(2017-02-24, 18:41)Guilouz Wrote: [ -> ] (2017-02-24, 17:48)morstef4 Wrote: [ -> ]This MOD2 is magnificent !
I have 3 tiny changes I would like to propose. (Tiny but might take a lot of efforts)
I wonder if the box where the flags are can be move to the right section where the Director and staffs are...
Having them on the left reduced the space for the plot readings... (where usually more data are written)
The media information icons at the bottom of the screens are .png ? Personnaly I would edit the one that as the HD1080 and others so that 1080 is bigger. (At ten feet I have a hard to see)
Not that I want to go back to Estuary but, selecting Estuary skin from the MOD caused the "Settings" is no longer available.
Thank you
Not possible to move right, some movies have more info :
Yes media flags are png but you need to edit code to change size of resolution icon.
Your right, the right box is not a good solution.
I tried to look at the png but no luck.
Found Variables.xml, DialogPlayerProcessInfo.xml, 1080.png...... but just can't find my way...too bad. ;-)
(2017-02-25, 00:55)morstef4 Wrote: [ -> ] (2017-02-24, 18:41)Guilouz Wrote: [ -> ] (2017-02-24, 17:48)morstef4 Wrote: [ -> ]This MOD2 is magnificent !
Thank you
png are located in media/flags/videoresolution
And code is in Includes.xml line 451
Hi, is the hide main menu option in mod version 1 also?
I need it,but i need itfor krypton version..
(2017-02-25, 10:06)Skank Wrote: [ -> ]Hi, is the hide main menu option in mod version 1 also?
I would also like to see this v2 mod for krypton.
(2017-02-25, 10:31)hoppel118 Wrote: [ -> ] (2017-02-25, 10:06)Skank Wrote: [ -> ]Hi, is the hide main menu option in mod version 1 also?
(2017-02-25, 14:26)dickdistortion Wrote: [ -> ] (2017-02-25, 10:31)hoppel118 Wrote: [ -> ] (2017-02-25, 10:06)Skank Wrote: [ -> ]Hi, is the hide main menu option in mod version 1 also?
Yes please, me too!
No, only for V2.
Install Kodi 18, it's working well.
Hi Guilouz,
After the 2.0.5 update the skin stoped to show the movie set logo. It used to show the set logo here:
i mean this logo:
Is it my problem or is it something that i am doing wrong? And another question that i would like to ask you is about extened info addon. is it working? because mine is not working.
Thank you.
(2017-02-25, 17:53)Georgio85 Wrote: [ -> ]Hi Guilouz,
i mean this logo:
Thank you.
Thanks, fixed on git.
No, not working, I have reported issue on extended info thread but not fixed yet.
(2017-02-25, 16:15)Guilouz Wrote: [ -> ] (2017-02-25, 10:06)Skank Wrote: [ -> ]Hi, is the hide main menu option in mod version 1 also?
(2017-02-25, 14:26)dickdistortion Wrote: [ -> ] (2017-02-25, 10:31)hoppel118 Wrote: [ -> ]I would also like to see this v2 mod for krypton.
Yes please, me too!
No, only for V2.
I cant, i need mvc kodi build and thats 17 only.
No chance supporting 17 then? Very pitty
Damn, in Desperate need of an estuary mod that supports full screen widget, without left menu for kodi krypton
hi Guilouz ,
Is it possbly to add option to edit movie collection plot.
Like the way you can do it for a single movie.
Is it something that you can do it? or is it something for another addon. If you cant do it do you know where the metadata from the scrapers are stored?
Any info for that matter would be very helpful
Thank you
