I have version 3.1.1 on my Kodi 15.2. After the recent update to version 4.0.0 I am getting an error "Addon is incompatible or been marked broken in repository. Dependencies not met. Please contact add-on Author. My debug log is
http://xbmclogs.com/p72iyozoe
When this error was generated I immediately got an error in the Audiodb.com for music videos scraper v. 1.2.8 "Addon is incompatible or has been marked broken in the repository. Broken due to website overload. Please use another scraper"
Can you kindly help.
(2015-12-01, 14:50)maverick1960 Wrote: [ -> ]I have version 3.1.1 on my Kodi 15.2. After the recent update to version 4.0.0 I am getting an error "Addon is incompatible or been marked broken in repository. Dependencies not met. Please contact add-on Author. My debug log is http://xbmclogs.com/p72iyozoe
You are obviously missing a dependency. Since you decided to install bleeding-edge you should know about stuff like that.
AudioDB.com scraper is not related to this add-on at all.
Please can you kindly point me in the right direction What is bleeding edge and how do I uninstall it.
Bleeding-edge means using the git version, and not the repo version. Youre probably missing script.module.actionhandler.
To get back to stables remove your git version and install the one from official repository.
I have uninstalled the script. Now I cannot install from either the fusion repo nor the git. Cannot see the script on the official kodi repo under program addons. Please let me know how to install the same. My debug log
http://xbmclogs.com/pm348pylh
I am loading similar movies and youtube search as plugin content in a custom window. Just noticed I am not getting any results anymore, I have not made any changes to the skin code. Is this broken at the moment? Other content like directormovies are working fine as plugin content.
Hi. I'm getting dependencies not met on a recent update. I left it for a few days but same thing. I've uninstalled / reinstalled and even tried to install from your zip ..... Dependencies not met
I'm on v 15.2 Isengard running Rapier skin Any help appreciated. Thanks
(2015-12-02, 16:10)chris1304 Wrote: [ -> ]Hi. I'm getting dependencies not met on a recent update. I left it for a few days but same thing. I've uninstalled / reinstalled and even tried to install from your zip ..... Dependencies not met I'm on v 15.2 Isengard running Rapier skin Any help appreciated. Thanks
Hi chris1304.
Which version of Rapier do you use?
I guess you have some silly repositories installed which blindly pull in my latest GIT version.
master branch is now jarvis-only and needs script.module.actionhandler (already available on jarvis repository).
Older kodi versions have to use Helix branch.
phil65,
I am running 15.2 Isengard and have actionhandler 1.0.1 installed.
Can your latest extendedinfo script 4.0.0 work on Isengard or this this version exclusively for Jarvis?
Is anyone else on Jarvis missing the lib folder from the new actionhandler script? I got the update to version 4.0 and noticed errors in the log saying it could not find the ActionHandler module. Looking locally in script.actionhandler which must have been installed automatically the lib folder was not there. To resolve this I added the lib folder here:
https://github.com/phil65/script.module....master/lib locally and the extended info script works correctly now.
Yeah, I experienced and did the exact same thing.
Official repo probably needs an updated or fixed version?
(2015-12-05, 22:19)Gade Wrote: [ -> ]Yeah, I experienced and did the exact same thing.
What is the official repo for this addon? I was under impression that its default Kodi repo but cant find it there.
