this onexml:<onclick condition="String.IsEqual(ListItem.DBTYPE,tvshow)">RunScript(script.extendedinfo,info=extendedtvinfo,name=$INFO[ListItem.Title])</onclick>
Then click on a tv show information then on the extended info button. You won't see informations about the tv show (it will be written "tv show info not available")xml:<onclick condition="String.IsEqual(ListItem.DBTYPE,tvshow)">RunScript(script.extendedinfo,info=extendedtvinfo,dbid=$INFO[ListItem.DBID])</onclick>
(2021-07-21, 17:09)Bungee_G Wrote: [ -> ]OK, but log would still help as the script does write some useful stuff to the log. That toast means the script couldn't get a tmdb_id for the show, but I will look more closely.(2021-07-21, 04:15)scott967 Wrote: [ -> ](2021-07-17, 18:47)Bungee_G Wrote: [ -> ]@scott967 but I also have the bug with the tv show not only with tv show episode. the dbid=$INFO[ListItem.DBID] doesn't work it only works when name=$INFO[ListItem.Title] but name=$INFO[ListItem.Title] is not accurate, because there can be multiple tv show with the same name, for example I have a tv show named "Another" but it displays a tv show named "Another Life". That's why I have to use the dbid=$INFO[ListItem.DBID] but it doesn't work.Probably need a debug log to confirm what is going on. In general, though, when supplied a DBID the script tried to get the tmdb id number from the videodatabase, and if none might try to lookup. But there's different things that can happen so need a log to see.
scott s.
I think it would be better if you test by yourself what I did : I scraped some tv shows with MediaElch. Then I tried the extendedinfo script in different skins. For example in the Metropolis skin, change the DialogVideoInfo.xml file. Change this lineto this onexml:<onclick condition="String.IsEqual(ListItem.DBTYPE,tvshow)">RunScript(script.extendedinfo,info=extendedtvinfo,name=$INFO[ListItem.Title])</onclick>
(2021-07-21, 22:37)scott967 Wrote: [ -> ]Okay thanks. I don't know if I did it well but here is the log : https://paste.kodi.tv/ohuyacesak.kodi(2021-07-21, 17:09)Bungee_G Wrote: [ -> ]OK, but log would still help as the script does write some useful stuff to the log. That toast means the script couldn't get a tmdb_id for the show, but I will look more closely.(2021-07-21, 04:15)scott967 Wrote: [ -> ]Probably need a debug log to confirm what is going on. In general, though, when supplied a DBID the script tried to get the tmdb id number from the videodatabase, and if none might try to lookup. But there's different things that can happen so need a log to see.
scott s.
scott s.
(2021-07-24, 03:35)Bungee_G Wrote: [ -> ]@scott967 have you seen the log ?Unfortunately your log shows plugin.video.venom installed, which is on the addon blacklist. So no further analysis can be given for that client.
Also I don't understand why most of the skins use name=$INFO[ListItem.Title] while it's not accurate... dbid="$INFO[ListItem.DBID]" is.
(2021-07-24, 22:09)scott967 Wrote: [ -> ]I deleted this addon, a while ago but thanks to you I just found out 2 related addons that weren't uninstalled...(2021-07-24, 03:35)Bungee_G Wrote: [ -> ]@scott967 have you seen the log ?Unfortunately your log shows plugin.video.venom installed, which is on the addon blacklist. So no further analysis can be given for that client.
However, I will advise that extendedinfo is working as designed. If extendedtvinfo is requested with a DBID, a query of the videodatabase is done to get the tmdb id for that DBID. If found the tmdb will be used to query tmdb site. If no tmdb id is in the database then the addon will not attempt to query tmdb for info.
In the case that extendedtvinfo is requested with the show title, the addon will query tmdb with the title and attempt to scrape the tmdb id. I don't know why the addon was designed this way; I assume there is a valid reason (my assumption is that if the show is in the database, it must have been scraped prior so the tmdb id should be available).
The tmdb v3 api query does allow for a tv "year first shown" query parameter and it is possible to add that as a parameter when skins request extendedtvinfo by adding year=$INFO[ListItem.Year]. I have added that for testing. It can also be used for movies, but in that case tmdb has 2 different year options: year, and first release year. Since Kodi only stores 1 premier value I assume that's first release year, but will have to look at the scraper code to verify.
scott s.
xml:2021-08-31 23:53:04.162 T:13504 ERROR <general>: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.extendedinfo/resources/lib/dialogs/DialogMovieInfo.py", line 247, in set_omdb_infos_async
2021-08-31 23:53:04.163 T:13504 ERROR <general>:
2021-08-31 23:53:04.163 T:13504 ERROR <general>: self.omdb_thread.join()
2021-08-31 23:53:04.164 T:13504 ERROR <general>:
2021-08-31 23:53:04.164 T:13504 ERROR <general>: AttributeError
2021-08-31 23:53:04.164 T:13504 ERROR <general>: :
2021-08-31 23:53:04.164 T:13504 ERROR <general>: 'DialogMovieInfo' object has no attribute 'omdb_thread'
