(2017-08-18, 23:56)rudrood Wrote: [ -> ]Is there a way to change the background to fully transparant for the fanart in info mode?
Like the option: hide fanart opacity in fullscreen mode.
The color options:
Background color: none
Background patern: none
Opacity for fanart as background: 100%
Opacity for top and bottom bars: 100%
result in the next screenshot with still some tint on fanart. Compare the background with the artist banner.
watch gallery
It's normal, no opacity changes on music visualisation because if opacity is set to 100%, visualisation is not shown. But I can add opacity for top and bottom bars.
(2017-08-18, 12:00)Guilouz Wrote: [ -> ] (2017-08-18, 07:33)XxKaiserxX Wrote: [ -> ]Guilouz any chance section on manga in your build?
Nope, because for mangas, kodi use TV Shows section. If you want to isolate mangas, you must use smart playlists like that :
For TV Shows : TV Shows.xsp
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>TV Shows</name>
<match>one</match>
<rule field="path" operator="startswith">
<value>smb://NAS/video/TV Shows/</value>
</rule>
</smartplaylist>
For Mangas : Mangas.xsp
<name>Mangas</name>
<match>one</match>
<value>smb://NAS/video/Mangas/</value>
</rule>
</smartplaylist>
Put this two files in userdata / playlists / video and you can choose them in personalize home menu.
You can also do the same for widgets.
Exemple for recently added :
For TV Shows : Recent TV Shows.xsp
<match>all[/php]</match>
</rule>
<rule field="dateadded" operator="after">
<value>1900-01-01</value>
</rule>
<order direction="descending">dateadded</order>
</smartplaylist>
For Mangas : Recent Mangas.xsp
<name>Mangas</name>
<match>all</match>
</rule>
</rule>
</smartplaylist>
Wow thanks for the tip bro!!!
(2017-08-18, 20:21)Guilouz Wrote: [ -> ] (2017-08-18, 18:51)tehax Wrote: [ -> ]I do not why but in series and movies view "shift" i get no clearlogo only text. In other windows like home menu i get them. Any idea?
Log: https://pastebin.com/R0JAejTf
picture: https://1drv.ms/i/s!AnMOu_3VsLX4rAoyJbHGgfQgFsV5
In Shift view, it's clearart on top and clearlogo on list :
If you use streaming addons, it's normal, property of Skin Helper Service not working in container. You must have stored files with database to have them.
Same error here in windows and android tv box!
(2017-08-19, 03:33)XxKaiserxX Wrote: [ -> ] (2017-08-18, 20:21)Guilouz Wrote: [ -> ] (2017-08-18, 18:51)tehax Wrote: [ -> ]I do not why but in series and movies view "shift" i get no clearlogo only text. In other windows like home menu i get them. Any idea?
This view use ClearLogo and ClearArt from Artwork Downloader. Just added a new TV Shows and no problem on OSX and LibreELEC builds.
Hi, it would be nice if fanart is empty on view wall (fanart) it will fall back to poster content to prevent from blank items.
watch gallery
Artwork downloader currently has an issue: the integrated API keys are dead
Make sure to follow instructions about API keys in first post of this thread before reporting any issue with artworks in this mod
Ok then:
To use your API keys with Skin Helper Service :
Go to 'Settings / Skin / Extras / Configure personal API keys'
Go to 'API keys' tab and enter your API keys
Ready!!
To use your API keys with Artwork Downloader :
Go to Kodi 'addons' folder (see : Userdata (wiki))
Go to 'script.artwork.downloader / lib / provider'
With a text editor open, edit and save this files :
For Fanart.TV : Open 'fanarttv.py' and replace line 34 with your API Key like that : API_KEY = '84f9633e5c6801d82759ed48e5059560'
For TheMovieDb : Open 'tmdb.py' and replace line 33 with your API Key like that : API_KEY = '878b84aeea12334580bd86fa300e67da'
For TheTVDB : Open 'tvdb.py' and replace line 41 with your API Key like that : API_KEY = 'self.api_key = 'FF02D36BE10A733B''
Ready!!
But no logos in shift mode
Poster:
Shift mode:
(2017-08-19, 05:52)Gracus Wrote: [ -> ] (2017-08-19, 03:33)XxKaiserxX Wrote: [ -> ] (2017-08-18, 20:21)Guilouz Wrote: [ -> ]In Shift view, it's clearart on top and clearlogo on list :
Ah, that' s it. In the past it works without API key now i have a key and it works again. Thanks.
i noticed that icon for video resolution would not be updated on streaming media inside the videoosd. In my case source is amazon plugin. It usually stays on "3D".
watch gallery
A second thing:
When borders for media are enabled in settings they are shown for movies epsiodes etc. but missing on favourites and live tv.
Can't seem to use advanced launcher folder as a home menu item for games. Anyone had the issue and know of a fix?
(2017-08-19, 07:13)XxKaiserxX Wrote: [ -> ]Ok then:
Ready!!
Ready!!
Poster:
Shift mode:
Try to run Artwork Downloader to download Artworks. I think your clearlogos on others views come from Skin Helper Service and artworks from it not working in container (that have Shift view).
(2017-08-19, 12:22)hawkeyexp Wrote: [ -> ]Hi,
watch gallery
A second thing:
There is some issue with videoplayer in last kodi builds, like aspect ratio icon.
For borders it's voluntary.
Best thing is to have local artworks for movies:
Then no more issue...
(2017-08-19, 14:40)Guilouz Wrote: [ -> ]There is some issue with videoplayer in last kodi builds, like aspect ratio icon.
Ok thx - will have a look on next versions of kodi. Will you add the missing borders ?
PS: The skin is really great with its growing features :-)
