the text label under the tiles have disappeared from the favourites page on the main screen, can these be re-enabled?
also, resume positions on YouTube videos don't seem to be remembered with this skin, they always play from the start. any ideas?
Is there any way to make the thumbnails in the widgets smaller? They seem huge, I only get four x two the screen at a time. Thanks
I am having trouble with this skin. This is a fresh install, I install the repository, dependencies, and skin as per instructions. Once the skin is installed, if I navigate to Home and then back Setting, I can no longer access Skin, Interface, or any other settings for that matter.
Making it impossible to change any setting of the skin or even revert back to the default skin. What am I missing?
skin.estuary.modv2.log
(2018-06-28, 01:54)kaybird Wrote: [ -> ]There is a section in the main menu of titles where it shows 10 (?) random titles for you to choose from. How can I force UI to refresh the list and give me a new set of random titles?
Random titles are updated every time there is a change in database (movies watched, cleaning database, new scann, etc...).
(2018-06-28, 04:51)Picard Wrote: [ -> ]Thanks for great skin, my favourite, one problem though, I keep getting Skin Helper Service error, tried deleting addon but still doesn't work.
Any help would be appreciated
Without debug log, it's difficult to help you...
(2018-06-30, 11:54)junias Wrote: [ -> ]Hi,
I have a quick question:
In the movie list there is the rating in a blue circle above the cover. Thats really nice.
But for view the rating from TMDB is used.
Thats not ideal, I think...
Here´s the explanation:
The TMDB rating is mostly much worse than the IMDB rating.
For the TMDB rating there are less user ratings (example: TMDB: 347 ratings, IMDB: 1236 ratings). So the average of the TMDB rating, which is shown in the view, is based on just a few ratings...
So my question:
Would it be possible, to choose, which ratings should be shown in the view?
Or better, get a average of the ratings:
Example for this:
347 ratings from TMDB with 6,1 and 1236 ratings from IMDB with 7,2 --> ((347*6,1) + (1236*7,2)) / (347 + 1236) = 7,0
Thanks so much!
Ratings in views depending of scrapper you use. If you use a scrapper it use IMDB rating, you will have it.
(2018-07-02, 08:25)tehax Wrote: [ -> ] (2018-06-14, 18:45)Angelinas Wrote: [ -> ]Add this code to see what SHS show for info...and all good for me............need some time to load(old machine, but working).
Change for mine EPG, title in originaltitle----- I use EPG , non english language.
videOSD.xml
<label>$VAR[VideoOSDHelpTextVar]$INFO[Window(Home).Property(SkinHelper.Player.OriginalTitle), - ]$INFO[Window(Home).Property(SkinHelper.Player.media_type), - ]</label>
All good "Monk" "tvshow"
Hello Guilouz,
its me again. Do you get ahead with actors for pvr? One other thing is when i click on "m-button" while playing a movie, then on actors tab and choose one actor a new window pop up with a list where the actor also cooperate. Could do add this function also in info "i-button" window?
I can't work more on PVR because the person who gave me access to his PVR server disconnected him.
Some Xbox One feedback.
Maybe someone can help me fix some issues.
With every video add on (set on poster widget) right click and go to info.
Play botton works perfect
Play Trailer: Kodi crashes, exits and goes back to Xbox Home
Info: tmdb-id4 error
Director: no response
Edit: Skin Helper Settings Error
Dont have any other buttons
Maybe someone can help me out ?
Thanx
Not what you want, but get to the coreelec configuration via addons. Then add it to favourites
(2018-07-16, 16:51)djric Wrote: [ -> ]Some Xbox One feedback.
Thanx
Have you try with trailer in fullscreen or not ?
I can not really help you I do not use Kodi on Xbox...
Hi, I like the mods, but is it possible to put a short cut for the tv guide on the home page, for live tv?
& a shortcut for Years on the home page for movies? & possibly a search shortcut.
Please.
If anyone else, doesn't like this idea, please say so.
(2018-07-18, 22:42)bubblegum57 Wrote: [ -> ]Hi, I like the mods, but is it possible to put a short cut for the tv guide on the home page, for live tv?
Please.
This shortcuts are already on home menu, TV Guide and Years are in categories widgets and search button is on top of main menu.
