2020-04-10, 23:51
Question which skins does this work with , I use it for Arctic-Zephyr but in kodi 17.6 I can't get plexkodiconnect to resume files & in kodi 18.6, fast forward & rewind are horrible with speed. So I am stuck.
(2019-12-12, 01:03)ontap Wrote: [ -> ]I have this script enabled in madnox skin, when i long press on OK whilst highlighting a movie, the extended info page slides into view , but when highlighting "play" on screen and pressing OK on keyboard or remote, nothing happens ? is there a setting anyway to activate the "play" button in EIS please ?
EDIT: found "patch" that Angelinas submitted , fixed, thank you sir.
(2020-05-29, 18:54)scott967 Wrote: [ -> ]I have been working on this script (and dependency kodi65 same author) for Kodi 19. To play youtube video via extendedinfo it is best to use the youtube plugin called from the script. Also, to search Youtube, there was a hard-coded api key in kodi65 and these no longer work. You need your own api key (the one you need also for the Youtube plugin). I have it all working, but it is for Matrix only so not backwards compatible (my practice is to strip out non-working python2 code, not to try to make the same code base work in both python 2 and 3). Feel free to checkout my Matrix branches of the two addonsHey Scott any chance you would have a simple solution to my issue down here?
kodi65
extendedinfo
scott s.
Quote:I've been trying to customize script.extendedinfo so that a widget automatically lists all results of a search eg.: all movies in Portuguese language, sorted by descending date?
I looked into all the lists of command but can't seem to find an example for original language or country of origin and sorting parameters to add to RunScript(script.extendedinfo,)
(2020-06-04, 12:44)rorolei Wrote: [ -> ]I will have to take some time to investigate/ think about this. Note that my goal was just to get the script working in Kodi 19 as it did before and I'm not that good about what the script really can do.(2020-05-29, 18:54)scott967 Wrote: [ -> ]I have been working on this script (and dependency kodi65 same author) for Kodi 19. To play youtube video via extendedinfo it is best to use the youtube plugin called from the script. Also, to search Youtube, there was a hard-coded api key in kodi65 and these no longer work. You need your own api key (the one you need also for the Youtube plugin). I have it all working, but it is for Matrix only so not backwards compatible (my practice is to strip out non-working python2 code, not to try to make the same code base work in both python 2 and 3). Feel free to checkout my Matrix branches of the two addonsHey Scott any chance you would have a simple solution to my issue down here?
kodi65
extendedinfo
scott s.
(2020-06-09, 19:03)scott967 Wrote: [ -> ]Of course. If you manage to pull something like that out if and whenever you have some spare time itll be awesome(2020-06-04, 12:44)rorolei Wrote: [ -> ]I will have to take some time to investigate/ think about this. Note that my goal was just to get the script working in Kodi 19 as it did before and I'm not that good about what the script really can do.(2020-05-29, 18:54)scott967 Wrote: [ -> ]I have been working on this script (and dependency kodi65 same author) for Kodi 19. To play youtube video via extendedinfo it is best to use the youtube plugin called from the script. Also, to search Youtube, there was a hard-coded api key in kodi65 and these no longer work. You need your own api key (the one you need also for the Youtube plugin). I have it all working, but it is for Matrix only so not backwards compatible (my practice is to strip out non-working python2 code, not to try to make the same code base work in both python 2 and 3). Feel free to checkout my Matrix branches of the two addonsHey Scott any chance you would have a simple solution to my issue down here?
kodi65
extendedinfo
scott s.
scott s.
