(2021-03-29, 23:47)drinfernoo Wrote: [ -> ] (2021-03-27, 21:59)mardukL Wrote: [ -> ] (2021-03-27, 20:32)Angelinas Wrote: [ -> ]Done
But still sorry, had to be done in 1pr.
glad @Fuchs2468 found the issue fast.
my concentration level is bad sometimes
so what.
its done now.
thanks.
tested and workin.
https://github.com/kodi-community-addons...-1.0.3.zip
It seems to me that the lines here: https://github.com/kodi-community-addons....xml#L9-11 don't agree with the folder structure... Is that accurate?
EDIT: Seems others have noticed this as well, but still looking like it didn't get fixed in the repo.
The line 9 is correct.
But the line 10 and line 11 must be changed.
(2021-03-30, 04:12)Fuchs2468 Wrote: [ -> ] (2021-03-29, 23:47)drinfernoo Wrote: [ -> ] (2021-03-27, 21:59)mardukL Wrote: [ -> ]But still sorry, had to be done in 1pr.
so what.
its done now.
thanks.
tested and workin.
I should've been clearer... I included L9 because it
was correct, and the others weren't
EDIT: It also appears to be correct in the
addon.xml
for the repo itself, but not in the
addons.xml
. I'm honestly not sure if this is an issue or not, but should probably be fixed for clarity
(2021-03-30, 05:27)drinfernoo Wrote: [ -> ] (2021-03-30, 04:12)Fuchs2468 Wrote: [ -> ] (2021-03-29, 23:47)drinfernoo Wrote: [ -> ]It seems to me that the lines here: https://github.com/kodi-community-addons....xml#L9-11 don't agree with the folder structure... Is that accurate?
I should've been clearer... I included L9 because it was correct, and the others weren't
EDIT: It also appears to be correct in the addon.xml
for the repo itself, but not in the addons.xml
Indeed correct,
addon.xml was correct, addons.xml wasn't updated correct. Fixed soon.
https://github.com/kodi-community-addons...2410592871
Fixed typo on github for addon.xml in repo, also need test for matrix titan skin.I changed code in github for shs need to run some test before upload in repo.
In skin fixed in skinsetings lot of action.
I tested some mod of skin and almost all working as in Leia version.
All knowing missing actiion in matrix for all shs script
-Wall images (problem with PIL, i don't know hiw to fix)
-webservice(cherypie problem with decode)
-similar and recommend movies in s.h.widget
If you notice some new isue please write here.
(2021-03-30, 08:58)Angelinas Wrote: [ -> ]Fixed typo on github for addon.xml in repo, also need test for matrix titan skin.I changed code in github for shs need to run some test before upload in repo.
for the titan skin itself i just can say that a lot of deprecated 'gui' stuff is in use, as it is based on gui changes of kodi krypton.
for v 3.8.5 i just bumb the gui dependencie for leia, release in the repo, nothing else.
i dont remember all atm but know there are alot.
I'm using several scripts from community add-ons github but every time Dev change something in that scripts don't update automatically.
Need to manual download zip and install.
I already install last Marcelveldt repository (1.03)
What I'm doing wrong?
Why on the widget its only show The Walking Dead? Any idea how to fix it?
Also getting this error as well when I was trying to install Titan Bingie Mod on Matrix. Same error about wall images/PIL. Heres a brief log :
2021-03-30 18:24:14.010 T:9324958 WARNING <general>: Skin Helper Backgrounds --> Exception details: Type: ModuleNotFoundError Value: No module named 'PIL' Traceback: Traceback (most recent call last):
File "/var/mobile/Library/Preferences/Kodi/addons/script.skin.helper.backgrounds/resources/lib/wallimages.py", line 24, in <module>
from PIL import Image
ModuleNotFoundError: No module named 'PIL'
2021-03-30 18:24:14.010 T:9324958 ERROR <general>: Skin Helper Backgrounds --> Exception in resources.lib.wallimages ! --> No module named 'PIL'
2021-03-30 18:24:14.024 T:9324958 WARNING <general>: Skin Helper Backgrounds --> Exception details: Type: ModuleNotFoundError Value: No module named 'Image' Traceback: Traceback (most recent call last):
During handling of the above exception, another exception occurred:
File "/var/mobile/Library/Preferences/Kodi/addons/script.skin.helper.backgrounds/resources/lib/wallimages.py", line 32, in <module>
import Image
ModuleNotFoundError: No module named 'Image'
2021-03-30 18:24:14.025 T:9324958 ERROR <general>: Skin Helper Backgrounds --> Exception in resources.lib.wallimages ! --> No module named 'Image'
unsure if that helps and related to the pil ~ pillow 'issue'
but may worth put in here,
https://forum.kodi.tv/showthread.php?tid...pid2179879
edit: also unsure if thread needs splitted to differ the skinhelper addons
(service , widgets, backgrounds, colorpicker ...)
edit2: by reading "no module named 'image' , may there is an issue with unescaped paths / parenthesis , but unsure....
(2021-03-31, 20:45)mardukL Wrote: [ -> ]unsure if that helps and related to the pil ~ pillow 'issue'
In win10 I have module Image.py , but stil wall images dosen't work.
I will remove all problematic code including Pil from wallimages.py in script.skin.helper.backgrounds/
