2017-02-19, 23:37
(2017-02-19, 21:37)marcelveldt Wrote: [ -> ]I set One of content.(Movie,tvshow,season,episode,artist,album.....), in favourite.(2017-02-14, 18:57)Angelinas Wrote: [ -> ]Marcel , latest fix for favourite didnt have succes...still broken for all content type.Version SHS widget 1.0.20
What do you mean ? Favourites widgets are working fine on my setup.
If it's still in error, do you see any errors in your kodi logfile ?
Open S.H.widget from Addon (your code are in that addon-no mine) with Button "use".
Open widget content in list:
movies,chose favourite (last in list) .:.all empty
tvshows,choose favourite(last in list)...have info (only this working)
...same for all other favourite ...all empty
Maybe you dont have all content in your favourite , I for test have all and one of them is making trouble for me
22:25:35.814 T:3964 DEBUG: CVideoDatabase::RunQuery took 3 ms for 0 items query: select * from musicvideo_view WHERE ((musicvideo_view.strFilename LIKE '%01 Skyfall.mp3%'))
22:25:35.820 T:3964 DEBUG: JSONRPC: Value does not lay between minimum and maximum in type albumid
22:25:35.821 T:3964 DEBUG: Skin Helper ArtUtils --> {"error":{"code":-32602,"data":{"method":"AudioLibrary.GetAlbumDetails","stack":{"message":"Value between 1 (inclusive) and 2147483647 (inclusive) expected but 0 received","name":"albumid","type":"integer"}},"message":"Invalid params."},"id":1,"jsonrpc":"2.0"}
22:25:35.821 T:3964 DEBUG: Skin Helper ArtUtils --> {'params': {'albumid': 0, 'properties': ['title', 'fanart', 'thumbnail', 'genre', 'displayartist', 'artist', 'genreid', 'musicbrainzalbumartistid', 'year', 'rating', 'artistid', 'musicbrainzalbumid', 'theme', 'description', 'type', 'style', 'playcount', 'albumlabel', 'mood', 'dateadded']}, 'jsonrpc': '2.0', 'method': 'AudioLibrary.GetAlbumDetails', 'id': 1}
22:25:35.848 T:3964 WARNING: Skin Helper Widgets --> Traceback (most recent call last):
File "C:\Users\TEST\AppData\Roaming\Kodi\addons\script.skin.helper.widgets\resources\lib\main.py", line 141, in show_widget_listing
all_items = getattr(media_class, action)()
File "C:\Users\TEST\AppData\Roaming\Kodi\addons\script.skin.helper.widgets\resources\lib\media.py", line 123, in favourites
return Favourites(self.addon, self.artutils, self.options).favourites()
File "C:\Users\TEST\AppData\Roaming\Kodi\addons\script.skin.helper.widgets\resources\lib\favourites.py", line 63, in favourites
details = self.find_window_match(fav, media_filter)
File "C:\Users\TEST\AppData\Roaming\Kodi\addons\script.skin.helper.widgets\resources\lib\favourites.py", line 101, in find_window_match
extend_dict(result, self.artutils.get_music_artwork(result["title"], result["artist"][0]))
KeyError: 'title'
22:25:35.849 T:3964 ERROR: Skin Helper Widgets --> Exception in main ! --> 'title'