# -*- coding: utf8 -*-
# Copyright © 2015 - Philipp Temminghoff <phil65@kodi.tv>
# This program is Free Software see LICENSE file for details
import os
import re
import xbmc
import xbmcgui
import xbmcvfs
import TheMovieDB as tmdb
from kodi65 import windows
from kodi65 import addon
from kodi65 import utils
from kodi65 import busy
from kodi65 import player
from kodi65 import local_db
INFO_XML_CLASSIC = u'script-%s-DialogVideoInfo.xml' % (addon.ID)
LIST_XML_CLASSIC = u'script-%s-VideoList.xml' % (addon.ID)
ACTOR_XML_CLASSIC = u'script-%s-DialogInfo.xml' % (addon.ID)
if addon.bool_setting("force_native_layout") and addon.setting("xml_version") != addon.VERSION:
addon.set_setting("xml_version", addon.VERSION)
INFO_XML = u'script-%s-DialogVideoInfo-classic.xml' % (addon.ID)
LIST_XML = u'script-%s-VideoList-classic.xml' % (addon.ID)
ACTOR_XML = u'script-%s-DialogInfo-classic.xml' % (addon.ID)
path = os.path.join(addon.PATH, "resources", "skins", "Default", "1080i")
xbmcvfs.copy(strSource=os.path.join(path, INFO_XML_CLASSIC),
strDestination=os.path.join(path, INFO_XML))
xbmcvfs.copy(strSource=os.path.join(path, LIST_XML_CLASSIC),
strDestination=os.path.join(path, LIST_XML))
xbmcvfs.copy(strSource=os.path.join(path, ACTOR_XML_CLASSIC),
strDestination=os.path.join(path, ACTOR_XML))
else:
INFO_XML = INFO_XML_CLASSIC
LIST_XML = LIST_XML_CLASSIC
ACTOR_XML = ACTOR_XML_CLASSIC
class WindowManager(object):
window_stack = []
def __init__(self):
self.active_dialog = None
self.saved_background = addon.get_global("infobackground")
self.saved_control = xbmc.getInfoLabel("System.CurrentControlId")
self.saved_dialogstate = xbmc.getCondVisibility("Window.IsActive(Movieinformation)")
# self.monitor = SettingsMonitor()
def open_movie_info(self, movie_id=None, dbid=None, name=None, imdb_id=None):
open movie info, deal with window stack
busy.show_busy()
from dialogs.DialogMovieInfo import DialogMovieInfo
dbid = int(dbid) if dbid and int(dbid) > 0 else None
if not movie_id:
movie_id = tmdb.get_movie_tmdb_id(imdb_id=imdb_id,
dbid=dbid,
name=name)
dialog = DialogMovieInfo(INFO_XML,
addon.PATH,
id=movie_id,
dbid=dbid)
busy.hide_busy()
self.open_infodialog(dialog)
def open_tvshow_info(self, tmdb_id=None, dbid=None, tvdb_id=None, imdb_id=None, name=None):
open tvshow info, deal with window stack
busy.show_busy()
from dialogs.DialogTVShowInfo import DialogTVShowInfo
if tmdb_id:
pass
elif tvdb_id:
tmdb_id = tmdb.get_show_tmdb_id(tvdb_id)
elif imdb_id:
tmdb_id = tmdb.get_show_tmdb_id(tvdb_id=imdb_id,
source="imdb_id")
elif dbid:
tvdb_id = local_db.get_imdb_id(media_type="tvshow",
dbid=dbid)
if tvdb_id:
elif name:
tmdb_id = tmdb.search_media(media_name=name,
year="",
media_type="tv")
dialog = DialogTVShowInfo(INFO_XML,
addon.PATH,
tmdb_id=tmdb_id,
dbid=dbid)
busy.hide_busy()
def open_season_info(self, tvshow_id=None, season=None, tvshow=None, dbid=None):
open season info, deal with window stack
needs *season AND (*tvshow_id OR *tvshow)
busy.show_busy()
from dialogs.DialogSeasonInfo import DialogSeasonInfo
if not tvshow_id:
params = {"query": tvshow,
"language": addon.setting("language")}
response = tmdb.get_data(url="search/tv",
params=params,
cache_days=30)
if response["results"]:
tvshow_id = str(response['results'][0]['id'])
else:
params = {"query": re.sub('\(.*?\)', '', tvshow),
params=params,
cache_days=30)
dialog = DialogSeasonInfo(INFO_XML,
addon.PATH,
id=tvshow_id,
season=max(0, season),
dbid=int(dbid) if dbid and int(dbid) > 0 else None)
busy.hide_busy()
def open_episode_info(self, tvshow_id=None, season=None, episode=None, tvshow=None, dbid=None):
needs (*tvshow_id OR *tvshow) AND *season AND *episode
from dialogs.DialogEpisodeInfo import DialogEpisodeInfo
if not tvshow_id and tvshow:
tvshow_id = tmdb.search_media(media_name=tvshow,
media_type="tv",
cache_days=7)
dialog = DialogEpisodeInfo(INFO_XML,
addon.PATH,
tvshow_id=tvshow_id,
episode=episode,
def open_actor_info(self, actor_id=None, name=None):
open actor info, deal with window stack
from dialogs.DialogActorInfo import DialogActorInfo
if not actor_id:
name = name.split(" %s " % addon.LANG(20347))
names = name[0].strip().split(" / ")
if len(names) > 1:
ret = xbmcgui.Dialog().select(heading=addon.LANG(32027),
list=names)
if ret == -1:
return None
name = names[ret]
else:
name = names[0]
busy.show_busy()
actor_info = tmdb.get_person_info(name)
if not actor_info:
return None
actor_id = actor_info["id"]
else:
