(2017-11-18, 03:35)terpsarlington Wrote: [ -> ]Is there any way to make it so when you hit the power button the program just Exits (Quits()) instead of the power menu. Also any way to make it so when you hit the search button it goes directly into search local library.
If not, can you provide an option to delete the top menu (power, settings, search). I can make custom side menu with these option.
Not possible but you can edit code in Home.xml line 2041 to 2064.
(2017-11-18, 03:38)Guilouz Wrote: [ -> ] (2017-11-18, 03:23)ritaben Wrote: [ -> ]Hi, wind speed in weather top panel is cut off at bottom, in both weather underground and openweathermap extended.
Using latest version of Estuary MOD V2 in windows 10.
Thank you
I don't see any issue :
Please post screenshot.
Screenshot here -
http://imageshack.com/a/img922/3429/eHBZ3n.jpg
Only happens on windows 10 pc, my nuc running nightly LibreElec and your latest version is OK.
Thank you
(2017-11-18, 04:44)ritaben Wrote: [ -> ] (2017-11-18, 03:38)Guilouz Wrote: [ -> ] (2017-11-18, 03:23)ritaben Wrote: [ -> ]Hi, wind speed in weather top panel is cut off at bottom, in both weather underground and openweathermap extended.
Thank you
Screenshot here - http://imageshack.com/a/img922/3429/eHBZ3n.jpg
Thank you
I think you have not a correct aspect ratio with your resolution. I see you use Arial font and just try with this font and it's working for me.
Hi Guilouz,
I would really love to see the Track name and then the Artist name in the music library when I sort the view by Track, similar to this skin...
This is how it shows now...
Very strange. What do you think the problem is??
(2017-11-18, 14:26)iMak Wrote: [ -> ]Very strange. What do you think the problem is??
Are you in music library ? Music track correctly tagued and scrapped ?
And here while playing, everything seems ok...
I'm afraid yes, all the albums. Here is another one...
i was trying to do a Genres widget appearance that look likes the default Genre widget in movies and TV. where you have three posters with banner. However when ever i choose appearence as genres i just get "tow laughing faces" with banner on the bottom. anyway to change this into the three posters.
windows 10, 64 bit.
when we will get the new update (2.8.9) ?
and thank you for keeping up the good work I appreciate what you are doing
