Morning and evening to you,
I have been playing around with the mod for a few days, the major thing i want to use it is upnp. I have my main computer which acts as a server for all others, and I have mutiple pi's and laptops. I want to pretty much have the upnp sources on the homescreen as if they were local. I have run into 2 hurdles
1) content within widgets (from upnp) will not play, I press enter or select and it does nothing, but oddly if i press c and bring up the context menu, and then press play it plays perfectly fine. I cant really understand why they wont play by default.
2) This is by far secondary, I want to be able to exclude watched content from specific widgets (for upnp sources) currently recently added shows me a somewhat differnt order of content and shows watched media.
I do have some limited experience with skinning on kodi, ive slapped together a few very basic mods (often mods of mods). Infact i had a basic version of estuary with skin shortcuts working (as my current skin actually) but with v18 I found that this mod really has a lot of extra cool features.
I hope that i can help figure this out
Some of the music clearart on TheAudioDB is poor quality at the moment, I would appreciate if any skilled artists could help out making it better
New Update 2.9.0 on repository :
• KODI 18 : Move recording control and info functionality from player to PVR
• KODI 18 : Add button to bring up program selection dialog
• Add support for more aspect ratios (used by newer phones)
• Add Christmas (1 december to 2 january) & Halloween (30 & 31 october) themes
• Add extended info when playing music
• Minor fixes
(2017-12-05, 22:48)ketterer Wrote: [ -> ]Morning and evening to you,
1) A debug log can be help in this situation :
http://kodi.wiki/view/Log_file/Easy
2) You must use smart playlist to do that and add this playlist as widget :
http://kodi.wiki/view/smart_playlists
I also setup some widgets on the main screen for netflix, however the shows that it normally displays are not from the profile linked.
(2017-12-06, 03:52)Guilouz Wrote: [ -> ] (2017-12-05, 22:48)ketterer Wrote: [ -> ]Morning and evening to you,
1) A debug log can be help in this situation : http://kodi.wiki/view/Log_file/Easy
2) You must use smart playlist to do that and add this playlist as widget : http://kodi.wiki/view/smart_playlists
Here is my buglog,
https://paste.ubuntu.com/26122679/
in this i try clicking on several upnp movies in the widget, but i did not use the context menu to play one.
(2017-12-06, 05:31)ketterer Wrote: [ -> ] (2017-12-06, 03:52)Guilouz Wrote: [ -> ] (2017-12-05, 22:48)ketterer Wrote: [ -> ]Morning and evening to you,
Here is my buglog, https://paste.ubuntu.com/26122679/
I have done some extra testing, so if i use the context menu to play a video from this widget it plays as mentioned, it will then play by just clicking on it. This persists through menu rebuilds, but not restarting kodi
Hi, anyway to create a "Recently Aired" widget?
edit:figured it out
(2017-12-03, 21:02)Guilouz Wrote: [ -> ] (2017-12-03, 16:45)MrSed Wrote: [ -> ]Hi all,
I switched yesterday to Kodi v18 and Estuary MOD v2. One issue drives me crazy.
The "duration" and "finshed time" media flag is empty. The symbol is shown but no time information. This issue doesn't appear in standard estuary skin.
Does anyone has advice how to fix it?
Thansk. I appreciate your help.
No idea... Duration and finished time are from kodi core, there is no reason they are not working.
I had the same issue, I made changes to the Show Mediaflags in the Skin-General section, set it to Skin standard and they re-appeared.
(2017-12-06, 05:47)ketterer Wrote: [ -> ] (2017-12-06, 05:31)ketterer Wrote: [ -> ] (2017-12-06, 03:52)Guilouz Wrote: [ -> ]1) A debug log can be help in this situation : http://kodi.wiki/view/Log_file/Easy
Kodi try to ipen this playlist file :
21:26:37.487 T:140278589548288 ERROR: GetDirectory - Error getting upnp://87eac7c3-7991-2364-1c4c-b3159de7d5d5/special%3a%2f%2fprofile%2fplaylists%2fvideo%2fg-gp%20.xsp/
What do you try to open ? A folder ? A video file ?
(2017-12-06, 13:21)Guilouz Wrote: [ -> ] (2017-12-06, 05:47)ketterer Wrote: [ -> ] (2017-12-06, 05:31)ketterer Wrote: [ -> ]Here is my buglog, https://paste.ubuntu.com/26122679/
https://paste.ubuntu.com/26133053/ -log
http://paste.ubuntu.com/26133115/ - crash log
The one you referenced above was actually broken but i now tried to add "video library" to the widget and when i try to open something such as title or year it actually stalls and needs to be killed. So i dont know why but it has trouble with upnp sources in general in a widget.
