2013-10-31, 19:05
This is for sure a very stupid question, but here it goes: how do I install this? I go to your github repo, download the zip, then in XBMC choose "Install from zip file", but nothing happens... What am i missing?
(2013-11-06, 21:14)sv0911 Wrote: [ -> ]The view of the movie "titles" from a collection/set as labels are working correct but when i scroll the movie-list, the titles from the last viewed set do not disappear...
<visible>ListItem.IsFolder</visible>
<visible>IntegerGreaterThan(Window(0).Property(Set.Movies.count),0)</visible>
(2013-11-07, 13:13)Sranshaft Wrote: [ -> ](2013-11-06, 21:14)sv0911 Wrote: [ -> ]The view of the movie "titles" from a collection/set as labels are working correct but when i scroll the movie-list, the titles from the last viewed set do not disappear...
You should be able to fix that with a <visibile> tag in the group control.
Code:<visible>ListItem.IsFolder</visible>
Or use the following to make sure they don't appear for other non-collection folders.
Code:<visible>IntegerGreaterThan(Window(0).Property(Set.Movies.count),0)</visible>
(2013-11-07, 13:36)sv0911 Wrote: [ -> ]can you please explain/clarify how to do that(2013-11-07, 13:13)Sranshaft Wrote: [ -> ](2013-11-06, 21:14)sv0911 Wrote: [ -> ]The view of the movie "titles" from a collection/set as labels are working correct but when i scroll the movie-list, the titles from the last viewed set do not disappear...
Big big thanks Sranshaft,
very kind of you!!!!!
I use the second tag suggestions and it works very well.
I implemented the tags under every label and adjusted the counts # 0,1, a.s.o...!!
Again, big thanks to you...!!!!!!
(2013-11-17, 11:18)MeniBI Wrote: [ -> ](2013-11-07, 13:36)sv0911 Wrote: [ -> ]can you please explain/clarify how to do that(2013-11-07, 13:13)Sranshaft Wrote: [ -> ]You should be able to fix that with a <visibile> tag in the group control.
"LibraryPath" : 'musicdb://artists/' + str(item['artistid']) + '/' }
if xbmc.getCondVisibility("!IsEmpty(ListItem.DBID) + [SubString(ListItem.Path,videodb://movies/sets/,left)| Container.Content(artists) | Container.Content(albums)]"):
(2013-11-18, 22:55)sv0911 Wrote: [ -> ](2013-11-17, 11:18)MeniBI Wrote: [ -> ](2013-11-07, 13:36)sv0911 Wrote: [ -> ]Big big thanks Sranshaft,can you please explain/clarify how to do that
Sure,
here the way i got it working for me (example for 3 labels.. just look at the counts:
<control type="label">
<width>235</width>
<scroll>true</scroll>
<scrollspeed>20</scrollspeed>
<font>Font_Neon_15</font>
<textcolor>FFFFFFFF</textcolor>
<label>$INFO[Window(0).Property(Set.Movie.1.Title)] $INFO[Window(0).Property(Set.Movie.1.Year)]</label>
</control>
<width>235</width>
<label>$INFO[Window(0).Property(Set.Movie.2.Title)] $INFO[Window(0).Property(Set.Movie.2.Year)]</label>
<visible>IntegerGreaterThan(Window(0).Property(Set.Movies.count),1)</visible>
</control>
<width>235</width>
<label>$INFO[Window(0).Property(Set.Movie.3.Title)] $INFO[Window(0).Property(Set.Movie.3.Year)]</label>
<visible>IntegerGreaterThan(Window(0).Property(Set.Movies.count),2)</visible>
</control>
I used it also for the covers...
Here how it looks now on my modded skin:
Greetings
sv0911