busy.show_busy()
dialog = DialogActorInfo(ACTOR_XML,
addon.PATH,
id=actor_id)
busy.hide_busy()
def open_video_list(self, listitems=None, filters=None, mode="filter", list_id=False,
filter_label="", force=False, media_type="movie", search_str=""):
open video list, deal with window stack
from dialogs import DialogVideoList
Browser = DialogVideoList.get_window(windows.DialogXML)
dialog = Browser(LIST_XML,
addon.PATH,
listitems=listitems,
filters=[] if not filters else filters,
mode=mode,
list_id=list_id,
force=force,
filter_label=filter_label,
search_str=search_str,
type=media_type)
self.open_dialog(dialog)
def open_youtube_list(self, search_str="", filters=None, filter_label="", media_type="video"):
from dialogs import DialogYoutubeList
YouTube = DialogYoutubeList.get_window(windows.DialogXML)
dialog = YouTube(u'script-%s-YoutubeList.xml' % addon.ID, addon.PATH,
type=media_type)
def open_infodialog(self, dialog):
if dialog.info:
else:
utils.notify(addon.LANG(32143))
def open_dialog(self, dialog):
if self.active_dialog:
self.window_stack.append(self.active_dialog)
self.active_dialog.close()
utils.check_version()
if not addon.setting("first_start_infodialog"):
addon.set_setting("first_start_infodialog", "True")
xbmcgui.Dialog().ok(heading=addon.NAME,
line1=addon.LANG(32140),
line2=addon.LANG(32141))
self.active_dialog = dialog
dialog.doModal()
if dialog.cancelled:
addon.set_global("infobackground", self.saved_background)
self.window_stack = []
return None
if self.window_stack:
self.active_dialog = self.window_stack.pop()
xbmc.sleep(300)
self.active_dialog.doModal()
else:
def play_youtube_video(self, youtube_id="", listitem=None):
play youtube vid with info from *listitem
url, yt_listitem = player.youtube_info_by_id(youtube_id)
if not listitem:
listitem = yt_listitem
if not url:
utils.notify(header=addon.LANG(257),
message="no youtube id found")
return None
if self.active_dialog and self.active_dialog.window_type == "dialog":
xbmc.executebuiltin("Dialog.Close(movieinformation)")
xbmc.Player().play(item=url,
listitem=listitem,
windowed=False,
startpos=-1)
player.wait_for_video_end()
wm = WindowManager()
(2020-03-31, 18:19)scott967 Wrote: [ -> ]If anyone is interested, I have a Python 3 version available at my github releease page here: Ver 5.6.0+matrix.1@scott967 did you ever figure out how to change the default "info" action ( in any skin) to open extended info instead of the skin info screen ? I say "any skin" because I would mod a skin for my own use as long as it had this feature.
You must first install my Python 3 update of script.module.kodi65 1.2.1+matrix.1
I added a new setting for a personal Youtube API key which is required to get Youtube search results (the hard-coded key in kodi65 won't work any more). Playback is via official Youtube plugin so if a user has that working they can use the API key from setting the plugin up in the extended info setting.
Currently there is some added code that's unique to my skin mod. I don't think that will affect any other skin (the code is there to restore the videos or music window view that was in effect prior to searching Youtube, as the addon was hard-coded for Estuary view IDs, otherwise IIRC you end up with view 50 after exiting the addon's dialog window.)
scott s.
<oninfo condition="String.IsEqual(ListItem.DBType,movie)">RunScript(script.extendedinfo,info=extendedinfo,imdb_id=$INFO[ListItem.IMDBNumber])</oninfo>
(2020-12-23, 22:32)Angelinas Wrote: [ -> ]In view xml on begining of list or panel writeThanks for replying , could you explain a little more please .
<code><oninfo condition="String.IsEqual(ListItem.DBType,movie)">RunScript(script.extendedinfo,info=extendedinfo,imdb_id=$INFO[ListItem.IMDBNumber])</oninfo></code>
In mine mod I have custom dialog for "script.extendedinfo-DialogVideoInfo" with name
script-script.extendedinfo-DialogVideoInfo.xml
and when I press "i" on keybord kodi open that dialog, similar for this I use for set, but dialog from Shs script.
https://github.com/Angelinas1/Aeonmq6-Le...t.xml#L787
All working
(2020-12-23, 23:07)Angelinas Wrote: [ -> ]You Don't need to create new dialog...use default dialog from extended script that will work too.So to be clear , where, in default dialogvideoinfo.xml file should I paste <oninfo condition="String.IsEqual(ListItem.DBType,movie)">RunScript(script.extendedinfo,info=extendedinfo,imdb_id=$INFO[ListItem.IMDBNumber])</oninfo>
